Plug gapping
Discussion in 'New Members' started by Clive, Feb 6, 2020.
  1. Feb 6, 2020 at 9:28 AM
    Clive
    Clive [OP] New Member
    Hi all,
    I'm a very old guy with a 1999 2.7 4WD. It has been a wonderful truck, much beloved. Now it will begin to start but misses so badly it won't stay running longer than three or four seconds. It feels like it is firing on but one cylinder. Following advice found on this forum, I ordered four Denso Iridium TT Spark Plug 4701 and new NGK Wireset 4441 plug wires. I haven't received the wires yet and haven't replaced but one plug.
    The electrodes in these new plugs are different from any I've encountered before, being much pointier. The gap in the new ones from the box was consistently .036. My manual indicates the gap should be .031. The plugs I removed (same pointier electrodes) were gapped greater than .040. My question is: does the manual tell me .031 because they assume ordinary electrodes and I should have left them as they came from the box - or was I right to reduce the gaps to .031? I thought maybe Denso gapped them just in between the 4Cyl specs (.031) and the 6 Cyl ones (.043).
    Any recommendations? Thanks so much for any help.
    Clive
    buckhuntin-tacoma and lynyrd3 like this.
  2. Feb 6, 2020 at 9:31 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    A gap specification is a specification. Set it to your truck.
    Plugs may come gapped consistently but that doesn't mean they are correct for your application.
  3. Feb 6, 2020 at 9:34 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard
    buckhuntin-tacoma likes this.
  4. Feb 6, 2020 at 9:35 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    From one old guy to another. I stick with the OEM plugs.
  5. Feb 6, 2020 at 9:39 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Welcome to TW :hattip:
  6. Feb 6, 2020 at 9:40 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    the 6cly doesn't use iridium plugs so they wouldn't be gapped to 6 cyl specs, either way plugs are never really gapped consistently
  7. Feb 6, 2020 at 10:41 AM
    Clive
    Thanks for the welcomes you guys, and thanks for the time and thought.
    Mine is FOUR cylinders, 2.7L. (The engine sticker reads E3Rz-N73; my manual says it would be "3RZ-FE")
    It seems the OEM's are "traditional" electrode types and the gap specifications (.031") would refer to that type of electrodes. Does anyone know if the specified gap for the ones I got (Denso Iridium TT Spark Plug 4701) would be larger than the manual specifies?
    I could be negating the effect of the later-model, more expensive plugs, by setting the gap incorrectly.
    Thanks again so much,
    C
  8. Feb 6, 2020 at 10:44 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  9. Feb 6, 2020 at 10:46 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Be careful gapping iridium plugs. They have a narrow fragile electrode.
  10. Feb 6, 2020 at 10:54 AM
    Merlin88
    Merlin88 $8.95 large hawaiian
    Southern Oregon
    2017 Silver SR5 V6 4x4 DCSB AT
    SSO Slimline Hybrid Bumper Smittybilt X2O 10k Wireless Winch N-Fab Rock Rails w/Removable Steps Fab Fours Premium Rear Bumper RCI Engine Steel Skid RCI Transfer Case Steel Skid RCI Transmission Steel Skid RCI Crossmember Steel Skid RCI Fuel Tank Steel Skid Pop & Lock Auto Tailgate Lock Decked Short Bed Storage System ARB OME BP-51 2” Lift Kit with ARB OME BP-51 w/adj res coil overs ARB OME BP-51 w/adj res rear shock ARB OME Differential Drop Kit SPC UCA’s w/adj Ball Joints OME Dakar Heavy Duty Leaf Packs BFG AT KO2 T/A 285/70/17 tires Ultra’s Maverick 235 17x8 wheels Full Size Matched Spare Thule TracOne Ladder Rack Toyota Matte Black Grille Smoked Amber Raptor Grille Lights Matte Black Emblems Toyota Chrome Exhaust Tip-blackout Bed Rug Tailgate Mat Optima Red Top 35 Weather Tech Side Vent Shades Weather Tech Laser Fit Floor Mats CoverKing Neosupreme Seat Covers Sabellco Tailgate Lock RedLine Quick Hood Lift Elite Subaru Tweeter’s JDMCAR liners Cupeez Scratch Protectors
    Welcome!
  11. Feb 7, 2020 at 5:28 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW! You always need to check the gapping in plugs.
  12. Feb 7, 2020 at 8:20 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Welcome to TW! I would have to agree...stick with OME parts and always check the gap before installing. Wondering if there are other issues in play here...
    Do you have access to a OBD2 scanner and if so....did it provide a fault code? if so what was the code....
    Good Luck and keep us all posted...we will try to help as much as we can....
