PO305 Cylinder 5 - misfire (solved)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gyrkin, Aug 18, 2022.
  1. Aug 19, 2022 at 2:30 PM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    Probably be better off taking everything related off and cleaning checking gap Apply grease. Running a leak down and compression check.
    MadNachos likes this.
  2. Aug 19, 2022 at 2:35 PM
    Gyrkin
    Gyrkin [OP] Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    Yea, I agree. My thought is maybe it's simply bad gas. I don't think they sell much premium at that station. It could be old or contaminated. Saying that, bad gas would probably not be causing a misfire on Cylinder 5 only.
  3. Aug 19, 2022 at 2:53 PM
    Smokestacks
    BayArea
    Any chance you put to much antiseize on the spark plug? I may have done that once and it definitely caused misfires.
  4. Aug 19, 2022 at 4:13 PM
    Gyrkin
    Wyoming
    Nope. Didn't put any on, so I can guarantee it's not too much.
  5. Aug 19, 2022 at 4:24 PM
    Gyrkin
    Wyoming
  6. Aug 19, 2022 at 5:03 PM
    Smokestacks
    BayArea
  7. Aug 19, 2022 at 6:07 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Ethanol won't fix anything. Ever. Unless you have an engine built to run alcohol it is always going to be garbage fuel. A mix is OK (but still sucks) but I would not go out of my way to run alcohol. Nothing in these engines likes it.
    ArizonaBrian and Smokestacks like this.
  8. Aug 21, 2022 at 1:31 PM
    Gyrkin
    Wyoming
    Got a test kit and it shows no exhaust gas in the coolant system. Had a little trouble getting the test done, kept getting coolant into the tester. Finally figured out it was getting sucked out of the overflow reservoir. Disconnected the overflow and plugged the hose. Then it worked, and I didn't get any coolant in the tester.
    Test fluid stayed blue. :bananadance:
    Smokestacks likes this.
  9. Aug 21, 2022 at 2:26 PM
    ArizonaBrian
    ArizonaBrian Well-Known Member
    I use an old turkey baster and pull some of the fluid out before doing the test. Then just pour it back in the overflow when you're done.
  10. Aug 21, 2022 at 3:07 PM
    Smokestacks
    BayArea
  11. Aug 21, 2022 at 5:45 PM
    Gyrkin
    Wyoming
    No, I did not check the spark plug wires for two reasons. First they are only a year or two old. Second, and more imortantly cylinder 5 is on the side with the coil pack. Spark to that cylinder does not flow through a wire. The wires just take spark from the cylindes on the passengers side over to the cylinders on the drivers side.
    Thanks for the links. I am thinking it must be injectors. I will try cleaning them first. Also after I clean them I will swap them around. That way if I still have a misfire related to a bad inkector it would follow to the new cylinder and verify that is the problem.
    Smokestacks[QUOTED] likes this.
  12. Aug 22, 2022 at 3:57 PM
    MadNachos
    Get them professionally cleaned and flowed so you have a matched set. I have used witchhunter.com for decades, dude does great work.
  13. Aug 23, 2022 at 7:57 AM
    Gyrkin
    Wyoming
    Thanks for the suggestion, but my truck is a daily driver. It would be a major hassle for me to be without it for the time it would take my injectors to do a round trip through snail mail. I'm going to tear into it today and clean them myself. I will make sure the one on cylinder 5 goes back in a different cylinder. That way if I still have a misfire only on cylinder 5 I know it's someting else.
  14. Aug 23, 2022 at 12:26 PM
    Gyrkin
    Wyoming
    Success! It's not fixed, but I now know exactly where the problem is. I cleaned the injectors on the passengers side. The misfire was in cylinder 5 so that is the main one I wanted to get to, and the ones on the drivers side are a little harder to get to. After cleaning, I put the one that came out of cylinder 5 on cylinder 3. I still have a misfire, but now it's in cylinder 3. Problem found, bad injector.
    Now to get a new set of injectors ordered. I have read that you don't want to change just one, plus they are originals so they have over 200,000 miles on them. It runs good enough to get me where I need to go while waiting for the new injectors.
  15. Aug 24, 2022 at 6:49 AM
    #35
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    If you haven't ordered them yet, you may want to consider using rebuilt injectors. If so, try MotorWest in Canoga Park, CA. Phone = 747 888 9768. You'll save a bunch of money and they do an excellent job of cleaning. replacing seals, and testing before shipping anything out.
  16. Aug 24, 2022 at 7:24 AM
    #36
    Gyrkin
    Wyoming
    I ordered them yesterday. I did get them from MotorWest. I got these https://motorwestperformance.com/product/upgrade-for-23250-62040/
  17. Aug 30, 2022 at 9:20 AM
    #37
    Gyrkin
    Wyoming
    Update: Put the injectors in two days ago. Runs great, and no more misfire codes.
  18. Sep 3, 2022 at 9:21 PM
    #38
    MadNachos
    Awesome! I would suggest buying a used but flowed and tested set to replace yours since you really cant completely clean them at home. It is amazing what a matched set of injectors will do for an old engine. Well worth the expense and frankly it isn't too expensive. Especially when you are trying to get a few more MPG out of a couple decades old engine.
