Poor Gas Mileage-Any input appreciated
Discussion in '4 Cylinder' started by 01TacomaGuy, Dec 24, 2014.
  1. Dec 24, 2014 at 8:02 PM
    01TacomaGuy
    01TacomaGuy [OP] Member
    Randy
    Horsham PA
    2001 Tacoma SR5 4Cylinder 2.7L 4X4
    New Radio,
    Greetings, hope everyone is well and having a wonderful holiday. So my taco has recently (last 4-5 months) had a major MPG drop. When I first got the truck 3 years ago i was getting about 17-18 miles to the gallon. Today I get about 11-13 MPG. I have tried 87 Octane and 93 Octane. No difference, had a local mechanic who I trust take a look at it and he didn't find anything wrong with it. I am not versed on trucks (Or any kind of vehicle unfortunately) so I have no idea what the problem could be. I do drive the truck rough sometimes, especially responding to fire calls being a volunteer but my driving habits vary week to week. Recently the fire company has been very quite and I have not been driving rough at all, but my MPG is still horrible. The other weird thing i thought was I have been driving it rough to calls for about 4 years now and just recently my MPG took this major crap.
    Any and all suggestions or comments are greatly appreciated.
  2. Dec 26, 2014 at 7:02 PM
    adamr94
    adamr94 Well-Known Member
    Adam
    NC
    06 Regular Cab 4x4
    Was about to say since it's getting close to winter, but it's been happening for awhile.
  3. Dec 26, 2014 at 7:27 PM
    n432cal
    n432cal Well-Known Member
    Caleb
    Minnesota
    96 2.7L
    Shift Knob 32 inch LED bar. 2 led pods. Future plans: 3 inch lift Tailgate tire holder. Bed tent.
    Is your check engine light on?
  4. Dec 26, 2014 at 7:37 PM
    Overlander
    Overlander Well-Known Member
    U joint, in front of pumpkin. Happened to me and two of my friends recently. Does it make noise or clunking? See if it will take grease. Air filter, plugs, tire pressure, ect.
  5. Dec 27, 2014 at 8:47 PM
    01TacomaGuy
    Randy
    Horsham PA
    New Radio,
    No check engine light is one. Has never come on before. It does sometimes make a clunking sound when shifting from park to drive or visa versa. Didnt know the U-joint could affect MPG though? (Im not truck smart though so) Air filter is a K&N repalcement and was just cleaned about two months ago. Had plugs check by a mechanic said they are okay and look to be around 40,000 miles in. (Truck has 73800 total). I will check tire pressure too. Havent done that. They dont look low to just look at but couldnt hurt. Thanks for all the replies.
    Note: I just got gas today. I drove just about 188 miles and the truck took 12.5 gallons of gas. About 15mpg but still bad compared to what ive seen others get on the forum.
  6. Dec 27, 2014 at 9:52 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I'd start with a basic tuneup. If you have been ignoring your rig, then its over-due anyway.
    New plugs (NGK or Denso), PCV valve, oil, oil filter.
    Also, clean the MAF properly (K&N air filters deposit oil on it).
    Grease all drive train zerk fittings.
    Set tire pressures to 35 psi.
    Get rid of K&N filter, and go back to stock :D .
  7. Dec 28, 2014 at 9:10 AM
    Overlander
    Bound u joint creates alot of friction.
    Good luck
  8. Dec 29, 2014 at 3:03 AM
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    '10 4x4 5sp 4cyl Access Cab
    Weathertech Floor Liners, Scangauge 2, Tailgate Hose Clamp, Rear Seat Headrests Removed
    There have been several instances of K&N filters getting oil on the Manifold Air sensors (MAP/MAF) and causing reduced mileage. That is one of the main reasons the AFE Pro Dry filters are usually recommended.
    You could do a quick clean of the sensor and go back to stock or AFE.
  9. Dec 30, 2014 at 9:33 PM
    motorhead310
    motorhead310 Well-Known Member
    Pomona , Ca
    2006 Taco Pre-Runner
    Clean throttle body, maf sensor, sea foam.
  10. Dec 30, 2014 at 10:12 PM
    knuckleduster271
    knuckleduster271 Well-Known Member
    Baron Longrod Von Hug€nschlong
    ohio
    98 sr5 xtra cab
    881's, 5100's, soft 8's, elocker, matrix seats, smittybilt xrc8.
    I had a bad injector once that killed mpg.
    Pretty easy to diagnose, just take a laser thermometer and point it to each cylinder on the header. If one is running alot cooler than the rest then thats the injector thats hanging open.
  11. Jan 5, 2015 at 10:17 AM
    01TacomaGuy
    Randy
    Horsham PA
    New Radio,
    Awesome. Thanks for all the replies and help. Going to take my truck into the shop this week to have all this performed.
    Respectfully,
    Randy
  12. Jan 6, 2015 at 10:04 PM
    tan4x4
    Rick
    Folsom, CA
    These are suggestions that MIGHT be your problem, not guaranteed.
    Just a warning, if you can't do any of this stuff yourself, it will cost you quite a bit of money to do all of the above, especially the injector and cleaning the throttle body. A good shop should be able to tell if the injector needs replacing.
  13. Jan 6, 2015 at 10:08 PM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    THIS
  14. Jan 6, 2015 at 10:09 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    If not mentioned, replace your fuel filter as part of your maintenance. Winter gas may also play a part of your reduced mileage.
    Good Luck
  15. Jan 6, 2015 at 10:53 PM
    kenjw
    kenjw Well-Known Member
    Indiana
    2014 Reg Cab 4-cyl., 5-spd
    If it were me, I would remove the K&N filter and buy a Toyota or equivalent paper filter. Not that it's necessarily bad but just to eliminate a variable. Check tire pressure to make sure it's at the recommended pressure, then take a road trip of at least 100 miles, and check your mileage. Try to do it when it isn't bitter cold, keep your speed down, accelerate moderately, take two-lane roads so you can go 55-60, and see if the truck will get its EPA highway rating. It's very hard to assess mileage when you are doing different kinds of driving, and short trips especially in cold weather annihilate your economy. I would do this before spending any money to fix anything. (Obviously if it is due for normal maintenance such as an oil change do that first.)
    I have found that most cases of bad mileage are a mixture of driving habits and circumstances such as temperature, weather and trip duration. I've never seen spark plugs or any "tune-up" related things affect mileage one iota on newer vehicles. Not to say it never could, but I never have seen it in a slew of different vehicles I have owned.
  16. Jan 12, 2015 at 9:49 PM
    01TacomaGuy
    Randy
    Horsham PA
    New Radio,
    Thanks to all who posted. Appreciate all the input and suggestions. I took the truck to the body shop last Thursday. They checked the injectors with a laser heat gun, they all were at about 95 degrees Fahrenheit so nothing injector wise was done, tire pressure was set to 35psi, air filter was replaced with a normal paper one, spark plugs were replaced with NGK Iridium plugs, sea foam treatment was done and front end was lubricated. The throttle body was cleaned about 3-4 months ago when I had it in the shop last time, oil is changed regularly and everything else seams to be working fine. Ill keep an eye on my MPG and performance of the truck as well as my driving habits.
  17. Jan 15, 2015 at 9:09 PM
    Shineman
    Shineman Jim
    Jim
    Apple Valley, MN
    2010 Tacoma 4WD man trans
    I'm new to the world of Toyota Tacoma trucks but my other vehicles are BMWs. When my mileage starts to deteriorate (it will normally deteriorate in the winter months slightly because the brain box will enrichen the fuel mixture when cold sets in, making starting and warm-up much easier) my first thought is the lambda sensor (oxygen sensor) so I put the car on the analyzer and it verifys the problem. If the sensor is bad, the engine will revert to full rich mixture, which you will notice by a deterioration in your MPG. As I say, I am very new to Toyota but I believe it does in fact have a Lambda sensor and if your vehicle is approaching high mileage, you might want to look at it. My Ford Ranger sensor lasted about 80K miles.
  18. Jan 15, 2015 at 9:20 PM
    Shineman
    Shineman Jim
    Jim
    Apple Valley, MN
    I neglected to mention in my last post that if your EEC reverts to full rich (default setting) due to the Lambda sensor failure, you stand a good chance of taking out the catalytic converter as well. As I pointed out, I am not a Taco expert but I believe most engines of this era have Lambda sensors, EEC boxes, and catalytic converters, and sensors that sense coolant temperature (one of the parameters/inputs to the EEC that adjusts the fuel mixture. Bad coolant sensor will also mean an enriched fuel mixture because the engine still thinks its cold! You might want to research a good Toyota maintenance manual and see what all is in the EEC circuit and proceed from there. From your posts I think you are throwing away an awful lot of good money by troubleshooting your problem with knowing what any of the specifics are. Than can get very expensive.
  19. Jan 16, 2015 at 8:29 AM
    adrstout
    adrstout Well-Known Member
    Adam
    Indiana
    '12 4cyl SR5 4x4
    2.5" lift, 265/75r16 Cooper AT3, All Pro Front Skid, KBVoodoo bed rack, a bunch of other random stuff
    I'm getting shit mileage now too. But, winter gas + lots of idle time + mostly very short (5-10 min) trips = shit mileage lol.
    This weekend I was planning on doing most of what was mentioned above and change diff oil also. Most items can be done pretty easily. Search for write ups to save $.
