Pop & Lock PL8540 install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by abqrivera, Dec 14, 2022.
  1. Dec 14, 2022 at 11:03 PM
    abqrivera
    abqrivera [OP] Active Member
    David
    Albuquerque NM
    2005 Tacoma Access 4 Cyl
    I have a 2005 Tacoma Access 2wd. I have installed the P&L PL 8540 tailgate handle successfully. The problem that I am having is with the correct colored wires. I want to install for the passenger door so I can hit the unlock button on the remote twice to unlock. The colors that come with the instructions are not the correct ones for my truck. Has anyone with my year and model successfully worked this out with the correct colored wires?
    Thanks
  2. Dec 15, 2022 at 1:02 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I looked up the installation instructions. Garbage
    Since your wire colors are different, you’ll likely need to go off pin location.
    IK1 connector pins #5 and #10
    I’d suggest testing with a meter before making alterations to the wiring.
    Rep15 likes this.
  3. Dec 15, 2022 at 1:03 PM
    abqrivera
    David
    Albuquerque NM
    Thank you. Much appreciated.
    TnShooter likes this.
  4. Dec 19, 2022 at 2:27 PM
    abqrivera
    David
    Albuquerque NM
    I checked and my lk1 has only 10 pins. In the diagram it shows 14. Do you think the needed pins remain the same, 5 & 10?
  5. May 15, 2024 at 4:44 PM
    flyymolo
    flyymolo New Member
