PO412 Air System Switching Valve Circuit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danarello, Sep 30, 2023.
  1. Sep 30, 2023 at 9:09 AM
    danarello
    danarello [OP] Member
    Dan
    San Diego, CA
    2007 White Tacoma 4cyl 2.7L 2D
    Last week the Check Engine Light came on so I checked for trouble codes with my scan tool and got the PO412 code. I erased the code and a week later it came back on. According to my research, the Fix is: 1) Air injector pump and 2) Oxygen Sensor.
    Questions:
    1) How can I check the Air Injection Pump with my multimeter?
    2) Where is the Oxygen Sensor located and is there more than one?
  2. Sep 30, 2023 at 10:22 AM
    BlueT@com@4×4
    BlueT@com@4×4 Well-Known Member
    2015 TRD PRO Tacoma
    To check air pump usually when you turn on the engine when is cold usually you will hear pump noise running by open the hood, the other way by take it out the pump and hot wire it from battery.
    For 02 sensor is it bank 1 or bank 2?
    danarello[OP] likes this.
  3. Sep 30, 2023 at 6:55 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    That code is a circuit code for the Secondary Air Injection Switching Valve, it means either the wiring between the Air Injection Control Driver module and Switching Valve is open or shorted or the valve itself is open or shorted. It has nothing to do with the pump nor the AFR or O2 sensors.
  4. Jan 9, 2024 at 8:56 AM
    danarello
    Dan
    San Diego, CA
    Update: I replaced the air switching valve (also called purge valve?) that is bolted to the top of the intake manifold and has 1 electrical connector and 2 hoses. I used an OEM part from Toyota. I cleared the code and the Check Engine Light hasn't come back on yet.
  5. Jan 9, 2024 at 6:53 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The Air Switching Valve and Purge Valve are not the same thing, the Purge Valve is part of the EVAP system and the Air Switching Valve is part of the Secondary Air Injection System.
    Anyway glad you got rid of your CEL.
    danarello[QUOTED][OP] likes this.
