Please help! Taco is spitting codes.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by neebs11, Dec 14, 2023.
  1. Dec 14, 2023 at 9:02 PM
    neebs11
    neebs11 [OP] Member
    2018 cement grey TRD sport long bed
    - Black tail gate letters - Soft tonneau cover
    For starters I’ve searched several post and found nothing that matched my errors.
    2018 TRD sport with 77K miles. I was driving to visit family in Miami (from Tampa area) and my check engine light came on mid trip. Once I arrived to my Destination I stopped at auto zone and found out my truck spit this codes.
    P0171
    P0174
    P1170
    I proceed to clean my MAF and K&N and removed negative battery cable. … When I started the truck the next day the code was clear and truck seemed to be running fine.
    I drove back to auto zone to buy fuel injector cleaner and then went to gas station to top off tank. When I pulled up to the pump the check engine came back on. After I topped off my tank and got back into my truck it wouldn’t start. It turned over quite well but wouldn’t fire up.
    I had the truck towed to my grandmothers house and let it sit for about 3 hours as I did research and at dinner. I went back out to the truck and it started it up.
    Though it was a rough start up and it had a bumpy idle for a moment and then evened out after about 20 seconds. I let it run for a few minutes, killed the engine and fired it back up. On the second start up it fired up smooth.
    Since I am 350 miles from home, and have limited resources I am trying to find the most effective solutions and way to handle this.
    I Am between a bad Crankshaft position sensor or a bad fuel injector. I may go buy the crankshaft position sensor as it’s a super easy fix and hope for the best. As I was suppose to be heading home Friday morning by 10am. All input, advice, and suggestions would be much appreciated.
  2. Dec 14, 2023 at 9:07 PM
    Bishop84
    Bishop84 Well-Known Member
    Crank sensor is nearly impossible to change at home. It's under the AC compressor wedged in behind a bracket. It would have nothing to do with fuel trim.
    You need to diagnose it rather than throw parts at it. At the very least you need a scan tool with live data to monitor fuel trim %'s.
    It's more likely fuel delivery, and you'll need to check pressure.
  3. Dec 14, 2023 at 9:24 PM
    kevinRR
    kevinRR Well-Known Member
    Milwaukee, WI
    2022 Toyota 4Runner
  4. Dec 14, 2023 at 10:42 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    The lean codes indicate a fuel issue - this is not a crankshaft sensor issue. It is also not a single fuel injector issue as the truck would run with a bad injector. Did you get the fuel pump replaced under the dealer recall? These are symptoms (no start/hard start) of a dying low pressure fuel pump.
  5. Dec 14, 2023 at 10:44 PM
    SEVtaco
    SEVtaco Well-Known Member
    Orange County
    2021 Tacoma TRD OR
    king2.5s/33s/Deaver/SCS wheels
    As Bishop stated you will need to monitor fuel trims, a basic scan tool that allows you to monitor live data, and a freeze frame data when the code set is also important. Don't start throwing parts at it.
    Chew likes this.
  6. Dec 14, 2023 at 11:52 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
  7. Dec 15, 2023 at 12:44 AM
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    i'm not saying i had the same problem long ago on another car or even my fix might work for you...but it might be worth a try...easy things first.
    i was getting very poor running/mileage and O2 sensors were complaining and fuel trims were off and had too lean codes. i forget all the details (10yrs ago).
    everyone was convinced i had a manifold leak, which was common for that car.
    i tried a home made smoker looking for the leak but found none but forum experts were convinced...and from what i had been reading for years on the forum it sounded right. i even bought the gaskets (and plugs while i was in there) and was ready to go.
    i looked at data logging from an obdII dongle and some software on a laptop and came to conclusion i might have a stuck open injector which was compensated for by the ECU and eventually showing a lean condition. very counter intuitive. again apology not remembering the details but that was the gist of it. before pulling it all apart, i dumped a bottle of GOOD injector cleaner in the tank. not the $2/bottle stuff. i think it was CRC's best around $10/bottle on sale IIRC. that did it. i no longer have the car but the parts are sitting in the garage. :( learn from that. at least i did not do all that work for nothing.
    if you can keep it going and are going to try to get home, dump some GOOD cleaner in the tank and cross fingers. won't hurt it if an injector is not the problem.
    good luck.
    edit: this is probably what i used: https://www.amazon.com/CRC-05062-Premium-Injector-Cleaner/dp/B000CINVEM
    bulalo and Gfenza89 like this.
  8. Dec 15, 2023 at 4:25 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    K&N toss that in garbage. I can't tell you many have f'd up MAF's and throw codes.
    Toycoma2021 and Chew like this.
  9. Dec 15, 2023 at 6:18 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Limited resources?
    It's always cheaper to properly diagnose than to play swap-a-part. And you won't have the headache of not knowing what the next problem is' because you mucked something up along the way.
    Rock Lobster likes this.
  10. Dec 15, 2023 at 6:24 AM
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    Disconnect and plug the evap purge valve and see what happens. Extremely common to have them fail, and they can stick in any position. Open would essentially give you an vacuum leak, causing it to run lean.
  11. Dec 15, 2023 at 6:29 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Best of luck. You might try a post in the FL section, see if anyone nearby can loan a good scan tool to get you some live data
    https://www.tacomaworld.com/forums/florida.45/
    Chew likes this.
  12. Dec 15, 2023 at 8:26 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    There's always the tiny chance that it's the original battery doing funny things, but not sure about this condition.
