Polyurethane bushing grease
Discussion in 'Long Travel Suspension' started by airkewled, Apr 8, 2022.
  1. Apr 8, 2022 at 5:37 PM
    airkewled
    airkewled [OP] Well-Known Member
    Kevin
    Moab
    2006 Tacoma DCSB
    Most polyurathane bushing kits come with install grease which is silicon based, generally with PTFE (teflon) additive.
    Suspension.com did a comparison on greases for poly bushings.
    There's only a few silicon based + PTFE that I can find (most tested by the above comparison):
    You can pretty much easily find the mini single use packs and small tubs in all of those which are totally fine for assembly but only a few of grease gun tube size that you'd need to keep lubing them up on the regular. From what I can tell, the grease gun size (14oz) tubes are about 50 dollars :spending:
    So for those with grease zerks on your bushings what are you using? :hattip: Is 50$ just a normal part of the LT tax or ? :notsure:
  2. Apr 8, 2022 at 5:38 PM
    OmahTako
    OmahTako Well-Known Member
    SoCal
    Tacoma-1ea. Tundra-1ea.
    Prothane:thumbsup:
  3. Apr 8, 2022 at 5:40 PM
    airkewled
    Kevin
    Moab
    2006 Tacoma DCSB
    Copy that. I guess I've just got a little bit of sticker shock going on. Was *not* expecting a tube of grease, even high faloot'in stuff to be 50 bucks.
    Wile_E_RedDog likes this.
  4. Apr 8, 2022 at 5:47 PM
    OmahTako
    SoCal
    Probably last a lifetime though because you're not gonna be using it all that much.
  5. Apr 8, 2022 at 5:53 PM
    airkewled
    Kevin
    Moab
    2006 Tacoma DCSB
    That's fair. Guess I'll bite the bullet. Thanks for the advice.
    OmahTako[QUOTED] likes this.
  6. Apr 8, 2022 at 10:46 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  7. Apr 8, 2022 at 10:47 PM
    FloTaco
    FloTaco Well-Known Member
    Bay Area, CA
    2021 SR DC 4X4
    Superlube
    airkewled[OP] likes this.
  8. Apr 9, 2022 at 5:58 AM
    airkewled
    Kevin
    Moab
    2006 Tacoma DCSB
    Yeah, I’ve got one of those little tubs for assembly, it might be worth it to see if I can put it in a mini gun or something.
    Not in salt really but I do live in Moab so there’s no malls to flex at :D
  9. Apr 9, 2022 at 6:10 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    It’ll be interesting to see if you get some squeaking prior to the time where swapping uniballs and / or bushings requires full prep anyway. Unless you’re always in water crossings, wet conditions, or salt (which you just said you weren’t on that one), I wonder if dust will ever penetrate the bushings or the bushings will deflect enough to wipe away the grease from one spot.
  10. Apr 9, 2022 at 6:25 AM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    Sorry, but I have to...
    These greases are Silicone based. Silicon is an element and in it's elemental state is a solid rock like material. Silicone (Organic Silicone, in this case) is a long chain flexible polymer. Yes, Silicone is Silicon based, but the greases are Silicone based.
  11. Apr 11, 2022 at 6:32 PM
    bundegr
    bundegr Active Member
    Grant
    2002 Tacoma Double Cab Pre-Runner
    Extensive... 4WD, Roll Cage, TRD Supercharger, Full long travel
    I had to re-read that a cople times to see what you were talking about :)
    Tacorific[QUOTED] likes this.
