Plexiglass cleaner
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Newtacoma19, Feb 18, 2020.
  1. Feb 18, 2020 at 3:56 PM
    Newtacoma19
    Newtacoma19 [OP] Well-Known Member
    SSM utility 19
    I recently smeared turtle wax inside outside protectant on the outside of my ARE MX plexiglass windows. Any advice to remove the smear streaks?
  2. Feb 18, 2020 at 3:58 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    IPA should remove everything, including your protectant. Clean up then reapply.
  3. Feb 18, 2020 at 4:01 PM
    nathanroyse
    nathanroyse Well-Known Member
    Nate
    2019 Tacoma TRD-Offroad 4x4
    Bilstein 5100 w/ OME 887 Springs Bilstein 5160s TRD Pro Grille Method NVs w/ Falken Wildpeaks 265/75/16
    Be careful using IPA near painted parts of your truck though, if not used/diluted correctly it will remove paint. Also, I would be careful using it on plastic too.
  4. Feb 18, 2020 at 4:08 PM
    Newtacoma19
    SSM utility 19
    IPA? Have a name or a picture to better know what I’m lookin for. Any other safer options, that aren’t so dangerous for the plastic and paint?
  5. Feb 18, 2020 at 4:10 PM
    nat103
    nat103 Well-Known Member
    KY
    2017 DCSB OR
    Isopropyl alcohol
  6. Feb 18, 2020 at 4:11 PM
    nathanroyse
    Nate
    have you tried windex? its got some alcohol in it. might do the trick.
  7. Feb 18, 2020 at 4:12 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Plastic polish
  8. Feb 18, 2020 at 4:12 PM
    Newtacoma19
    SSM utility 19
    I did yes... all it did was add to smearing
  9. Feb 18, 2020 at 4:13 PM
    Newtacoma19
    SSM utility 19
    Any brands you’d recommend?
    US Marine[QUOTED] likes this.
  10. Feb 18, 2020 at 4:13 PM
    06ltd
    06ltd Well-Known Member
    Maryland
    2019 TRD OR 6MT
    Been using this stuff on airplanes and motorcycles for over a decade.
    Newtacoma19[OP] and Toms 17 like this.
  11. Feb 18, 2020 at 4:15 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Meguiars plastix cleaner polish
  12. Feb 18, 2020 at 4:22 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Lemon pledge works very well
    nathanroyse and Newtacoma19[OP] like this.
  13. Feb 18, 2020 at 4:30 PM
    Toms 17
    Toms 17 Well-Known Mumbler
    Tom
    Central Ohio
    17 MGM DCSB TRD Sport
    Second on the Plexus. Best I ever used on motorcycle acrylic windscreens.
    Newtacoma19[OP] and 06ltd like this.
  14. Feb 18, 2020 at 4:36 PM
    Drangus
    Drangus Active Member
    Rochester, NY
    '15 Tacoma SR V6 4x4
    Definitely don't use Windex or any glass cleaner with ammonia— it can damage the surface. Soap and water is the safest place to start. IPA is okay in small areas but not good near machined edges. I use Novus or Brillianize on acrylic and polycarbonate for cleaning and hand polishing.
    Newtacoma19[OP] likes this.
  15. Feb 18, 2020 at 5:42 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    I had to ask myself why are people using IPA beer to clean lexan.
  16. Feb 18, 2020 at 5:56 PM
    Newtacoma19
    SSM utility 19
    Thank you all for the great information. I’ll give soap and water a go then I’ll give this plexus a go
