plan on moving to pennsylvania had a couple of questions?
Discussion in 'North East' started by pumo420, Oct 14, 2009.
  1. Oct 14, 2009 at 7:01 PM
    pumo420
    pumo420 [OP] Well-Known Member
    florida
    07 Prerunner Sr5 Debadged
    silver star headlights, optima yellow top battery, 2X10 mtx thunder 4500 speakers, kicker kx 400 amp, pioneer headunit, injen air intake, flowmaster dual exhaust, doug thorley long tube headers. waiting to put on urd maf caliberater, urd o2 senser, urd supercharger and 7th injector setup.i Fell
    im living in florida right now and i plan on moving to harrisburg, pa. i have 2006 prerrunner urd mark 1 supercharger doug thorley long tube headers catless y pipe flowmaster 50 series exhaust dumped behind the axle walboro 255 fuel pump. im wondering what i need to do do pass emissions or what kind of emission testing they have in harrisburg.
  2. Oct 14, 2009 at 7:02 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    My advice is to make friends with someone at a garage that does inspections. Well as long as you dont have any codes you might be alright depending how close they actually look at the pipes
  3. Oct 14, 2009 at 7:04 PM
    Foster9091
    Foster9091 Well-Known Member
    Upperco, MD
    01 Doublecab TRD
    deckplate mod, floor mats, hi lift, scanquage, and 2 in front leveling kit
    in pa they inspect your truck every 2 years fyi
  4. Oct 14, 2009 at 7:09 PM
    pumo420
    florida
    thats good to know, i installed the o2 simulater when i got the long tube headers, so that stopped the cel.
  5. Oct 14, 2009 at 7:24 PM
    98tacoma27
    Ben
    Not Beech Creek
    I don't think they do an actual emissions test unless you live in Philly or Pittsburgh. PA does it emissions based on per capita. My county doesn't do any testing other than visual presence of emission components. The county next to mine only does a gas cap check. Here is the State Code for emissions. I think you will be required to have a cat though.
    http://www.pacode.com/secure/data/067/chapter177/chap177toc.html
  6. Oct 14, 2009 at 10:34 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Depends on where you live.
    I live in Lancaster county and we get emmissions tested. Aside from the gas cap check & visual inspection, I'm pretty sure they hook up to the OBD port and run diagnostics.
    If you drive less than 5,000 miles per year, you're exempt from the emmissions test - although, they still do a visual check. You're exhaust system has to be intact with CAT and in good working order.
    Pumo420 - Welcome to PA!! I don't know about how Florida is, but PA tends to be strict about a lot of things (yearly inspections).
