Pcv valve replacement interval?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Jun 30, 2023.
  1. Jun 30, 2023 at 6:48 PM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    How often are you guys changing out your pcv valves ? I have a 2023 tacoma 2gr-fks and doing my oil every 3k miles.
  2. Jun 30, 2023 at 6:54 PM
    Bishop84
    Bishop84 Well-Known Member
    They are lifetime, just remove it and clean it with carbclean/intake clean. Do the shake and reinstall. I usually see them need to be cleaned around 10 years.
    The V6's aren't know for blow by issues.
    Also I'd suggest 5k for intervals, its synthetic oil and designed for 10k. You don't get the most out of it until later in the run. It's a cam of worms but my 2 cents. Factory tech for Toyota.
  3. Jun 30, 2023 at 6:56 PM
    Gfenza89
    How about timing cover leaks on the 2023 models? Anyway to prevent it?
  4. Jun 30, 2023 at 6:59 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    no
  5. Jun 30, 2023 at 7:00 PM
    Gfenza89
    Has yours leaked?
  6. Jun 30, 2023 at 7:02 PM
    Bishop84
    It's random but we havent seen many leak after the 2019 years. They still happen but its not as common as it seems.
    wayupnort and RustyGreen like this.
  7. Jun 30, 2023 at 7:03 PM
    auskip07
    Skip
    Atlanta, Ga
    no
    Gfenza89[QUOTED][OP] likes this.
  8. Jun 30, 2023 at 7:03 PM
    Gfenza89
    Thanks. From how I understand it if they are gonna leak it happens within the first 2k miles or so
  9. Jun 30, 2023 at 7:04 PM
    auskip07
    Skip
    Atlanta, Ga
    i thought i saw more in the 60-70k mile range
    Abominator and kahanabob like this.
  10. Jun 30, 2023 at 7:14 PM
    Gfenza89
    I think that is by the time people notice it leaking
  11. Jul 1, 2023 at 11:01 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I owned 4.7 tundra for nearly 300k miles and 19 years....never changed the pcv....wouldn't even know where to look for it. I only used mobil1 5w30 motor oil.
    #4TOY4ME and Gfenza89[OP] like this.
  12. Jul 3, 2023 at 7:49 AM
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Not usually.
    60k-100k is the usual time frame.
  13. Jul 3, 2023 at 8:26 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    You don't necessarily need to replace it, but you should periodically check and clean it. My schedule this every 50k miles or so in all my vehicles. If they get plugged up at all, the engine will develop oil leaks.
    Gfenza89[OP] likes this.
  14. Jul 3, 2023 at 8:40 AM
    Gfenza89
    Almost makes you wonder if 60% of oil leaks in older engines is due to a partially clogged pcv valve. Feel like it’s something that gets over looked or never even thought about
    Junkhead and AM6217 like this.
  15. Jul 3, 2023 at 8:43 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    On older engines with a lot of crankcase blowby, it can overwhelm even a good PCV system and create leaks regardless. I have a 96 Camry with 230K that falls into that category.
  16. Jul 3, 2023 at 10:32 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    regarding timing chain cover leak. i think one reason is the timing cover is made up of layers not just one cover. thus once all installed and run for a day or two no way to re check the torque and re tighten since a lot of the bolts are buried and can't be checked. IMO
  17. Jul 3, 2023 at 10:39 AM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I pulled mine at 150k miles. It still rattled just fine. I blew carb cleaner and compressed air through it. I put it back without replacement.
  18. Jul 3, 2023 at 7:45 PM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Pretty cheap to not change it early.
  19. Jul 3, 2023 at 8:04 PM
    NewMexiMan
    NewMexiMan Well-Known Member
    2016 SR 5 Speed
    @Bishop84 I assume the same is true for the 2TR PCV valve?
  20. Jul 4, 2023 at 6:06 AM
    Gfenza89
    Yes
