PCV Valve, check it.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CaptainBart45, Mar 4, 2024.
  1. Mar 4, 2024 at 9:02 PM
    CaptainBart45
    CaptainBart45 [OP] Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Thought the rear main seal was leaking, 2017 TRD Sport 4x4 with 89,000ish miles. Anyways it may have been the PCV valve leaking or the PCV valve that caused the rear main to leak. It is a 10 dollar check valve, pain in the ass to get at, but worth checking to avoid a big repair.
  2. Mar 4, 2024 at 9:23 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Was it stuck closed? Looks pretty gunky.
    I just changed mine on 100 000 mile 2012 and it was stuck open.
  3. Mar 4, 2024 at 9:25 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I pull mine about once a year, blast it with carb cleaner, blow it out gently, and make sure it rattles.
  4. Mar 4, 2024 at 9:34 PM
    CaptainBart45
    Bart
    Work in progress...
    Yep, just every other oil change should do it.
    JDKred likes this.
  5. Mar 4, 2024 at 10:39 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I too had the same experience. Noticed my rear main seal was leaking. Thought well maybe my PVC needs replaced. Did that and oil leak stopped . My 2017 has currently 230k+ mi and definitely gonna replace PVC again so don't have that scary moment again .
  6. Mar 5, 2024 at 2:32 AM
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    Where is the PVC valve located?
  7. Mar 5, 2024 at 2:42 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    It’s on my 30k service routine
    CaptainBart45[OP] likes this.
  8. Mar 5, 2024 at 2:49 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Near the left valve cover, inner side, near the rear.
    willtill[QUOTED] likes this.
  9. Mar 5, 2024 at 5:25 AM
    JDKred
    JDKred Well-Known Member
    JD
    16 MT KDMax Tuned
    Where is it located? I'll have to check mine.
    92k miles
  10. Mar 5, 2024 at 5:44 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    look above
    JDKred[QUOTED] likes this.
  11. Mar 5, 2024 at 6:39 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Doing mine along with spark plugs when I hit 50K. Just seems smart.
    Changed the one on my brother’s Tundra 5.7L and it broke as soon as we put a socket on it, due to being so brittle. Hard to tell if it was clogged that way, but at least we know it’s good now.
    shakerhood and CaptainBart45[OP] like this.
  12. Mar 5, 2024 at 6:43 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Dang, more Dr TW giving me symptoms to worry about. Just crossed 100k and should get some FOMO on this.
  13. Mar 5, 2024 at 7:02 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Just swapped mine @ 125K. Aside from a little discoloration, it looked and functioned as new.
    Last one I looked at before that was on the Tundra, at something like 225K. Same thing.
    Might have something to do with driving habits, I suppose.
    At least in my experience, and fortunately for that vast majority of automobile owners that have no ideal what a PCV valve is, I think the average vehicle could go from cradle to grave on the original valve without an early demise.
    StayinStock and tonered[QUOTED] like this.
  14. Mar 5, 2024 at 7:20 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Cheers!
    You are not wrong. I mean, I just got a recall notice for a weeping HPFP. The symptom noted was raw fuel smell. Funny thing as I just looked at it while the oil was draining. Folks don't even crack the hoods these days.
    jmneill[QUOTED] likes this.
  15. Mar 5, 2024 at 7:32 AM
    BLtheP
    Plano, TX
    My take is that it's mostly unlikely to cause a problem, but unfortunately if it does happen to clog and become problematic, you probably won't know until it starts to cause other issues, like the RMS leak for example due to higher crankcase pressures. So for me it's easy to throw it into the rotation with the spark plugs, since the part is super cheap and installs right there while you're in there doing the plugs. I expect to see no clogging in the one I remove.
    I think also the amount of blowby and quality of the oil vapors that go through the PCV ultimately determine whether or not it's going to clog. But it's so cheap I'd like to just throw a new one at it when I do plugs.
  16. Mar 5, 2024 at 7:45 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Right on. Just do it.
    HondaGM, BLtheP[QUOTED] and Stevie17 like this.
  17. Mar 5, 2024 at 7:48 AM
    CaptainBart45
    Bart
    Work in progress...
    While you are in there changing the spark plugs makes sense and should be the perfect milage/time to change the PCV.
  18. Mar 5, 2024 at 11:10 AM
    SEVtaco
    SEVtaco Well-Known Member
    Orange County
    2021 Tacoma TRD OR
    king2.5s/33s/Deaver/SCS wheels
    12204-0P020, PCV Valve OEM part # for the 3.5v6 its 10 $
  19. Mar 5, 2024 at 1:37 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    when you say left side is that drivers side or passenger side? i assume passenger looking at it with the hood up. sorry sounds like a dumb question.
    Stevie17 and HondaGM like this.
  20. Mar 5, 2024 at 1:40 PM
    jmneill
    SE
