Please Recommend a Waterproof Cargo Bag for Truck Bed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rhythmking, Jan 18, 2024.
  1. Jan 18, 2024 at 12:05 PM
    Rhythmking
    Rhythmking [OP] Member
    2023 Tacoma TRD Sport
    OK so it's pretty clear that, even with the tonneau cover, the bed of my 2023 Tacoma Sport isn't exactly waterproof. I was on Amazon last night looking at cargo bags (much like and including rooftop cargo bags) that would fit in the truck bed with the tonneau cover closed. This limited the height of the bag to 17+ inches. So the overall dimensions were like 50" x 40" x 17". The bags available in that size had some pretty shitty reviews, and I'm looking for some decent quality -and- waterproof. I'm also toying with the notion of maybe using something smaller to give me more versatility when I'm not hauling all my stuff to the summer house.
    Thoughts? Suggestions? Thanks.
  2. Jan 18, 2024 at 12:11 PM
    Toyotas4Tots
    Toyotas4Tots Well-Known Member
    NC
    2023 Tacoma SR5
    Not sure what the use is going to be, but I’ve been using the Milwaukee Packout totes/boxes for a couple years for grab and go tools and misc stuff that I wanted to be sure would stay dry under the tonneau of my F150
    GarlicFarts likes this.
  3. Jan 18, 2024 at 12:12 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    vivid02 likes this.
  4. Jan 18, 2024 at 12:17 PM
    eurowner
    eurowner Duke Sky
    Scoty
    These Thule bags are really nice, I am not the seller,
    https://www.ebay.com/itm/195372697216?chn=ps
  5. Jan 18, 2024 at 12:17 PM
    Rhythmking
    I'll be filling the back with luggage, bedding, groceries, etc. This is my first truck so I never had to contend with the idea of this stuff getting wet. I guess I could simply buy a box of heavy-duty contractor bags as well!
  6. Jan 18, 2024 at 12:19 PM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
  7. Jan 18, 2024 at 12:27 PM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    Check out a local motorcycle store that sells apparel and accessories. You can check out RevZilla or a similar place that sells dry bags. I wouldn't go over 60L or 80L as the bags are quite big and will get heavy AF. The difference in price is usually the quality of materials and abrasion resistance - you probably don't need a motorcycle dry bag that is high end and can survive a high or low side slide; this is just to give you an idea of what is out there.
    Edit: it is hard to size these things just looking at pictures. A 60 or 80 liter bag is about as big as those giant, multi day Osprey packs you find in outdoor stores. Depending on what you want to carry, several 40L bags or a couple of 60 or 80L bags should be fine.
  8. Jan 18, 2024 at 12:30 PM
    Rhythmking
  9. Jan 18, 2024 at 12:32 PM
    Rhythmking
    Thanks Mic I'll check those out...
    mic_sierra[QUOTED] likes this.
  10. Jan 18, 2024 at 12:37 PM
    GarlicFarts
    Lil Rhody
    As advertised, no.
    Depends what your needs are though. If you have a tonneau, they'll keep water away from whatever is in them in the bed.
    https://www.hatchmag.com/articles/one-wader-bag-rule-them-all/7715502
    Has worked for me. And for 5 bucks for the zipper bags, a buck for the open top bags....Worth a shot :notsure:
    Essayons and tacoma_ca like this.
  11. Jan 18, 2024 at 12:48 PM
    17taconut
    17taconut Well-Known Member
    Dave
    Baltimore, MD
    2017 Quicksand Tacoma Off-Road DCSB
    You could possibly look into outdoor stores, such as REI. I recently picked up one of the Plano storage boxes (smaller one) from Home Depot for less than $20. Good luck
  12. Jan 18, 2024 at 1:31 PM
    stocko taco
    stocko taco Well-Known Member
    Az
    19 Nissan Armada
    Honda Accord OBS Chevy
    I would look into sealing the front section of the bed interior with silicone. Then tailgate with weatherstripping. This is a common issue with truck bed toppers aswell and you will find similar solutions for your tonneau.
    ESI Ultimate Tailgate Seal with Taper Seal 6ft for Either The Sidewalls or The Tailgate Bottom https://www.amazon.com/dp/B019QFCZ7A
    I currently use a hitch cargo bags for my SUV with no water intrusion. Ive had good luck with both bag brands.
    MARKSIGN 100% Waterproof Hitch Carrier Cargo Bag 59'' x 24'' x 24'' (20 Cu Ft), Waterproof Zipper and Rain Flap, 6 Lashing Straps with Cam Buckles, Zipper Lock Included https://www.amazon.com/dp/B07MLZQF27
    Mockins XL 25 Cu Ft Hitch Cargo Carrier Bag - 59.5x 30.5x23.5 | Abrasion Resistant Waterproof Cargo Bag
    https://www.walmart.com/ip/362428070
    If you dont have a bed mat i would highly recommend the tacoma bed mat.
    A bed net divider may also work for your application.
    Amiss Heavy Duty Mesh Cargo Net, 3 Pocket Trunk Bed Storage Organizer Compatible for SUV, Car, Pickup Truck Bed, Etc.with 4 Metal Hooks (11.8×11.8×47.3 Inch), Black https://www.amazon.com/dp/B09VP9R6RW
    Best of luck
    Benny blanco likes this.
  13. Jan 18, 2024 at 1:37 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Not sure why your cover doesn’t keep out the water. The only moisture I get are the holes by the tailgate
  14. Jan 18, 2024 at 1:49 PM
    Junn
    Junn Member
    Gen3 White Tacoma TRD-OR
    I had a similar issue OP, a tonneau cover is not really waterproof as water still gets into the bed. I had considered bigger and smaller cargo bags. Instead, the solution that worked the best for me was plastic storage containers, kind of like the Sterilite 12-gallon plastic storage totes or Rubbermaid ones.
    These containers are inexpensive, the bottom is waterproof (since they will not be submerged or get rained on), will fit under the tonneau cover, and can sit side by side in the bed along the cab. I generally keep a couple of empty ones in the bed of my truck for day-to-day stuff. I can dump power tools inside, wood scraps, groceries (so they don't slide around), winter gear, etc. When I go camping I will switch out these empty totes with the similar totes with recovery gear and camping gear already pre-packed (saves me time to pack and unpack each trip). I couple the totes with a ratcheting cargo bar to prevent the empty totes from sliding out of reach, toward the cab-end of the bed.
    Since you have a tonneau cover, all you need are containers that are waterproof on the bottom. As I age, I have less and less desire to carry big containers loaded with things around. And having separate totes, I can organize my truck bed a bit better. Unfortunately, these totes do not have strap-down points. But since I have a rubber bed mat, when loaded, they don't slide around anyway.
    So far, I have used these totes for over 6 years and I have been pretty satisfied with them. There are more robust containers and other totes that are a better fit inside the truck bed dimensions, I am able to get all the totes I need for the truck and for storing my gear in my garage for less than the cost of a single tote from Roam, Pelican, etc.
    https://www.amazon.com/Sterilite-Stackable-Container-organizer-Organization/dp/B0CNTWNWJZ?crid=1G2IOI4UX4RTO&dib=eyJ2IjoiMSJ9.wWqZa8aqIHQks0lpSJ9eSog6SOrhdXhBDtuRAnnLHWoqY03rgKUs6axL-JGqQ0ImD3fCURk2uc5HdPpB9YBeQubwobNEiTkn1pSfjj8VU9WCkLLJj8cg_5Ictf5WYDR_NwQBHZ98Qnt3hAulGAYZdnzMDIKy8_ZXZnHzX1HZLoc0ZMNjhJ7LIl-MyY3JPlHGohYY6_EL1dCa1NA3Q2LWfqtmhCuFfraJl74RgMBjnMl9ZRP_P8hazWL_6QllU2Txn6ltOCmOBffx32GaQncnEYEPhXmjPqE9YwVjckOFsiU.t3j67Ktu7-UwEorvbFLSJX45wQ235uStjywx5WA2IEw&dib_tag=se&keywords=plastic+storage+bins+with+lids&qid=1705613164&sprefix=plastic+storage+bins+with+lid%2Caps%2C190&sr=8-11-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9tdGY&th=1
  15. Jan 18, 2024 at 2:33 PM
    ricco333
    ricco333 Active Member
    Erik
    2021 White SR5/4x4
    I have the Plano sportsman, got it at Amazon and sealed it with weather stripping, I throw all kinds of tools and straps in there along with my DeWalt lug nuts wrench and everything stays dry.
    mic_sierra likes this.
  16. Jan 18, 2024 at 2:44 PM
    jsnow77
    jsnow77 Well-Known Member
    Jake
    New Hampshire
    2022 Limited Nightshade
    Can confirm this is a solid route to go, as my cheap bin has served me perfectly and no leaks at all through snow and ice on top. If OP wants a fancier solution here a thread with a nice Pelican box with mounting and locking if that is more your taste but a cheap bin will go a long ways. https://www.tacomaworld.com/threads...its-with-retrax-tonneau.727786/#post-28315452 I love my cheap bin.
    ricco333 likes this.
  17. Jan 18, 2024 at 2:57 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Kanga large waterproof bag. I have one and it is good.
  18. Jan 18, 2024 at 3:00 PM
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2021 Tacoma TRD Off Road, 2019 Sahara
    Same for me. The bed stays pretty much dry. No water in the back even after the heavy rains we just had.
  19. Jan 18, 2024 at 3:25 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Tote bins for the win
    RIX TUX likes this.
  20. Jan 18, 2024 at 3:32 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
