Plug and play seat heaters?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Offroadr, Nov 9, 2020.
  1. Nov 9, 2020 at 10:30 PM
    Offroadr
    Offroadr [OP] Well-Known Member
    Considering buy clazzio leather seat covers and wanted to see if anyone knows of a company that makes a plug and play set up for seat heaters?
    Reason behind wanting plug and play is that I don’t want to splice into any electrical wires or harnesses on my 2020.
  2. Nov 9, 2020 at 10:40 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I installed professionally for 15 years, only kits I ever seen or installed that were “plug and play” were Mopar kits. Basically they T harnessed into the 12v lighter socket. Can’t fully remember but might of also had to run a wire to the fuse box or battery. Everything else involves splicing. You could always make your own customer harness but you’d have to plan it all out and get connectors made. Nothing wrong with splicing if you know what you’re doing and do it right.
  3. Nov 9, 2020 at 10:42 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I’m trying to sort it out too. Some chatter here. Also some talk of the seat heater relay in the Oem bed light thread but I don’t think I’ve stumbled on anyone successfully adding the relay and finding a convenient connector. One of the biggest questions is which switches to use. The Oem dual zone climate panel isn’t usable on a truck with manual climate controls and that’s also where the Oem heater buttons are.
  4. Nov 9, 2020 at 10:48 PM
    JJD92
    JJD92 Well-Known Member
    JORGE
    Springfield, MA
    2020 TRD OR DCSB
  5. Nov 9, 2020 at 10:56 PM
    JJD92
    JORGE
    Springfield, MA
    2020 TRD OR DCSB
  6. Nov 10, 2020 at 6:23 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I just installed mine (more details in the above thread) without splicing any factory wires. Power and illumination comes from the trailer brake controller plug. I did have to use an add a fuse to a switched ignition source so the heaters only work when the ignition is on.
  7. Nov 10, 2020 at 10:50 AM
    Offroadr
    Thanks for the info.... I need to install a brake controller in my truck at some time so that may not be an option for me to add the heaters to the circuit
  8. Nov 10, 2020 at 11:12 AM
    RX1cobra
    19 OR
    Think you can still follow pretty much my install with separate fuse panel. Just grab power right from battery instead of from trailer brake. Or add a fuse to an empty slot. Pretty sure there are open ones in heated seat and sunroof.
  9. Nov 10, 2020 at 12:36 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    if you use an add a circuit you don't have to splice any factory wiring
