Pioneer AVH-P4400BH Double Din
Discussion in 'Audio & Video' started by mne3312, Jun 20, 2012.
  1. Jun 20, 2012 at 7:36 PM
    mne3312
    mne3312 [OP] Well-Known Member
    Alabama
    '10 Prerunner SR5
    K&N Air Filter, Weather Tech Floor Mats, Weather Tech Deflectors, Truck Covers USA Roll Cover, 15% front 5% back Tint, Toyota Hitch Cover, Pop & Lock 8521, Pioneer 4400BH, Infinity 6-1/2" Speakers, 4-Channel Amplifier, Access Bed Mat
    I just ordered this Pioneer AVH-P4400BH head unit along with 629I and 609CS Infinity Kappa door speakers. I plan on installing myself. I would love to know where to pick up a silver textured metra double din kit? Also, if you guys have any tips, advice, or other threads on installing this unit that would be great. I would love for you to share some of that wisdom. It has been several years since I have ripped a truck apart. Thanks in advance!
  2. Jun 20, 2012 at 7:44 PM
    fubar718
    fubar718 Well-Known Member
    Jose
    NJ
    2010 double cab, TRD offroad
    about to start the same project
    bump
  3. Jun 20, 2012 at 7:48 PM
    deanbhula1
    deanbhula1 Well-Known Member
    I have 3 dash kits if u wanna work a deal for one...pm me. And I installed a pioneer avh p4200 in mine so if u have any questions I can probably help
  4. Jun 20, 2012 at 8:05 PM
    mne3312
    Alabama
    '10 Prerunner SR5
  5. Jun 21, 2012 at 6:05 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Various notes:
    • Google up Schosche Tacoma dash kit - Amazon, eBay, on-line elec sellers
    • Also want a wiring kit for the HU, keeps you from having to cut the factory connectors off.
    • Consider getting a Metra interface unit if you want to integrate the steering wheel controls into the HU.
    • Video bypass - if you want to view video while driving, google up Pioneer video bypass - you can go the cheap route and wire in a relay ($4 + wire/connectors), eBay has a micro-relay ($10) that is smaller and easier to fold into the space behind the HU, or a PAC TR-7 ($40) is a more expensive solution to a relay.
    • Speaker wiring - you need to decide if you are going to use the existing OEM speaker wires, or run your own. If you are just running off of HU power you don't really "need" new wires, but maybe you want them. If you use the factory wires there is also a wiring kit to plug into the stock door plugs vs tapping/cutting the stock plug.
    • iP*/USB cable - decide where you want the iP*/USB cable routed to and route that while everything is apart. Decide if you want iP* video as well as you need a Pioneer specific cable to route video to the HU. If you just want audio, a regular USB should work fine.
  6. Jun 21, 2012 at 6:40 AM
    mne3312
    Alabama
    '10 Prerunner SR5
    Lurkin...You are awesome! A "grocery list" (so to speak) of items to check off as I go is just what I was looking for. Your wisdom is much appreciated!
  7. Jun 21, 2012 at 7:18 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    NP, but please don't confuse "wisdom" with "experience" :p :p :p
  8. Jun 21, 2012 at 7:54 AM
    mne3312
    Alabama
    '10 Prerunner SR5
    Wisdom could be the common sense to apply experience and knowledge. So having both experience and knowledge leads to wisdom...or could wisdom be knowledge from experience? Ha-Ha Either way you have experience and knowledge and I appreciate that.
  9. Jun 21, 2012 at 8:01 AM
    mne3312
    Alabama
    '10 Prerunner SR5
    I'm going to need speaker wire to hook up the front component speakers and crossovers to the head unit. I will use the factory harness for the rear door speakers. Also on the grocery list is speaker adapters.
  10. Jun 21, 2012 at 8:10 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You don't "need" speaker wire for the components if you're running off of the HU power, you can still use the factory door wires. You'll only need to run new wires if you add an amp (even then "need" is a strong term).
    When you mentioned speaker adapters, are you talking about the wiring adapters, or the plates that adapt the speakers to the stock door mounts?
    I did forget to note the speaker adapter plates which you'll need to purchase or make.
  11. Jun 21, 2012 at 9:07 AM
    mne3312
    Alabama
    '10 Prerunner SR5
    I am not sure how to hook-up the crossovers (that come with the speakers) without running new wire from the HU? And yes, I am talking about the speaker adapter mounting brackets that adapt the speakers to the doors.
  12. Jun 21, 2012 at 9:21 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Just hook the stock wires to the crossover just like you would if you were connecting them to a speaker, then wire the woofer and tweeter to the crossover. Or run new wires...
  13. Jun 21, 2012 at 9:37 AM
    mne3312
    Alabama
    '10 Prerunner SR5
  14. Jun 21, 2012 at 9:49 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Looks like it'll work to me. Haven't done this one myself though.
  15. Jun 21, 2012 at 9:57 AM
    mne3312
    Alabama
    '10 Prerunner SR5
  16. Jun 21, 2012 at 10:24 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    The bypasses are all basically the same for the Pioneer line, at least for the 4200-4400 that I am familiar with, so buy on price and reviews. These do nothing more then pass the parking brake line to ground after a delay when power on is sensed.
    As for the iPhone cable I would ensure that Pioneer supports that cable for your iPhone for your model HU. They do have a habit of changing the supported hardware and the cables slightly. Easiest way is to buy what Pioneer recommends unless you find a reputable source that has used one of the others.
    I think that I have a CD-IU200V for my 4300 though.
  17. Jun 21, 2012 at 10:47 AM
    mne3312
    Alabama
    '10 Prerunner SR5
  18. Jun 21, 2012 at 10:55 AM
    mne3312
    Alabama
    '10 Prerunner SR5
  19. Jun 21, 2012 at 11:32 AM
    mne3312
    Alabama
    '10 Prerunner SR5
  20. Jun 21, 2012 at 11:37 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Might want to do some search on the Schosche vs. the Metra dash kit if you haven't already. The Metra uses the stock metal brackets, has a smooth finish, and the HU fits in at a bit of an angle. The schosche uses it's own plastic mounts, does fit in flat and matches the stock silver color and texture. I think that's right on the Metra, I have the Schosche so not experience talking on the Metra.
