Plug n Play Rock Light Harness with Courtesy Mode By DSIM Solutions
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by DSIM, Feb 24, 2021.
  1. Feb 24, 2021 at 8:55 AM
    DSIM
    DSIM [OP] Well-Known Member
    Daniel
    Raleigh, NC
    2017 MGM Tacoma TRD Off-Road
    Base Relay Harness
    This fully Plug N Play Rock Light Harness will save you a ton of time if you want to add rock lights to your 3rd gen taco. All of the guess-work is taken out as the Harness is cut to length and has 8 total leads to wire up 8 lights underneath your rig (compatible with short bed and long bed Tacomas).
    To top it off this kit has an included T-Harness that plugs into your OEM Bed-Light Switch that brings courtesy mode to your lights. This will activate the lights whenever your cab light is on. This eliminates the need for a switch.
    **Lights are NOT INCLUDED in this kit. Leaving you the freedom to select any brand/style you would like.
    ** Note: RGB lights that are controlled with a controller will likely not be compatible with this harness. Here is a link to the lights on Amazon we would recommend LINK.
    Rock lights are controlled via Cab Light Switch.
    Cab Switch OFF & Door CLOSED = Rock Lights OFF & Cab Light OFF
    Cab Switch OFF & Door OPEN = Rock Lights OFF & Cab Light OFF
    Cab Switch DOOR & Door CLOSED = Rock Lights OFF & Cab Light OFF
    Cab Switch DOOR & Door OPEN = Rock Lights ON & Cab Light ON
    Cab Switch ON & Door CLOSED = Rock Lights ON & Cab Light ON
    Cab Switch ON & Door OPEN = Rock Lights ON & Cab Light ON
    **For independent rock light control please see the added compatible switch harness. This will allow for rock light activation via a separate CH4x4 Style Switch. When the rock lights are activated the cab lights will not turn on.
    Cost: $150 + Shipping
    Link to website: 3rd Gen Tacoma Plug N Play Rock Light Harness – DSIM Solutions
    Base Relay Harness with added Switch Harness
    This is a fully plug n play add-on to the 3rd Gen Tacoma rock light harness that allows for independent control of your rock lights. When the lights are activated via CH4x4 style switch the cab lights will not turn on.
    The relay module included converts the positive trigger from the switch to a negative to trigger the relay. The green plug on this harness connects directly to a CH4x4 style switch. Making it fully plug n play!
    **Switch and Lights NOT INCLUDED. Rock light harness Sold Separately.
    CH4x4 Style Switch OFF
    CH4x4 Style Switch ON
    Cab Switch OFF & Door CLOSED = Rock Lights ON & Cab Light OFF
    Cab Switch OFF & Door OPEN = Rock Lights ON & Cab Light OFF
    Cab Switch DOOR & Door CLOSED = Rock Lights ON & Cab Light OFF
    Target Cost: $25 Adder on top of $150 for Base Harness ($175) + Shipping
    Link to website: 3rd Gen Tacoma Independant Switch Kit Add-On – DSIM Solutions
    Base Relay Harness with added SwitchPro Harness
    This fully plug n play add-on allows for independant rock light control from a switchpros setup.
    The loose orange wire gets pinned to existing DSIM Rock Light Harness 4-Pin JST Connector, opposite end is the positive trigger for switchpros or similar setup.
    **Further Detail for how to pin the loose wire into base harness coming soon.
    ** SwitchPros and Lights NOT INCLUDED.
    Link to website: 3rd Gen Tacoma SwitchPros Add-On – DSIM Solutions
    **This mod works off of the cab light switch. If you do not have a cab light switch in your trim of 3rd Gen Tacoma then this mod will not work for you... yet.
  2. Feb 24, 2021 at 8:56 AM
    DSIM
    Daniel
    Raleigh, NC
    Install Instructions
  3. Feb 24, 2021 at 8:56 AM
    DSIM
    Daniel
    Raleigh, NC
    Reserved x2
  4. Feb 24, 2021 at 8:56 AM
    DSIM
    Daniel
    Raleigh, NC
    Reserved x3**
  5. Feb 24, 2021 at 10:26 AM
    Erikerowley
    Erikerowley Well-Known Member
    Erik
    2017 Toyota Tacoma TRD OR
    Following
    DSIM[OP] likes this.
  6. Feb 24, 2021 at 12:16 PM
    fake4x4
    fake4x4 Well-Known Member
    Los Angeles, California
    3rd Gen Tacoma TRD Off-Road DCSB
    Cool stuff
    wanting to see how this plays out
  7. Feb 24, 2021 at 1:57 PM
    fake4x4
    Cool stuff
    would like to use this for a BED Light
  8. Feb 24, 2021 at 2:00 PM
    DSIM
    Daniel
    Raleigh, NC
    Would be easy enough to tap off of one of the leads and send a pair of wires to the bed for that purpose. Good idea, that may be a future adder.
    Would just need to make sure you plug the other leads if you don't run the rock lights as well.
  9. Feb 24, 2021 at 2:03 PM
    fake4x4
    Cool stuff
    i would prefer something to plug in ... i hate tapping anything other than ....
  10. Feb 24, 2021 at 2:07 PM
    DSIM
    Daniel
    Raleigh, NC
    lol to the end statement. But it would be a simple "splitter" no tapping the wires. Can split off of the spade connectors.
    I'll look into this, I could definitely have a PNP harness with or without a pressure switch offered for this purpose at some point if demand is enough.
  11. Feb 24, 2021 at 2:07 PM
    Ruminator
    Ruminator Chairman of the Bored
    Mark
    Northern Illinois, USA
    2017 Red TRD-Sport, ACLB, MT!!!
    Alright doll-face, c'mon and bore me!
    I'm confused. Isn't this the bed light?
    ...and isn't the cab (dome) light switch up in the roof console.
    2017 TRD-Sport - no bed light, no such switch as pictured :(
  12. Feb 24, 2021 at 2:16 PM
    DSIM
    Daniel
    Raleigh, NC
    This harness works off of the cab light switch. Both the cab light switch and the a-pillar have the courtesy ground wire for courtesy mode. The cab light is easier to tap off of as it is not a PWM signal. This harness will only work if you have a cab light switch.
    The other product I have (DomeRock V4) is tapping off of the courtesy wire to the dome light. That one is a PWM signal though so their is some circuitry on board to cancel that out. That is what you would need if you do not have the cab light switch, however no full harness available. And also requires the extra switch. I may try to tie them together at some point in the future.
    daveeasa likes this.
  13. Feb 24, 2021 at 2:22 PM
    patdeezy
    patdeezy Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
    This is awesome, looking forward to this PNP harness
  14. Feb 24, 2021 at 2:25 PM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    @DSIM great work! Also, a great price considering everything you have included. :thumbsup:
  15. Feb 24, 2021 at 2:26 PM
    caribe makaira
    Caribbean, Puerto Rico
    LuisLAN, STrooper and Grossomotto like this.
  16. Feb 24, 2021 at 2:28 PM
    Ruminator
    Mark
    I got hung up on the semantics. What you call a cab light, I call a bed light. It's attached to the cab but lights up the bed. Meh.
    Already have your DomeRock module. Wasn't able to work up enough ambition to mount the rock lights before winter hit.
  17. Feb 24, 2021 at 2:29 PM
    caribe makaira
    Cargo/Bed Lights circuit switch. The cab light IS a PWM signal controlled circuit.
    STrooper likes this.
  18. Feb 24, 2021 at 2:35 PM
    caribe makaira
  19. Feb 24, 2021 at 2:39 PM
    GI_Taco
    GI_Taco Well-Known Member
    Halann
    Maryland
    2019 Quicksand DCSB TRD OR MT
    This is great! Just have one question. What is the long term reliability those blade connectors, since they’ll be running under the truck?
  20. Feb 24, 2021 at 2:44 PM
    DSIM
    Daniel
    Raleigh, NC
    Yes correct. The cab light itself is PWM but the wire tapped at the switch is not.
