Please recommend a good tow strap for me
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skiergd011013, Nov 10, 2015.
  1. Nov 10, 2015 at 8:57 AM
    skiergd011013
    skiergd011013 [OP] Well-Known Member
    2010 TRD Offroad 4x4 AC SSM
    What is a good tow strap that i can carry in my truck for pulling out others/being pulled myself. Through the little reading ive done on here i see that hooks are frowned upon, and the good straps are the ones that "stretch". Is a budget of around $100.00 doable?
    DrFunker likes this.
  2. Nov 10, 2015 at 8:59 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
  3. Nov 10, 2015 at 9:00 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I have an ARB and a Bubba Rope. Both are great, but the ARB one OZ linked will be in your price range.
  4. Nov 10, 2015 at 9:05 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
  5. Nov 10, 2015 at 9:09 AM
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    you can get pretty good stuff down at you local auto dealer, I go to Canadian tire. They sell 10,000 lb ropes that I have seen do lots of pulling for about 20 bucks. Maybe not the best quality but they always do the trick. They have longer, shorter, heavier whatever you need.
  6. Nov 10, 2015 at 9:09 AM
    skiergd011013
    Thanks. How do you secure that snatch strap to the front tow hook, or the rear. I have nothing in my receiver.
  7. Nov 10, 2015 at 9:11 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    It's possible to overthink this. When used as intended, a recovery strap is subject to wear and friction. You don't want to spend so much on a strap that you're reluctant to throw it away and replace it when it's worn.
    With that in mind, the inexpensive straps from e.g. smittybilt are just fine for the job.
    For our trucks, you want a 2" 20,000 lb strap rather than a 3" 30,000 lb strap. You want it to stretch.
    http://www.4wd.com/Jeep-Winches-Jee...TBrpmothH9y3r3mC-uIChDHbwQxOHxhHI8aAk9m8P8HAQ
  8. Nov 10, 2015 at 9:14 AM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    20+ feet of 3/4" braided rope and learn hit to tie a bowline knot. Essentially a loop that you can adjust the size of.
  9. Nov 10, 2015 at 9:15 AM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
  10. Nov 10, 2015 at 9:16 AM
    geekhouse23
  11. Nov 10, 2015 at 9:17 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    For the strap, these are great in price and really good quality that do more that get the job done. I recommend the 4" x 30' priced at $59
    They are really beefy
    http://www.uscargocontrol.com/Towin...ow-Straps/Recovery-Straps-W-Cordura-Eyes-4x30
  12. Nov 10, 2015 at 9:18 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  13. Nov 10, 2015 at 9:29 AM
    OZ-T
    Peter North
    British Columbia
  14. Nov 10, 2015 at 9:35 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    quick and easy. Just the way I like it
    ramonortiz55 likes this.
  15. Nov 10, 2015 at 9:37 AM
    OZ-T
    Peter North
    British Columbia
    I meant on the looped / clevis style , not your hook
  16. Nov 10, 2015 at 9:43 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    yea I've used it before, the hook is much easier IMO. Sometimes after a good recovery pull the clevis pin on the D-ring tightens up and is a bitch to loosen up
