performance chips
Discussion in '1st Gen. Tacomas (1995-2004)' started by Xmaster1738, Dec 20, 2021.
  1. Dec 20, 2021 at 7:41 PM
    Xmaster1738
    Xmaster1738 [OP] taco sauce
    98 Tacoma SR5
    train horn, extra lights, cargo rack, 3"lift, special lights for the holidays(temporary)
    so my 98 taco has started suffering mpg and power as of late and im not looking at replacing the motor quite yet, i want to push that thing till it blows, but i have heard chips can help with mpgs and slight power gains, a good freind of mine has recommended a chip he got for decently cheap, and his buddy also has the same deal, im just looking for any consolation on the topic as im not quite convinced yet that it helps at all.
    if it helps any, the chip he recomended was a pcr revamp chip, they go for about 60$ and he was quite happy with it, but im not sure hes not just getting a placebo effect
    unstpible likes this.
  2. Dec 20, 2021 at 8:54 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
  3. Dec 20, 2021 at 8:59 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    I just looked up PCR Revamp and that's quite a convincing scam they're running.... wow, just wow.
  4. Dec 20, 2021 at 9:02 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Save your money, give your high mileage engine some well deserved and proven TLC/tune up to help it along without wasting money on snake oil products.
  5. Dec 20, 2021 at 9:38 PM
    Xmaster1738
    98 Tacoma SR5
  6. Dec 20, 2021 at 9:39 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Yes, those actually work, just not for this truck of yours
  7. Dec 20, 2021 at 10:04 PM
    Xmaster1738
    98 Tacoma SR5
    oh shit man that makes me sad asf
  8. Dec 20, 2021 at 10:58 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    If you're really invested, there are options, but they're not cheap or easy.
    Start by skimming that thread I linked
  9. Dec 20, 2021 at 11:05 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    Snake oil. Do a compression test and leak down. Keep up with the maintenance. OEM parts only.
  10. Dec 21, 2021 at 6:54 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    PCR Revamp -hahahahahahahahahaha!!!
    2 wires hot glued to some cheap sort of circuit board material, with what looks like a resistor. The wires are not even attached to the 'electronics', just hot glued.
    $60??? Hahahahahahahahaha. This is bigger snake oil than the 'tornado' throttle body spacers of yesteryear.
    Abeyancer likes this.
  11. Dec 21, 2021 at 7:04 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I can always get a little mileage and performance boost on an old engine with over 150,000 miles with new Denso/OEM O2 sensors -- and -- new correct NGK or Denso plugs.
    I install the O2 sensors first to feel any performance/MPG gains and install the new plugs second. Clean the MAF and perform other often overlooked maintenance items.
    It's always surprising to see how well an engine performs when everything is in spec like it was when new.
  12. Dec 21, 2021 at 8:11 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    I found this site last night breaking down how these "performance" chips work.
    https://www.performancechipguide.co...p-iat-performance-chip-tuner-review-teardown/
    Even if it does provide more power to some makes/models, it seems like it would put your cats at risk of being fouled by running rich for extended periods. Auto engineers aren't stupid and OEMs spend millions trying to squeeze out every last HP/MPG. If there was an easy way to generate more power without consequences they would have already done it.
    CS_AR and Andy01DblCabTacoma like this.
  13. Dec 21, 2021 at 9:54 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    That's not entirely correct. There's usually a decent safety gap they leave - CIP: +50-60HP on my Golf with just a tune
  14. Dec 21, 2021 at 10:02 AM
    CrustyTaco
    Todd
    Louisville, KY
    I guess I don't understand why manufacturers would leave that much power on the table if there's no downsides. Seems like that would give them a competitive advantage if they could squeeze out that extra power without harming reliability or emissions.
  15. Dec 21, 2021 at 10:04 AM
    eon_blue
    Azusa, CA
    MPGs/emissions and meeting EPA requirements most likely
    Abeyancer and Bivouac like this.
  16. Dec 21, 2021 at 10:34 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    I just did the same thing, read through the testimonials, can't believe that many people actually bought into this and they received those kind of gains. I'd spend 60 bucks to get 60 hp if it really worked.
  17. Dec 21, 2021 at 10:35 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    I don't think they're real testimonials tbh
  18. Dec 21, 2021 at 10:45 AM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
  19. Dec 21, 2021 at 10:49 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    In the 90's for JDM cars it was a gentleman's agreement.
  20. Dec 21, 2021 at 10:51 AM
    treyus30
    Trey
    Mesa / AJ, AZ
