PLEASE HELP - No Turn Signals
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05PreRunner, Feb 22, 2008.
  1. Feb 22, 2008 at 5:41 PM
    05PreRunner
    05PreRunner [OP] "Living life in the FAST lane..."
    <-(714)-> SO-CAL
    TRD intake, JBA "shorty" headers, URD y-pipe
    Ok,so i today i decided to change out my front turn signals to new led ones... I guess they didn't work....So, i put on my original ones and now i have no turn signals on both the front and the rear!! I have no clue what to do next............
  2. Feb 22, 2008 at 5:49 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    did you check the fuselink to se if you may have accidentally grounded it out???
  3. Feb 22, 2008 at 5:54 PM
    05PreRunner
    <-(714)-> SO-CAL
    I'll go check it out right now. Thanks
  4. Feb 22, 2008 at 5:57 PM
    lawnrevenge
    lawnrevenge Well-Known Member
    Southern California
    08 regular cab 5-lug, automatic
    Careful, many times cheap LED replacement lights
    don't have an internal resistor and so they blow the fuse or blink really fast.
  5. Feb 22, 2008 at 6:05 PM
    05PreRunner
    <-(714)-> SO-CAL
    Yup, the fuse was blown............ I'm throwing out the leds! Thanks guys for the quick responses. I just replaced the fuse and everything works perfectly now.......... lol, and yeah those were some cheap leds that i got on e-bay. I thought i messed something up bigtime!
  6. Feb 22, 2008 at 6:51 PM
    Bubba-Jet
    Bubba-Jet Active Member
    Wyano PA.
    07 Tacoma SR5 TRD 4X4 Sport
    Removed Secondary Air Filter,Tacomaworld Sticker,Wade In-Channel wind deflectors,Fumoto 12mm.F103N Engine Oil Drain Valve,Home Cast Bed Tie-downs
    How many Amps were the LED's rated at? Power Rating spec ?
    Simple calculation : Power = Amps x Voltage
    Amps = Power / Voltage
    Voltage = Power / Amps
    You already know 1 constant of 12v.
  7. Feb 22, 2008 at 6:56 PM
    05PreRunner
    <-(714)-> SO-CAL
    It didn't say.... I never saw any specs/ratings. I just though they would work... Oh well, i learned my lesson........lol
  8. Feb 22, 2008 at 7:03 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    yeah, some of those LED lights need another module to regulate the voltage or current. not sure what they'll called though.
  9. Feb 22, 2008 at 7:09 PM
    05PreRunner
    <-(714)-> SO-CAL
    yeah.......i've heard of that, i think its called a LED Load Equalizer.
  10. Feb 23, 2008 at 12:14 AM
    lawnrevenge
    Southern California
  11. Feb 23, 2008 at 6:32 AM
    piercedtiger
    Jon
    Southern Tier, NY
    No, there's a plug n play harness or box that has the correct resistor(s) or flash regulator for the LED turn signal bulbs so they flash normal speed without cutting, splicing, or doing the math to figure out what you need. Most places that sell the LED replacement bulbs SHOULD have that thing (whatever it's called).
  12. Feb 23, 2008 at 8:02 AM
    lawnrevenge
    Southern California
    I know what you are talking about. I posted that link because a resistor can be bought for less than a buck and it's small, those adapters are somewhat bigger and cost several dollars. That's all you need to regulate flash etc. it just produces enough resistance so that the relay doesn't think the bulb is burnt out.
  13. Feb 23, 2008 at 3:49 PM
    Bubba-Jet
    Wyano PA.
    Some of the High End LEDS are High -Voltage low current.
