pelican case 1620
Discussion in 'Buy / Sell / Trade - Other' started by lonniea, Feb 13, 2012.
Thread Status:
Not open for further replies.
  1. Feb 13, 2012 at 10:34 PM
    lonniea
    lonniea [OP] Well-Known Member
    Lonnie
    Monroe LA
    02 tacoma dc sr5
    add a leaf and uninstalled for rebuild fabtech coilover set at 3 inch foglight mod keyless entry deckplate soon leer shell
    new pelican case 1620 sales fo around 250 online want 150 and ship on your dime or trade for 1 gen toyota stuff pm me and let me know what you have
    This Pelican 1620 Black Case comes with Pelican unique Pick 'N Pluck foam. This foam is pre-cut which allows you to customize the interior by half inch cubes. Trace out the item you want in the case and simply pluck the foam out by hand, no tool required. You can customize your case in less than 15 minutes.
    Unbreakable, watertight, airtight, dustproof, chemical resistant and corrosion proof. These are some of the features of this Pelican Protector Case that offers total protection for your equipment. It is made of Ultra High Impact structural copolymer that makes it strong and durable. Its exclusive 1/4" (6.4 mm) neoprene o-ring and ABS latches seal perfectly and includes an automatic purge valve for quick equalization after changes in atmospheric pressure. It is equipped with 2" (5 cm) hard rubber transport wheels, a retractable extension handle and multiple fold down carrying handles. Your equipment can fit into the high density foam or padded dividers for total subjection and protection against impact, vibration or shock.
    This case is tested to MIL C-4150J (Military Standard), IP-67 (Ingress Protection) and ATA (Air Transportation Association). Unconditionally Guaranteed ... forever.
    Interior (l/w/d cm)
    21.48"54.5 x 16.42"41.7 x 12.54"31.8
    Exterior (l/w/d cm)
    24.64"62.6 x 19.39"49.2 x 13.78"35
    Dimensions
    Buoyancy Max
    149.91 lbs68 kg
    Range Temp
    -10 / 210 °F-23 / 99 °C
    Lid / Case Depth
    2.06"5.2 cm / 10.5"26.7 cm
    Weight
    26.01 lbs11.8 kg (with foam)
    24.47 lbs11.1 kg (w/o foam)
    Foam Set
    1621 1622
    Opt. Accessories
    1600IP Instapak Quick® RT
    Certificates
    IP67 MIL C-4150J Def Stan 81-41/STANAG 4280
    Special Features
    Wheels (2) Extendable
  2. Feb 13, 2012 at 10:39 PM
    iliketurtles
    iliketurtles Well-Known Member
    It sales for 250?!
  3. Feb 13, 2012 at 11:21 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
Thread Status:
