"Plug and play" compact sub for stock headunit
Discussion in 'Audio & Video' started by Bobcat Luke, Feb 21, 2020.
  1. Feb 21, 2020 at 10:15 AM
    Bobcat Luke
    Bobcat Luke [OP] IT
    Austin, TX
    2020 Cement TRD Sport DCSB
    Wasup guys, I'm looking to improve the sound of my 2020 taco. I don't want to break the bank and I don't want to lose steering wheel functionality or replace my headunit.
    I'm not an audiophile by any means but I ordered the subaru tweeters and I'm looking for a little more bass. In an older thread on simple subwoofer installs one member was using the Kenwood KSC-SW11 (compact). There also seems to be a newer compact kenwood, the Kenwood KSC-PSW8. What do y'all think of these two options? Are there better choices for the money? Any recommendations? Which would be better between the two?
    Kenwood-SW11
    https://www.amazon.com/Kenwood-KSC-SW11-Compact-Enclosed-Subwoofer/dp/B00BO8O9XQ
    Kenwood-PSW8
    https://www.amazon.com/Kenwood-KSC-...1?keywords=kenwood-psw8&qid=1582308889&sr=8-1
  2. Feb 21, 2020 at 12:05 PM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
  3. Feb 21, 2020 at 12:10 PM
    Zac of all trades
    Zac
    fwpfab.com
    couple other options
    JL Audio
    https://www.crutchfield.com/S-aGtAm...0F5pXIbFTVqfQH7IKPn43bFbsMj0pxsYaAs65EALw_wcB
    in the 90s Cerwin Vega was a good brand
    https://www.amazon.com/CERWIN-VEGA-...a-784806208057&psc=1&ref=&adgrpid=69534739896
    MTX has always been good to me. Ran their amp on a solo baric L5 for 10 years flawlessly
    https://www.crutchfield.com/S-W0SmY...XNWb-DgvsjWt_SfiT77EjCpeuMAvLg3oaAl7VEALw_wcB
    If you can spend the money go with JL audio, if you are trying to save some money but want something good i would go with the MTX
  4. Feb 21, 2020 at 2:59 PM
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    Out of the one's you listed above, it seems like the Cerwin Vega will be the best in terms of specs. 200W RMS and a 10" driver. I'm currently running one of the earlier Inifinty basslinks and the bass is just fine for a small package. It is a bit bulky and doesn't really "fit" anywhere well in a 4-door Tacoma. It is a 200W RMS with a 10" driver so I'm assuming the CV version will be the closest match to it. All others you listed above seem to be a bit lower spec in terms of power/driver. Sound about right?
  5. Feb 21, 2020 at 4:34 PM
    tacovagon
    tacovagon Well-Known Member
    Dan
    Oceanside CA
    2016 SW SR5 DCLB 4x4
    ARB Locker 5100s w OME 887s OME EL095R Camburg BJ UCAs
    I have the Kicker Hideaway and it performs adequately for my tastes. I had it installed under the drivers seat and like the extra thump it provides that way.
  6. Feb 21, 2020 at 8:13 PM
    CLVol1255
    CLVol1255 Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    I have an infinity basslink sm 8” under my driver seat and I love it.. nice tight bass and quality sound but nothing over the top. Definite improves sound in stock system. 125rms. I’d recommend it to anybody. I got mine on Amazon for $170. Crutchfield has it for $300. I also have a JL audio lg10w3v3 and it’s awesome imo I’m very impressed with it but it has to go behind the rear seat
  7. Feb 23, 2020 at 9:58 AM
    Thatnoobguy
    Thatnoobguy Well-Known Member
    Somewhere
    2020 Tacoma trd off road with “premium” audio :|
    12 in sub for actual bass
    Have an image dynamics 12 in laying around, trying to pair an amp to it
  8. Oct 19, 2022 at 5:28 AM
    TacoSince2017
    TacoSince2017 Active Member
    What are the connectors on the end of the wiring covered in plastic? What type of connectors do I need coming from the stereo wiring and tap a fuze to connect them all? Thanks
  9. Oct 19, 2022 at 8:48 AM
    poopshute
    Colorado
    I'm not entirely certain what your specific question is but this is basically how the connections work if you're using one of these all-in-one subs. If you're talking about the plastic connections that come with the kit, those go directly into the amp/sub unit. The other end will be open leads that will tie into your line in. See below for more details. If you're using a separate sub and amp setup, there's a few more connections from the amp to the sub. However, for the sake of this thread and as it's talking about all-in-ones, here it goes:
    1. Ensure you're using the proper gauge power cable that the instructions state. Over-gauging (smaller number) future-proofs your power source wire. Lower number means thicker cable. Connect the power cable directly to the positive terminal on your battery. Then, make sure the fuse is connected as close to the battery terminal as possible w/out being and the way and by allowing it to be mounted safely under the hood. You NEVER want to fuse the power cable further down the line closer to the sub even if it's more convenient. Think of it this way, the line from the battery terminal to the fuse will be unprotected meaning it can burn up if there's a situation. The line after the fuse is protected and will not burn up as the fuse will burn out first. If you're fusing further down the line (in the cab for example), you'll have A LOT more line that can catch fire.
    2. If you're using your stock head unit, you'll need to tap into your speaker outputs to provide a line input into your subs low pass filter. There are harnesses available from places like ********* that are plug-n-play so you don't have to cut wires or splice into your speaker wires (https://*********.com/shop/toyota-t...re-harnesses/plug-play-add-subwoofer-harness/)... ok, apparently this vendor is banned here. The vendor is taco tunes but all one word. You run these cables to the sub's amp line-in. This is what provides the sound signal to your amp's low pass filter which will then take only the low-level sound and outputs it to the sub.
    3. Some of these all-in one's come with a sub level knob since our stock units don't have this built in. This knob uses a data cable and simply plugs into the knob that can be mounted near your instrument panel and the other connects to the all-in-one unit.
    4. Lastly, you need to ground the amp. Running a cable from the engine bay all the way back to your sub/amp box doesn't make sense and is way more work than necessary. You simply need to find a bolt or something that is attached to the body or frame of your truck and then tap the ground wire to that bolt and the other end goes to the ground on your amp/sub. I used one of my passenger side seat mounting bolts for this.
    That's the nutshell of how to wire your sub. If you are unsure of any of this, please contact a professional. As getting some of the wires mixed up like the line in wires won't really cause you an issue, messing up the power and ground cables can cause safety issues. You need to makes sure the power cable is protected, physically, by using wire looms while it travels under the hood. Usually when you route the power line into the cab, the cables own housing is ample enough to keep it safe as long as you have the cables hidden under the carpet and race ways. You will need to punch through your firewall from the engine bay to your cab but luckily there are a few grommets that can provide you the access.
