Patched tire and long road trip/off-roading
Discussion in 'Wheels & Tires' started by TacomasRulefor100Alex, Sep 5, 2020.
  1. Sep 5, 2020 at 5:04 PM
    TacomasRulefor100Alex [OP] Member
    Zack
    2016 Tacoma TRD
    Hey Folks,
    I have a question for you experts. I recently had one of my tires repaired on my Tacoma after hitting a screw. I believe they used the patch method but I need to double check. Next month I plan to do a month long road trip from Texas to California. It'll probably be around a 6k mile trip. I do plan to drive down some rocky trails during this trip but nothing too extreme. From your experiences, do you believe it is safe to drive on that tire or should I get it replaced. The shop said I should be fine but to not air down. Also, I waited about 2-3 months to get the tire fixed because it was a slow leak, with that said, there were times when I got the pressure down to around 20 before filling it back up. I recently read that could weaken the walls of the tire. Last thing I want is to blow the tire in the middle of New Mexico or something. I'm assuming my shop would have told me though if they noticed some damage. Thanks in advance for any advice!
  2. Sep 6, 2020 at 8:47 AM
    project plan B
    project plan B Member
    Alec
    2016 White Limited DCSB Tacoma
    King Mid-Travel Kit with Total Chaos UCA and OME Dakar Leaf Packs ATX Slab Beadlocks with Nitto Ridge Grapplers Rigid Fog lights AT The Helm Fab Bed Corner and bedside reinforcements MBRP Exhaust with drop in K&N
  3. Sep 6, 2020 at 8:56 AM
    Zack
    2016 Tacoma TRD
    @project plan B Sigh.... yeah that's what I'm thinking. I just don't wanna fork up the cash right now to replace it. Better safe than sorry though I guess.
  4. Sep 6, 2020 at 8:56 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    no correct answer
    cant cover Every contingency
    toooooooo much flex in either scenario is never good
    tooooooo much flexion causes heat that could make either to fail
    U could use the ' screwed ' tyre as a spare.................. a diff tyre to count on
    good luck
    69 Jim likes this.
  5. Sep 6, 2020 at 8:58 AM
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    2013 Standard Cab 4x4
    Your truck runs on 100% used parts, where do you start? Whatever you do, enjoy your trip:thumbsup:
    Rollin-slow likes this.
  6. Sep 6, 2020 at 9:00 AM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    20psi isn't aired down.
    If you've got LT tires you can likely drive on the interstate for extended periods without issue at that PSI.
    It's unlikely you'll have any problems cruising around with a plug.
  7. Sep 6, 2020 at 9:01 AM
    project plan B
    Alec
  8. Sep 6, 2020 at 9:08 AM
    ROAD DOG
    FEW
    id rather patch than plug
    yet at 75-80mph hiway summertime either could fail.................
    whatstcp[QUOTED] likes this.
  9. Sep 7, 2020 at 12:49 PM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    If the patch is properly applied and stays stuck..... my concern is I have seen them work loose. Maybe due to poor glue or poor prep / application.
    When I was in high school (mid-1960s) I worked in a service station. We plugged quite a few tires and never had a plug fail (that we knew of). Do tire shops still use plugs?
    I was working in SoCal in 1968 and had a '65 Corvette. Forgot all about the plugged tire and ran it up to 135 mph for a short distance in the desert. Luckily it held.
    But like you say, anything can fail. OP, you should be fine but I would check your tire pressure religiously just in case.
    If you're concerned about it, run it as a spare as suggested. If you're really worried, get a new tire.
    doublethebass likes this.
  10. Sep 8, 2020 at 10:32 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    A proper repair includes a plug and a patch; some use a combo patch/plug.
    69 Jim and XSplicer62[QUOTED] like this.
