Performance brake pads?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VTCAL, Jun 9, 2023.
  1. Jun 9, 2023 at 10:47 PM
    VTCAL
    VTCAL [OP] Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    Are there any suggestions for front disc brake pads that offer real "BITE" with acceptable wear?
    Looking...
  2. Jun 9, 2023 at 11:01 PM
    mauctopa
    mauctopa Well-Known Member
    R1 concepts
    Rusty66 likes this.
  3. Jun 10, 2023 at 3:31 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Anything semi-metallic is going to bite really hard at any temp and have good wear. I have used R1 semi-metallic pads, they work good with not too much dust. The most aggressive pad I have used is Centric C-tek semi metalic. Very dusty but they literally will put you through the windshield.
    Don't be fooled by price. Semi metallic pads are very inexpensive compared to ceramics, this doesn't mean they are inferior.
    RustyGreen likes this.
  4. Jun 10, 2023 at 6:01 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Centric Fleet Performance 306.09760. Same as TRD Sport pads w/o the red paint and higher price.
  5. Jun 10, 2023 at 6:13 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I tried semi metallic pads in my 2001 tundra, and hated them. They were noisy till the pads got up to temp. The stock toyota ceramic pads gave me the best performance.
  6. Jun 10, 2023 at 7:07 AM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Powerstop pads/Centric rotors.
    Check out Tire Rack, you can even reach out to them and pick their brains about it.
    Bishop84 likes this.
  7. Jun 10, 2023 at 10:39 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  8. Jun 10, 2023 at 4:58 PM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    Age315 likes this.
  9. Jun 10, 2023 at 5:27 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Not sure if MAX brakes are in the US but they ship right to your door and offer cheap brakes, OEM brakes, and performance brakes. More importantly they come with a special coating to prevent corrosion & rust and to protect against moisture and salt.
    They're even on Amazon. I last used them on my CRV and they lasted a long time and weren't too dusty up front. I will use them again when they are due.
    https://www.amazon.ca/Rotors-Ceramic-Brakes-2007-2014-Cruiser/dp/B00IIWHIRK?qid=1686443215&s=automotive&sr=1-9&vehicle=2017-76-1037------------1&vehicleName=2017+Toyota+Tacoma&th=1
    More options here: https://maxbrakescanada.com
  10. Jun 10, 2023 at 6:23 PM
    RyanDCLB
    4/19 DCLBOR
    I'm sure the pads and the rotors are better :notsure:
    Here's the brake line kit sold separately.
  11. Jun 10, 2023 at 8:08 PM
    Herennow
    Herennow Well-Known Member
    2023 Lunar Rock Tacoma TRD 4X4 Sport V6
    Les Schwab Open Range A/T- Peragon LimitedHD Tonneau Cover- Teton Workshop Shift Knob - Vtails Taillight Conversion kit - Cali Raised LED's Catalytic Converter Shields- Rough Country bed mat- 9 piece LED interior light kit - HIGH FLYING Led Side Mirrors Sequential Dynamic Turn Signal Lights Indicator. -Diode Dynamics Elite Series Fog Lamps.
    Not been impressed with the brakes on this truck at all. Been trying to decide on an upgrade. Doesn't even have two grand on it yet.
    Just the pads here. I was thinking of trying pads. But the factory pads that came on my truck should be ceramic. So I haven't been sure it would make any difference.
    Pads might work for you though. $52
    https://www.amazon.com/dp/B009FRTR4Y/
    https://www.powerstop.com/product/power-stop-z36-brake-pads/#y=2022&mk=TOYOTA&mo=TACOMA
    Power Stop K137-36 Front Z36 Truck & Tow Brake Kit, Carbon Fiber Ceramic Brake Pads and Drilled/Slotted Brake Rotors $217
    https://www.amazon.com/dp/B005UB8X94/
    https://www.powerstop.com/product/power-stop-z36-brake-kit/
  12. Jun 10, 2023 at 9:26 PM
    VTCAL
    2021 Sport
    OK! Thanks for the info
  13. Jun 11, 2023 at 7:25 AM
    zoo truck
    None
    I had a set of EBC slotted and drilled rotors on my 2001 tundra for years. They were outstanding vs the original solid ones.
