Permanently Adding Weight to Bed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by erok81, Jan 23, 2023.
  1. Jan 23, 2023 at 10:20 PM
    erok81
    erok81 [OP] Well-Known Member
    Imposter
    So I need to add 100-200 pounds to my bed. It’s not for winter traction and more to help out my rear springs that need more weight to function correctly.
    I thought about maybe bolting a couple 45# plates to the spare tire carrier but I’d be worried about 90# hanging off that thing and breaking off on the freeway or something.
    I don’t want to lose a bunch of bedspace using something like buckets of concrete or big water bags.
    Figure maybe some of you have been around trucks longer than I have and might have some ideas that I am not aware of.
    My only other idea might be adding a big ass piece of 1/2” steel across sole of the bottom of my bed cage. But I have no clue where to get that much steel, or how to get it into my bed.
    Here is what I am working with. So far I have my battery and a 37” spare.
  2. Jan 23, 2023 at 10:25 PM
    MGMDesertTaco
    :popcorn:
    Weld plates to the bedcage?
    HighCountryTacoma likes this.
  3. Jan 23, 2023 at 10:27 PM
    erok81
    Imposter
    I think I’d have to do two sheets of 1/4” since I doubt I’m going to be able to wrestle around 160 pounds by myself. :rofl:
    If I did plates they’d go on the bottom tubes and then they could be a little shelf/platform.
    MGMDesertTaco[QUOTED] likes this.
  4. Jan 23, 2023 at 10:31 PM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    Undercover Ridgelander tonneau cover weighs about 100lbs.
    erok81[OP] likes this.
  5. Jan 23, 2023 at 10:49 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Maybe weld some metal to that frame that you could use for something else? Even if doesn't get the full weight, then you can add bulk elsewhere to remove when you need to.
    No offense, but I can't imagine being worried about bed space with those mods, that is no grocery-gettir.
  6. Jan 23, 2023 at 10:53 PM
    evdog
    evdog Well-Known Member
    San Diego
    2019 DCLB TRD OR
    Make the wife and kids ride in the bed? :D
    RIX TUX, JJ Diablo, Bivouac and 3 others like this.
  7. Jan 23, 2023 at 10:54 PM
    erok81
    Imposter
    I was debating on a shell at some point but it’s going to be a lot of work to install it. I have fiberglass bedsides that won’t support the weight and have a slight curve. I have an idea how to do it along with the steel, just haven’t gotten around to it yet.
    AtomAnt and e6400ultra[QUOTED] like this.
  8. Jan 23, 2023 at 10:59 PM
    erok81
    Imposter
    I thought about putting the plates on the frame as well. Figured on the bed might be easier to get to.
    I only want the bed space for camping gear. Oh and for my shopping bags from Saks Fifth Ave of course.
    71tattooguy and Chew[QUOTED] like this.
  9. Jan 23, 2023 at 11:00 PM
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    Add additional framing to the existing tubes to extend to the tailgate, get some heavy duty drawer slides, and build a bedslide. With a reinforced 3/16 plate tray, you’re looking at around 100 lbs total
    J Williams and Chew like this.
  10. Jan 23, 2023 at 11:01 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    great idea!
    Not my truck, but I can't imagine adding that much dead weight, there's gotta be something useful that can be done.
  11. Jan 23, 2023 at 11:17 PM
    MGMDesertTaco
  12. Jan 23, 2023 at 11:18 PM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    Add a molle panel to the front of that Fram and add stuff you always take/need camping. Axe, shovel, bolt a propane tank in, traction boards, leveling blocks, etc. Little things add up.
    If it's in the budget, look at adding a roller door style cover to the frame for more weight and security.
    erok81[QUOTED][OP] likes this.
  13. Jan 23, 2023 at 11:28 PM
    erok81
    Imposter
    Ha. Front is already filled up. :cool:
    50Buck[QUOTED] likes this.
  14. Jan 23, 2023 at 11:30 PM
    erok81
    Imposter
  15. Jan 23, 2023 at 11:41 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Bolt some plate on top the wheel wells out of the way no lose of bed space .
    A few pieces to make the handling easier plus it puts the weight right over the springs
    Also great for winter traction . Easy to remove if the added cargo capacity is ever needed.
    just a thought.
  16. Jan 24, 2023 at 12:35 AM
    Bivouac
    Ha Ha Ha Wow that brings back Memories I forgot I made brackets and used a bar hung 700 pounds on the front end of a Truck i used for pulling.
  17. Jan 24, 2023 at 1:56 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Date a fat chick and tell her you keep Big Macs in the bed
    4xPaddler, t2c and Phlogiston like this.
  18. Jan 25, 2023 at 9:00 AM
    MulletTaco
    MulletTaco Wannabe prerunner
    Kevin
    Somewhere in AZ
    21 TRD Sport 4x4 DCLB
    Removed some stuff, added some stuff.
    You could always put 2 boxes at the tailgate with sandbags that way you can tune the weight and also play with placement.
  19. Jan 25, 2023 at 9:03 AM
    MulletTaco
    Kevin
    Somewhere in AZ
    How many feet of tubing did you have to order for that bed cage?
  20. Jan 25, 2023 at 9:08 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Quick, inexpensive and easy with a box cutter.
    Go to your local tractor/farm supply and buy a big section of horse stall mat. This is HEAVY ~3/4" thick rubber mat. Cut some large rectangles out that fit on the bed in between the cage and stack about 3 layers deep. That will probably get you in the 100-200lb range for like $50.
    They are unlikely to remove themselves on the road unless you crash and flip/roll.
    50Buck likes this.
