Pictures of your truck bed with battery and inverter setup please!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by scott0_1, Mar 1, 2022.
  1. Mar 1, 2022 at 3:26 PM
    scott0_1
    scott0_1 [OP] Well-Known Member
    Scott
    2017 DCLB TRD Sport
    I'm going to be installing a 100 ah lithium battery, a 700 W inverter and a solar controller in the back of my 2017 DCLB. I'm also going to put a half sleeping platform in it.
    Anyone have pictures of a similar setup (even without a platform)?
    Thanks!
  2. Mar 1, 2022 at 10:43 PM
    Farpolemiddle
    Farpolemiddle Well-Known Member
    2017 Tacoma TRD
  3. Mar 1, 2022 at 10:47 PM
    scott0_1
    Scott
    2017 DCLB TRD Sport
    I've already got all the components for my planned setup. More bang for your buck if you build it!
    I spent a lot of time looking at portable solar generators. Definitely a good option for quick and clean!
  4. Mar 2, 2022 at 12:43 AM
    evdog
    evdog Well-Known Member
    San Diego
    2019 DCLB TRD OR
    Here's my setup. 100Ah Renogy battery, Renogy DC-DC charger with MPPT controller (charges from both alternator and solar), and 1200W inverter. 2 x 100W Renogy solar panels up top. I'd go with 1200 or 1500W inverter. Soon as you buy 700W you'll want to plug something in that uses more : ).
    The fridge is flush with the cabinet top making for a stealth sleeping platform in case I'm somewhere I can't pop up the camper top. If it were my primary sleeping platform the fridge would go elsewhere and I'd make the sleeping surface low enough I could comfortably sit up and hang out without hitting my head.
  5. Mar 2, 2022 at 12:49 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    What type of fridge is that and model? I like how low and flush it sits. Mine sticks up pretty high over the shelf which is
    even with the back window and sides like yours.
  6. Mar 2, 2022 at 2:02 AM
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    Check out the following threads:
    https://www.tacomaworld.com/threads...eping-platform-drawer-storage-systems.424709/
    https://www.tacomaworld.com/threads/truck-camping-photo-thread.407866/
    https://www.tacomaworld.com/threads/car-camping-trip-reports-photos-buildouts-“overland”-expedition-rigs-area-homeless.220278/
    I have a 200w panel & a 100aH Li-Fe w/ self heating function. Panel is a little overkill but in northern NE w/ low light angle & inconsistent weather I wanted the confidence that I'd be able to offset use.
    (Ignore the actuator covers--dealer's choice and I'm replacing w/ custom ones)
    Initial electrical set up before connecting everything.
    Mounted the panel so I can angle for better efficiency.
    LN2022, wi_taco and Jtac15 like this.
  7. Mar 2, 2022 at 2:59 AM
    evdog
    San Diego
    2019 DCLB TRD OR
    It's a Dometic CFX 45. I have it mounted direct to the shelf rather than use sliders, which allows it to sit a bit lower. Those fridges have bolt holes underneath so you can direct mount them to a shelf like I did using M5 (I think) bolts.
