pcm
Discussion in '1st Gen. Tacomas (1995-2004)' started by kodiak341, Aug 23, 2021.
  1. Aug 23, 2021 at 7:13 PM
    kodiak341
    kodiak341 [OP] Well-Known Member
    01 Tacoma 4x4
    2001 tacoma 2.7 regular cab 5 speed 4x4….where is the pcm located?
  2. Aug 23, 2021 at 7:19 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Behind the glove box.
    Black DOG Lila likes this.
  3. Aug 23, 2021 at 7:21 PM
    kodiak341
    01 Tacoma 4x4
    dude thank u lol…that’s literally the only place i failed to look….i feel so silly lol
  4. Aug 23, 2021 at 7:22 PM
    kodiak341
    01 Tacoma 4x4
    any suggestions on where to get a replacement?…plug and play would be nice
  5. Aug 23, 2021 at 7:33 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You will have to get it out and get the part numbers off it and either search for it or call around to local salvage yards and see what they have. Are you sure it's bad?
  6. Aug 23, 2021 at 7:40 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Oh you have the no crank thread.
    The PCM has absolutely nothing to do with the starter circuit on a 1st gen Tacoma, you could completely unplug the PCM and the truck should still crank over it just wouldn't run.
  7. Aug 23, 2021 at 8:01 PM
    kodiak341
    01 Tacoma 4x4
    i do….. i wasnt sure about the relevance between the pcm an the starter, i know they play a role…im new to the toyota world….we have dodges an chevys lol
  8. Aug 23, 2021 at 8:02 PM
    kodiak341
    01 Tacoma 4x4
    so if the pcm has no role….then it must be in the switch…correct?……or in the fuse box..?
  9. Aug 23, 2021 at 8:04 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    Or in your starter itself.
  10. Aug 23, 2021 at 8:05 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yes on most domestics the PCM is involved in enabling the starter but 1st and 2nd gen Tacomas the PCM is not involved in enabling the starter.
  11. Aug 23, 2021 at 8:06 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You gotta trace out the circuit with a test light and see where your power ends, go to the STA fuse first and see if it has power on both sides when the key is held in the crank position.
  12. Aug 24, 2021 at 9:02 PM
    Glamisman
    Glamisman Well-Known Member
    clutch switch...
  13. Aug 28, 2021 at 8:19 AM
    kodiak341
    01 Tacoma 4x4
    ok, so after tracing from the switch alll the way to the starter it ended up being a loose wire in the fuse box…it was where the starter relay is…now on to the clutch, time to put a new one in it
    TnShooter and Dm93 like this.
