Pioneer AVH-P3200/PAC-SWI-PS Programming
Discussion in 'Audio & Video' started by MX81, Aug 5, 2010.
  1. Aug 5, 2010 at 11:58 AM
    MX81
    MX81 [OP] Well-Known Member
    Dallas
    2014 TRD Offroad PreRunner
    Has anyone hear programmed their Pac-swi to a pioneer avh-p3200 ?
    I installed the HU last weekend with no issues but can't get the the pac to program. The unit seems to be recognizing my vehicle as it flashes 8 times when it is turned on.
    When I try to start programming volume up I would hold volume up until light went out, then would release and the light would not come back on. After 15 seconds the pac would the blink 11 times. I have checked all wiring, and I have the 150ohm resistor between pin 7 and pin 8. Any help would be greatly appreciated.
    Also the pac is version 1.6.8
  2. Aug 6, 2010 at 12:20 AM
    acozzens
    acozzens Well-Known Member
    98056 , washington state
    06 4d 4wd trd sr5 silver
    Michelin ltx m/s WSU (cougs) License Plate Holder $1.99 Gate Theft Mod DIY HU install DIY SWI-JACK install DIY rear speaker & baffle DIY ipod audio/video interface DIY HD radio DIY Alpine pdx 5 DIY front components install DIY RedLine Tuning Gas hood lift ( very slick ) DIY slimcubby gb hid head/fog DIY extang trifold trifecta DIY dynolock tailgate lock
    THOUGHTS:
    over 6k have used the swi-jack sticky in this A/V section of the forum, glance at that one more time ( if you haven't already )
    I monitor a lot of the questions, normally it is a connection problem. Double check your resistor, and once again check all your connections. If still whack, ensure you're setting the SWI device to the proper Head Unit setting, and take the manual to the bathroom. Sounds like you are "very close" Hope you complete it, cause it's worth it!
    AC
  3. Aug 6, 2010 at 1:28 PM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    As has been said, check all of your connections, but I had a similar problem and it was due to my hooking the SWI switch power line to a constant power source.
  4. Aug 6, 2010 at 2:31 PM
    MX81
    Dallas
    I have my powerline connected in with the power source to the HU..( red wire) Is that what you did ?
  5. Aug 7, 2010 at 5:09 AM
    dangerbird
    dangerbird Well-Known Member
    Tacoma SR5
    I have the AVH-P4200DVD. Initially I used crimp on connectors that made poor contact. So then I went back and took those off and wired them directly to the wire. That fixed all of my problems.
  6. Aug 9, 2010 at 5:52 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Again, check, but my HU has a connection for always-hot and switched. I mistakenly connected the SWI switched to the HU always-hot.
  7. Aug 9, 2010 at 4:45 PM
    kigi
    kigi Member
    Install and programmed a pacswi-ps version 1.68 this weekend with a avhp4200dvd
    My install sheet instructed to use the 560 ohm resistor. Not the 150 ohm.
    Also I had issue with programming the buttons after the install. What I did.
    1. Check all connections.
    2. Programmed with the audio jack from the pac not plugged into the head unit.
    3. Done
    Used this as a guide and the vehicle specific info from the pac audio site.
    http://www.tacomaworld.com/forum/audio-video/82320-hu-installation-links.html
