plug on bottom of coolant overflow/recovery tank
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ubnpast, Jan 25, 2015.
  1. Jan 25, 2015 at 12:56 PM
    ubnpast
    ubnpast [OP] Well-Known Member
    Central Jersey
    Just picked up an 05 Tacoma and noticed this on the bottom of the coolant overflow recovery tank. Looks like a hose with hose clamp is on the bottom nipple. Is this normal?
  2. Jan 25, 2015 at 12:59 PM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Not sure but looks like the drain for the tank
  3. Jan 25, 2015 at 1:16 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Normal but rusty.
    Did you take a good look at the frame good before buying?
  4. Jan 25, 2015 at 1:18 PM
    ubnpast
    Central Jersey
    Frame was pretty rusty, talked to toyota, from what I was told a New frame is coming my way :). Looks moist around the plug, do they tend to need replacement or leak?
  5. Jan 25, 2015 at 2:15 PM
    fixnfly
    S.W.PA
    I noticed that too..
    I would replace that rusty clamp, it may have lost tension. And if that does not work, replace the plug.
    If the tank was filled recently it could be from spillage that ran down.
