Pinch weld mod extreme
Discussion in '1st Gen. Tacomas (1995-2004)' started by Logans2001, Oct 10, 2020.
  1. Oct 10, 2020 at 5:18 PM
    Logans2001
    Logans2001 [OP] What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    I’m looking to get some spacers because I’m rubbing my frame. I had some installed before but took them back off because I rubbed the cab. I also had wider mud tires on then. Now I have toyo ATs so I’m hoping I have a better chance now. I’ve already done the pinch weld mod but I’m still skeptical about them rubbing. Has anyone had better luck by hammering even more or even cutting? I’ve read that I should stay away from adjusting my alignment and camber/caster yada yada. I’m not gonna get new rims or tires to accommodate this so that’s out of the question. Thanks
  2. Oct 10, 2020 at 5:31 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    285/70/17
  3. Oct 10, 2020 at 5:38 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Who says to avoid adjusting your caster? That's the best way to clear larger tires. Pinch weld mod is usually necessary too but upping your caster to 3 or more degrees pushes the tire forward and helps clear.
    I used to rub the pinch weld bad even after cutting it, got my caster upped to 3.5° and cleared it easily.
    Without aftermarket UCAs though you probably won't get that much caster, fyi
  4. Oct 10, 2020 at 6:13 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    That’s good to hear. Luckily I have SPCs UCAs tho so I should be good?
    eon_blue[QUOTED] likes this.
  5. Oct 10, 2020 at 7:02 PM
    eon_blue
    Azusa, CA
    Yeah that's what I have too. You get some additional caster with those just from installing them, and an alignment shop should be able to adjust your lowers for additional caster to around 3 degrees.
    I wouldn't adjust the SPC ball joint unless it's needed
  6. Oct 10, 2020 at 11:40 PM
    Pj40
    Pj40 Well-Known Member
    Washington
    Gotta cut out your firewall, reweld in a filler plate and seal it on both sides if you dont want any rub on any of the inner fender. I run 285/75/17 with 0 offset and dont rub at full bump and full lock. I only have a 2 inch lift running these tires with no rub of course and no caster adjustments everything is stock angles
    Key-Rei likes this.
  7. Oct 11, 2020 at 3:16 PM
    Sreppep
    Sreppep Well-Known Member
    Philip
    Fort Worth, TX
    2001 SR5 4x4 V6 5spd 264k - 2005 T4R V8 4x4 139k
    5100/Toytec, F5s/w KO2 285s, ARB, 4x skids/sliders
    This looks extreme, I’ve not seen anyone go this far with the pinch weld and running 285s.
    Dalandser, tacomataco2 and BeLance89 like this.
  8. Oct 11, 2020 at 3:39 PM
    Pj40
    Washington
    They're 34.5 inch tall tires and 0 offset. I like being able to be at full bump/a little past and at full lock and never rub. Take out your strut jack the tire up under the control arm until that side is being lifted and I bet most people rub hard enough that they're wheel would not spin without serious damage. But I do actually do some stupid trails with my truck so I guess I'm not the majority of people who do forest roads or just relaxing trails. Dont get me wrong thoug I do those relaxing trails when I just want to get put as well.
    SR-71A likes this.
  9. Oct 11, 2020 at 3:56 PM
    Sreppep
    Philip
    Fort Worth, TX
    oh ok, so you’re running a 295/75/17?
  10. Oct 11, 2020 at 4:28 PM
    Pj40
    Washington
    No the cooper discoverer xlt measures in at 34.5 inches due to tread depth and load rating. At 38 psi its does measure to 34.5 inches. It's a 285/75/17 on a 7 inch rim so that also is helping that depth of sidewall stay upright.
  11. Oct 11, 2020 at 6:44 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Cut it out and tub it, or mess with the alignment as others have suggested. I tried to beat to fit 37s and it made my life a living hell when I eventually had to cut everything out to fit them.
    Pj40 likes this.
  12. Oct 12, 2020 at 7:39 AM
    mtnkid85
    mtnkid85 Well-Known Member
    MT
    1999 TRD Taco
    35s, Locked, blown
    When I was running 255/85/16 I was able to fit them just with some sledge hammer work, but after I went up to the 315s then I definitely needed to tub.
  13. Oct 18, 2020 at 1:16 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Got pictures of them installed?
  14. Oct 18, 2020 at 1:43 PM
    Pj40
    Washington
    My front struts are worn. I ordered king extended travel custom valved coilovers 15 weeks ago so the front end will come up about an inch to level it out
    rsm420 and Dalandser like this.
  15. Nov 7, 2020 at 9:28 AM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    So I plan on installing some spacers myself.. my question is, can I get away with just adjusting the caster on my SPC UCAs so my tires clear the cab without touching the LCA caster adjustment? If not, can I at least do that so I can drive to the shop to get the full alignment?
  16. Nov 7, 2020 at 9:30 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    A good alignment will help you get where you need to be before doing anything else.
    This was mentioned in the first reply last month.
  17. Nov 7, 2020 at 10:15 AM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    I think that was for a different question. I’m asking if it’s ok to adjust my SPCs myself for the sake of getting to the shop without rubbing badly So that the shop can do the LCAs too. Or do UCAs and LCAs absolutely need to be done at the SAME time?
  18. Nov 7, 2020 at 10:20 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You can, considering it'd cost you a lot less to do yourself (can only imagine what a shop would add for labor on that).
    Position C, would be my guess, to give that additional degree of caster.
    Others will chime in with better advice.
    @eon_blue
  19. Nov 7, 2020 at 10:35 AM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Sounds good to me. Maybe this’ll help.
