Pinkish color leak....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pster, Nov 29, 2009.
  1. Nov 29, 2009 at 5:27 AM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Hey guys and gals...I have been absent for the last several months as I prepare to close on my new mountain house tomorrow! I will have more than a few trips back and forth hauling stuff. I noticed today that there were small pinkish leaks of an oil type substance under the Tacoma. I don't have time to research threads, but I seem to recall reading something about this....is this transmission fluid? Is it serious? The leaks are small, quarter size drips.....
  2. Nov 29, 2009 at 5:48 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    It's coming from the front of the engine bay, so I am thinking it may be anti-freeze? Is the anti-freeze they use pink? I felt it with my finger and it wasn't water, felt like a very fine oil to me...didn't taste it......
  3. Nov 29, 2009 at 6:06 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Both the factory filled tranmission oil and coolant are pink. If its the coolant there might be a loose hose or you over filled it and it bubbled out (happened to me once) but you can check the level of the coolant and fill as needed till you can get it fixed but if its the tran. then i would be more concerned cause you can't check the level of the trans oil and you run the risk of over heating the trans. check under the truck and see if you can find any small holes that a rock could of done and around the oil pan for a broken gasket were the oil could be seeping out.
  4. Nov 29, 2009 at 6:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yep.....Sounds like the coolant. Does it have a "sweet" smell?
  5. Nov 29, 2009 at 7:50 AM
    fibertop
    fibertop Well-Known Member
    roger
    Ontario, Wasaga beach
    2010 sport DC
    could be tranny fluid coming from the tranny cooler behind the grill
  6. Nov 29, 2009 at 7:53 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sounds like a coolant leak to me.....as the toyota long life anti freeze is pink.
  7. Nov 29, 2009 at 9:52 AM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    x3 on coolant...toyotas coolant dries a light pink to help show any leaks...check your reservoir to see if you have any pink coolant left.
  8. Nov 29, 2009 at 11:13 AM
    fibertop
    roger
    2010 sport DC
    Let us know what it turns out to be. Since you said it feels like oil, I'm going with tranny fluid. Is your tranny automatic or manual?
  9. Nov 29, 2009 at 12:40 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Each time before moving your truck look underneath it. if the fluid presents itself again, look directly above to see where it came from. Hard to diagnose such things via the Internet.
  10. Dec 1, 2009 at 8:41 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Hey guys, just got back. CLosed on the house! After reading all the posts - THANKS - it sounds like coolant to me.....it does in fact dry a very light pink color.....I will let you know as soon as I verify.
  11. Dec 1, 2009 at 8:56 PM
    yosh2000
    CO
    '17 Tundra CM 5.7
    yep, this has coolant written all over it!!
  12. Dec 1, 2009 at 9:06 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    That's my guess until I can get under the truck and look around....been too busy lately. Curiously, it does not leak all the time. I have driven a lot of miles since I posted the issue and I look under the truck each morning and I don't see anything. I think it is sporadic...
  13. Dec 1, 2009 at 9:13 PM
    yosh2000
    CO
    '17 Tundra CM 5.7
    your baby just scabbed up and fixed the leak!! quit picking at it and it will no longer leak!!
  14. Dec 2, 2009 at 8:21 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i'll agree,or you chopped up a cat in your fan!:D
  15. Dec 2, 2009 at 8:31 AM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    I say taste it. If its sweet its antifreeze, if its not sweet its trans.
  16. Dec 2, 2009 at 9:02 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I'll try that.....thanks.
  17. Dec 2, 2009 at 9:04 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    A mountain home huh? Would that be near Asheville?
  18. Dec 2, 2009 at 9:10 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Black Mountain! 2 hours and 15 minutes from Charlotte.
  19. Dec 2, 2009 at 9:13 AM
    Afwrestler1986
    Johnstown, NY
    Ah yes, I know of where you speak. I lived in Marshall, NC for bout 8 years.
  20. Dec 2, 2009 at 9:20 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I just checked under the truck and no evidence of leak on garage floor. I drove for 3 hours last night. Very strange, it seems to be a sporadic event but this doesn't make sense to me.....there is definitely something leaking, why it is infrequent is baffling.
