Pcv valve replacement help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bulalo, Jul 11, 2022.
  1. Jul 11, 2022 at 12:29 PM
    bulalo
    bulalo [OP] Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Need help regarding pcv valve replacement on how to do it. Any torque values ? Don't want to overtighten it. Do I have to apply blue threadlocker ? Any videos specific for our 3rd gen ?
    Just want to prevent timing cover leaks from clogged pcv valve . Tnx
    mquibble likes this.
  2. Jul 11, 2022 at 1:12 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    you are a wise man. lot of people don't know that a clogged PCV valve can cause a oil leak due to backed up pressure in the block. had that issue with a old jeep once.
    Speedbird and bulalo[QUOTED][OP] like this.
  3. Jul 11, 2022 at 5:00 PM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Yup. After reading some folks with slightly high mileage tacomas here having timing valve cover leaks , I’m thinking a clogged or partially clogged Pcv valve may have something to with the leak . Just a prevention on my part. Almost 70t miles no leaks yet .
    cryptolime likes this.
  4. Jul 11, 2022 at 8:18 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Light coat of oil on the O-ring and torque to 44 in-lb.
    Iwilltaco and bulalo[OP] like this.
  5. Jul 11, 2022 at 8:19 PM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Thanks. Glad I asked. Imagine if not, I might crack the cover . Tnx again
  6. Jul 12, 2022 at 4:33 PM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    These can also be removed once a year and cleaned out with throttle body clean. Check for the "rattle". Rattle is good, no rattle bad.
  7. Jul 12, 2022 at 6:13 PM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Here's a pic of a 68000 miles pcv valve . Looks like new . Since I bought a new one, I installed the new and will keep this as spare.
    Big tall dave, Kolter45 and eurowner like this.
  8. Jul 12, 2022 at 6:31 PM
    splitbolt
    NW Arkansas
    Here's the service manual inspection procedure.
  9. Jul 12, 2022 at 6:59 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Is this an easy thing to do/check?
    bulalo[OP] likes this.
  10. Jul 12, 2022 at 8:29 PM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    It’s a PITA at least for me. Got frustrated . I can loosen it no problem but can’t take it off completely. The long socket interferes with the black plastic . so I just went ahead and went to Toyota. 84$ job for a 9$part. Is it worth it? For me it is . My frustration is sure more than the dollar spent for the dealer to do it ha ha. Also Peace of mind that Pcv is not clogged . I’m thinking the clogged Pcv contributed to the timing cover leaks in slightly high mileage tacomas .
  11. Jul 12, 2022 at 8:45 PM
    splitbolt
    NW Arkansas
  12. Jul 12, 2022 at 8:54 PM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Wow. This is very helpful . Had I seen this, i think I can do this . Anyway, thanks. I’m sure this will be helpful for everyone.
    Technique and splitbolt[QUOTED] like this.
  13. Jul 12, 2022 at 9:12 PM
    splitbolt
    NW Arkansas
    Might as well include the installation instructions then; you have good searchable title.
  14. Jul 13, 2022 at 12:29 AM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Thanks for this @splitbolt . You’re the man.
  15. Jul 13, 2022 at 6:41 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    It can be done without removing anything if you use a LONG extension and a wobble adapter, but it is a minor pain in the butt due to its location.
  16. Jul 13, 2022 at 7:35 AM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    That’s what I did and it’s so frustrating . My extended socket won’t come off it got lodged on the black cover behind . I gave up haha and drove it to Toyota .
    After reading @splitbolt attachment, I could have done it. I was adamant on removing hoses I’m not familiar with.
  17. Feb 20, 2023 at 10:05 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    bringing this back to the top with two questions i hope someone can help with. TIA.
    1. since i am viewing the PCV valve from above, are the threads the normal righty tighty, lefty loosy? so to loosen it i would turn it toward the firewall, correct?
    2. i have a few torque wrenches, sockets, etc., and would like to torque it to the required spec however, it doesn't seem like i can fit a socket and torque wrench in there. is there a special tool that is better suited for torquing the PVC valve?
  18. Feb 20, 2023 at 10:45 AM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    yes theres a video out there, give me a sec
    https://youtu.be/ZRDW0-zH0bA
