Payload Question (yes another one!)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rrcbob, Apr 13, 2021.
  1. Apr 13, 2021 at 3:24 PM
    rrcbob
    rrcbob [OP] Member
    Bob
    2021 Tacoma
    I just got a 2021 Tacoma and took it to the CAT scale to see if my understanding of the weight numbers is correct before beginning to tow a camper. I couldn’t get the numbers squared.
    The payload in my manual is 990 (model GRN305L-PRTSHA short-deck double-cab 4x4). There’s a sticker on the door frame indicating an additional 116 pounds of factory installed options and I’ve added a bed mat and roof railings/cross bars (guessing 30 pounds for these two items). I had a full tank of gas and I weigh 180 so I calculated available payload capacity of 664 (990 - 116 - 30 - 180) and an expected actual weight of 5,136 (5,800 GVWR less 664) but got a reading of 4,780 a difference of 356.
    I read somewhere that the CAT scales were calibrated to 20 pounds per 10,000.
    Is the CAT scale right or maybe they aren’t as accurate for a smaller vehicle? Or maybe something else I haven’t considered?
    Thanks.
    davidstacoma likes this.
  2. Apr 13, 2021 at 3:31 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    2019 m/t TRD OR DCSB
    OME Lift Viper Cut
    Go to a dump where they weigh you coming in and going out. Throw something away you know the weight of and see how it adds up?
  3. Apr 13, 2021 at 3:32 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Approx curb weight of your truck. Is it not 4,445?
    4,445+116+30+180 = 4,771
    Unless my math is bad, it seems like you're right where you should be, sitting @ 4,780.
  4. Apr 13, 2021 at 3:34 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    There are two stickers to look at on your door frame, the tire sticker which has your payload and the yellow one for additions to subtract from the payload sticker rating. Them you deduct your add ons as you are doing above.
  5. Apr 13, 2021 at 4:00 PM
    rrcbob
    rrcbob [OP] Member
    Bob
    2021 Tacoma
    Thanks.
    I kinda did that in reverse. I pulled in with 25 miles left in the tank and weighed before and after filling the tank. I put 17.9 gallons. With gas somewhere between 5.9 and 6.5 pounds per gallon (the range I found on the web depending on additives) I expected 106 to 116 - the actual difference before and after was 100 so maybe the scale was weighing light. The drive from the gas station to the scale was maybe 0.2 miles.
    barf[QUOTED] likes this.
  6. Apr 13, 2021 at 4:03 PM
    rrcbob
    rrcbob [OP] Member
    Bob
    2021 Tacoma
    With GVWR of 5,800 and payload of 990 isn’t curb weight 4,810?
  7. Apr 13, 2021 at 4:05 PM
    rrcbob
    rrcbob [OP] Member
    Bob
    2021 Tacoma
    The tire sticker shows 990 of payload consistent with the manual.
  8. Apr 13, 2021 at 4:20 PM
    jmneill
    SE
    Toyota's specs show the 2021 4X4, 5' box double cab SR and OR curb weight @ 4,445, with the Sport and Limited weighing in @ 4,465 and 4,505, respectively.
    Cliffj0441 likes this.
  9. Apr 14, 2021 at 1:15 AM
    rrcbob
    rrcbob [OP] Member
    Bob
    2021 Tacoma
  10. Apr 15, 2021 at 5:24 AM
    rrcbob
    rrcbob [OP] Member
    Bob
    2021 Tacoma
    More info on my question from CAT Scale
    Thank you for contacting CAT Scale.
    The variance of our scales is established in the National Institute of Standards and Technology Handbook (NIST) 44 Table 6. Class IIIL scales are allowed one division, or a 20 pound variance off zero for each 10,000 pounds of weight applied. Most calibration tests performed by either the State Weights and Measures or a licensed scale service company will use a minimum of 20,000 of certified test weights. In the case of a 20,000 pound test, anything beyond a 40 pound error in reading would be a failed test. In the case of CAT Scale, all of our scales are calibrated at least four times per year by a licensed service company and we require the calibration to be adjusted to zero error.
    CAT Scales display and print in 20 LB increments to comply with the specifications set in NIST Handbook 44. Each of the axle weights would round up or down to the nearest 20 LB.
    As an example, if your steer axle (front axle) weight is 2,612 LB the CAT Scale would register that weight as 2,620 LB. If the drive axle (rear axle) weight is 2,068 LB the CAT Scale would register that weight as 2,060 LB.
    Adding 17.9 gallons of gas would weigh approximately 112 pounds. Your total difference in gross weight between the two scale tickets was 100 pounds. The approximate 12 pounds could be the result of rounding to the nearest 20 pounds on each axle.
  11. Apr 15, 2021 at 5:42 AM
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    When I bought my truck I drove through a country weigh station and got 4700 pounds total, I'm about 200 so the truck is about 4500 pounds. I also weighed it not only with all four wheels on the scale but front/rear separately and it added up. Didn't take weight of gas into consideration, was about half a tank as I recall. "About" is good enough for me lol.
    EDIT: also was factory bumpers and no tonneau and no other cargo. If you gett aftermarket stuff add that weight in also.
  12. Apr 15, 2021 at 6:41 AM
    rrcbob
    rrcbob [OP] Member
    Bob
    2021 Tacoma
    Thanks. I'm about convinced that the numbers I got from the CAT Scale are about right. I just can't square them with what Toyota says the payload is. I'm seeing about 350 pounds more payload than Toyota if payload is GVWR less actual GVW.
  13. Apr 15, 2021 at 7:03 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I may be all wet, but I think an accuracy of +/-0.2% on 10,000 lbs is pretty darn good.
    I s'pose you can dink about with different scales, although, the CAT reading is very good.
    Don't think I' trust a landfill scale. They have motivation to weigh heavy on inbound and weigh light on outbound.
  14. Apr 15, 2021 at 7:37 AM
    rrcbob
    rrcbob [OP] Member
    Bob
    2021 Tacoma
    I agree that 0.2% is more than good enough. I haven’t been able to find a source that tells me that the scales are this accurate at 5,000 pounds. CAT does their testing at 20,000 pounds. When I see that Toyota’s payload number is not consistent with the weight I get on the CAT scale it makes me question (if payload is GVWR less GVW). Seems like either one or the other is wrong or there is something more to know about why Toyota shows the lower payload number.
  15. Apr 15, 2021 at 7:41 AM
    Knute
    In truth.......It doesn't matter what is wrong.
    You have the weight of the empty truck (UVW), you know the GVWR of the truck. Just do a little math to subtract the UVW from the GVWR, now you have the Cargo Capacity (CC) of the truck. Done.
    Find something else to fret about.
    farmtacoma, hiPSI and jmneill like this.
  16. Apr 15, 2021 at 8:45 AM
    NorrinRadd
    WA
  17. Apr 15, 2021 at 10:01 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    if you are worried about 356 lbs you have the wrong truck
    farmtacoma likes this.
  18. Apr 15, 2021 at 10:38 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Forget about any numbers you see on Toyota's website or on a spec sheet. Those numbers are for one specific truck. Every truck is different and will have different weights. GVWR stays constant within models, but since every truck is a different weight, heavier trucks with more options have less usable payload
    You can approach this 2 ways. There is a sticker on the door jamb with payload from the factory. Mine is 1200 lbs
    You have an additional 116 lbs of other options. Find your payload rating and subtract 116 from it.
    Or you could work from GVWR.
    My truck's GVWR is 5450. That means that my truck actually weighed 4250 when it was built. 5450-1200= 4250. But I have a cap on my truck that weighs 180 lbs meaning my trucks actual payload is closer to 1000 lbs.
    BTW, I've actually weighed my truck and the numbers match up pretty darn close to the numbers printed on the door jamb.
    Find your trucks GVWR and subtract your trucks actual weight( 4780) from it to determine your available payload. Remember, the 4780 includes YOUR weight too. Working off GVWR is usually more accurate since the payload sticker doesn't include the driver or any tools, recovery gear, accessories, modifications, or other items kept in the truck.
    You didn't list the printed payload anywhere, that is important info. It appears to me that your trucks actual weight, 4780, subtracted from payload is going to give you 1020 lbs payload. And since you weigh 180 if you add 180 lbs back to 1020 you come up with the same 1200 lbs payload as my truck. Which seems about right. I'm betting your printed payload is around 1300 lbs. Then the additional 116 would get you back near 1200.
  19. Feb 9, 2022 at 10:22 PM
    TheIncredibleTaco
    TheIncredibleTaco Well-Known Member
    Denver, CO
    2021 TRD OR DCSB
    Exhaust reroute RCI steel full skid plates (front, transfer case, transmission) Front camera (anytime backup camera) RCI rock sliders AC Drip mod OEM locking tailgate Brite box fogster anytime fogs Backwoods adventure mods hi-lite front bumper with Baja designs squadron pros ARB single OBA Fox 2.5 PES DSC 2-3” Wheelers superbumps + ubolt flip kit Deaver stage 1 u402 Cab mount chop+fender trim Rrw RR-7 -12 offset with 315/70r17 5.29 regear ARB front air locker Z precision big cupholder
    This is odd to me too
    GVWR: 5600 lbs
    GAWR: front 2940 lbs, rear 3280 lbs
    So that’s saying I can have more weight on one of the axles than the other, ok
    but my door states 990 lbs of cargo capacity
    Then when I bought the truck I have the title that said 4326 lbs
    21 gallons of gas is 133 lbs
    5600 - 4326 - 133 = 1141 lbs
    1141 - 990 = 151 lbs difference
    So could oil, wiper fluid, etc possibly weigh that much? I’m guess the gas has to be more than half the fluid weight. It seems the door has ~100 lbs of margin built into it
    anyone have any guesses?
    Of course I could go weigh my truck but then there’s a debate if unsprung weight really affects payload like heavier tires or lighter wheels
    was hoping maybe someone else has an estimate of what the truck with fluids weighs over the number on their title
  20. Feb 9, 2022 at 11:09 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Toyota specs says your curb weight should be 4495lbs. Based off your payload of 990lbs your actual curb weight (because of added options) should be about 4610lbs. Your truck does not weigh 4326lbs like listed on the title.
