Performance/power mods
Discussion in '1st Gen. Tacomas (1995-2004)' started by Eloisking, Aug 13, 2023.
  1. Aug 13, 2023 at 11:22 AM
    Eloisking
    Eloisking [OP] Active Member
    Eduardo
    04 Tacoma TRD 4d
    Stock
    I get it Tacomas are slow af, but once you add armor and bigger wheels it gets even worse….. does anyone have any recommendations for performance mods that can boost the speed and acceleration of this little truck??? mom trying to stick with naturally aspiration at the moment so superchargers or turbos out of the question lol
  2. Aug 13, 2023 at 11:33 AM
    TacoDinner
    TacoDinner Well-Known Member
    Nitrous oxide :burnrubber:
  3. Aug 13, 2023 at 11:49 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    5.29 gears
    Taco critter likes this.
  4. Aug 13, 2023 at 12:08 PM
    ret42
    ret42 Well-Known Member
    VA
    Cement 2021 TRD OR 6MT
    LS Swap.
    redneck_adjacent likes this.
  5. Aug 14, 2023 at 12:05 PM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    Regearing is your only option to recover your lost power. Forced induction is just a band aid.
  6. Aug 14, 2023 at 12:18 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Simply take your favorite drill bit and starting at the front fenders working back, drill holes in every body panel (it’s called “cheese whizzing” the body, I believe. Weigh the removed metal and be proud of the performance gain. 98B6AF32-4F05-4DF6-8B30-AA93C6AED65E.jpg
    b_r_o likes this.
  7. Aug 14, 2023 at 12:29 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I did the TPP.
    Trailerpark Performance Package.
    1 - TRD pro accelerator on the intake. (Trd Pro intake is better). I wouldn't listen to the k&n cult followers and their cai advice.
    2 - Throttle body spacer (Possibly just an overpriced whistle but it isn't hurting anything so I left it on).
    3 - Pedal Commander (No power or speed gains but eliminates throttle lag).
    4 - Axle dump (eliminating 2 extra bends from the stock exhaust).
    but like the one guy said. There really isn't much more you can do.
    Keep the air, fuel and spark clean.
  8. Aug 14, 2023 at 12:57 PM
    redneck_adjacent
    redneck_adjacent Well-Known Member
    Bellevue, WA
    1997 Tacoma 2.7L 4x4 W59 MT
    5 PSI supercharger 3" lift Bilstein 5100 shocks Old Man Emu springs General Spring leaf springs with 2" blocks and extended shackles 31" Firestone Destination XT tires LCE header and catback exhaust HPS CAI Tundra S13WE front brakes KC HiLites flood, ditch, fog, and backup lights Eaton Bussmann relay/fuse panel with custom power tray All Pro bumpers, sliders, and skid plates
    I have not dyno'ed my truck so I can only give you anecdotes.
    Nevertheless, the following bolt-on, non-forced induction modifications and maintenance habits allowed me to increase speed while driving uphill (60-70 MPH) on the highway in fourth gear, as well as better throttle response and speedy acceleration, all relative to OEM:
    • 1 inch throttle body spacer
    • Frequently cleaned throttle body and MAF sensor
    • Frequently ultrasonically cleaned spark plugs and fuel injectors
    • Frequently ultrasonically cleaned or replaced PCV valve (plug) and grommet
    • Frequent oil changes with full synthetic Mobil1 5W-30 and K&N oil filter
    • FIPK cold air intake
    • Straight headers
    • Cat-back exhaust
    • Fiberglass header wrap with high-temperature silicone spray
    Some other things to try:
    • Ultrasonically cleaning throttle body
    • Porting throttle body (maxbore.com)
    • New fuel filter
  9. Aug 14, 2023 at 1:09 PM
    Scott W
    Scott W Well-Known Member
    Scott
    Saranac Lake, NY
    2018 Tacoma TRD PRO. Calvary Blue.
    TRD Performance Air Intake. TRD Shift Knob. KTJO 4X4 Red TRD Push Button Start/Stop. Calvary Blue FOBIK by AJT Design. 12volt Solutions Remote Start with CAR:LINK Smartphone Remote Start and GPS app. Sprint Booster V3 Throttle Response Enhancer. AFE Silver Bullet Throttle Body Spacer 46-38010. 2" Supreme Suspension Lift Kit. TOYO 265/75R16 Open Country A/T2. EGR Matte Black In-Channel Vent Visors. REK GEN Offroad Mud Guards. AMP RESEARCH Power Steps. JDMastar 10000lumes LED Low Beam Lighting T1. JD Mastar Raptor LED Lighting. TRUXEDO Tonneau Cover.
    bkhlrTaco's likes this.
  10. Aug 14, 2023 at 1:12 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Scott W[QUOTED] likes this.
  11. Aug 14, 2023 at 1:20 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    @Eloisking note that most of these posts aren’t applicable to your 1st gen
    Nano909 likes this.
  12. Aug 14, 2023 at 1:20 PM
    Nano909
    Xcab 3.4 4wd 5MT
    Wrong forum buddy. Go back to the turd gen group.
  13. Aug 14, 2023 at 1:49 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
  14. Aug 14, 2023 at 1:55 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Wouldn't quite go as far as "most".
    Do you have anything to offer OP or just troll and bash others who try?
  15. Aug 14, 2023 at 2:00 PM
    0xDEADBEEF
    Lol. Pointing out that people are posting things that don’t even apply to your truck is not trolling. I didn’t want him to waste time on a wild goose chase looking for parts that don’t exist.
  16. Aug 14, 2023 at 2:12 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I pointed out what I did. to the '16 it says above it.
    The only thing I posted that doesn't apply is the intake acc.
    You're only sending him on a wilder chase by vaguely saying most won't work. but look, man. I come here to learn and try to help where I can.
    Not argue.
    I'm Brian. Nice to meet ya.
    Steves104x4 likes this.
  17. Aug 14, 2023 at 2:15 PM
    redneck_adjacent
    Bellevue, WA
    I joined TW only today and don't want to get on anyone's bad side but it definitely seems awkward that someone would suggest third generation modifications in a first generation forum. More, it doesn't look to me like anyone is trolling you. People are simply saying that your input was inapposite.
  18. Aug 14, 2023 at 2:19 PM
    0xDEADBEEF
    You’re in the first generation section. OP is asking about a first gen truck, which is an entirely different animal. Trying to help is fine, but context is super important. I was trying to be as nice as I could by just pointing it out and going no further, but you still took issue with it.
  19. Aug 14, 2023 at 2:20 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Welcome!
    You're all good. I'm good. Hopefully 0x is good.
    I had a 1st gen for 15yrs. I 'm aware of the differences. like I said was only trying to help lead you in the right direction.
  20. Aug 14, 2023 at 2:21 PM
    Nano909
    Xcab 3.4 4wd 5MT
    Except you starting with leading him in the wrong direction :confused:
    Kwikvette likes this.
