Picking a tow hitch?
Discussion in 'Towing' started by TacoTuesday1, Sep 10, 2021.
  1. Sep 10, 2021 at 10:22 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    Might need to pull a trailer soon.
    So I done lifted my shit. Fucked it up right?
    I have a hitch adapter from U-Haul. Walked in and the guy at the counter was like "WHAT YA NEED IS THIS ONE" 2 3/4" or some shit
    Stowed in the storage compartment, haven't used it since I last moved; had less lift back then.
    But sir it has x lift and x higher bumper
    "DONT MATTER"
    Well sir I fucking doubt it
    And on top of that now guess what
    I've got an even higher bumper, and higher lift (yeehaw)
    Look I get it. There's guides online. I will look at them. And potentially implement them.
    But I am asking y'all because:
    1. You are the 2ND GEN TACOMA EXPERTS
    2. Surely have also faced this dillemma
    but yeah, how do you figure out what adapter to stick in the hitch
    to pull a U-Haul trailer properly/level
    so that you don't have an adapter too short where the trailer hooks up tall and is all tilted upwards...
  2. Sep 10, 2021 at 10:30 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Could buy a nice adjustable hitch, but they are $$$.
    How high is your trucks hitch? Measure from inside bottom of hitch to ground.
  3. Sep 10, 2021 at 10:33 PM
    TacoTuesday1
    FL
    I'll measure and report back.
    Have seen those adjustable hitches but yeah if they're $$$ then it costs more than a one size
    the generic one at U-Haul they recommend for most trucks was only like $24
  4. Sep 11, 2021 at 11:50 AM
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    Use tape measure and measure heights. Crunch numbers and voa la!
    stonybrook and Lt. Dangle like this.
  5. Sep 11, 2021 at 1:18 PM
    Pigpen
    Northwest Montana
    I use a 3" or a 6" drop hitch, depending on which trailer I'm pulling. I have 3.5" lift in rear, heavy duty springs which don't sag much (if at all) under load. I also have air bags for the heavy stuff.
    If I needed to tow a UHAUL trailer, I am sure I would need the 6" drop to have it level.
  6. Sep 11, 2021 at 5:55 PM
    Meatballica
    Meatballica Member
    Observe the diagram for reference. I recently rented a 6x12 uhaul and found that their website says their stuff has about an 18" coupler height. Measure your receiver height as shown in the diagram above (ground to the top of the interior of the square). Mine is 19.5", So for me 19.5" - 18" = 1.5" drop. I used a 2" drop one I already had and sat just a hair low, so this method shows to be accurate. For you, make your measurement and then subtract 18. If you have to choose between the ball being 0.5" low or 0.5" high, go 0.5" high.
    rmreid20 and YF_Ryan like this.
