Passenger Side Mirror Replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cam308, Dec 7, 2017.
  1. Dec 7, 2017 at 2:54 PM
    Cam308
    Cam308 [OP] Well-Known Member
    2016 Tacoma TRD Sport 4x2
    Blew up my passenger side mirror like a dumb ass, backing out of the garage. My color matched cover was unharmed thankfully. I couldn't bring myself to buy the $200+ authentic Toyota replacement mirror....so I took a chance on the cheaper alternative (only $78). I'm happy to report to this group that the part fit like a glove. Integral blinker and mirror motor work perfectly. I followed the instructions in the links below and knocked it out in under 30 min. The moment of truth, if any step was going to expose my budget buy, it was replacement of the black cover with my authentic Toyota cover. Couldn't believe it fit perfectly. I'm happy that it was only $80 to fix my stupidity instead of triple that. Hope this helps.
    https://www.partsgeek.com/catalog/2016/toyota/tacoma/body_mechanical_-ar-_trim/mirror.html
    https://www.youtube.com/watch?time_continue=18&v=w8Quqpto81c
    https://www.tacomaworld.com/threads/replacing-side-mirrors-on-3rd-gen.471180/#post-14878998
    DSRamsey13, G-Dawgg and JoeCOVA like this.
  2. Dec 7, 2017 at 3:41 PM
    jholc21
    jholc21 Well-Known Member
    Colorado
    2017 White Tacoma TRD OR
    Bilstein 6112/5160 w/Dakars Leafs 255/80/R17 Cooper ST MAXX Skinnies 4.88 Gears TRD Pro Fog Lights Cali Raised 5D Combo Leather Seats LED Bed Lighting ARE Overland Shell
    Nice find! I did the same thing and was shocked when pieces went everywhere. I managed to put it back together but have a crack in the clear plexiglass where the turn signal light is. This looks to be a good option.
  3. Jul 10, 2018 at 10:39 PM
    Disaster06
    Disaster06 Active Member
    2018 quicksand Tacoma SR5
    Thanks!
  4. Apr 15, 2019 at 12:36 PM
    Blacklodge
    Blacklodge Well-Known Member
    Houston, TX
    2017 TRD Offroad
    2888 - Old Man Emu Coil Springs 90021 - Front Old Man Emu Nitrocharger Sport Struts (5mm Trim Spacer x2) 60091 - Rear Old Man Emu Nitrocharger Sport Shocks EL095R - Rear Old Man Emu Leaf Springs Total Chaos Uniball Upper Control Arms TRD Pro Grill American Racing 16" Wheels Falken Wildpeak A/T3W 285/75/16
    Any issues with this replacement rattling? I have the same replacement on the drivers side, the glass shakes distorting the image the housing seems to rattle over bumps.
  5. Aug 22, 2019 at 2:28 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Just replaced my passenger side with this mirror (premium heated, w/o blind spot, with the chrome blinker) and I'm very pleased. I was hesitant to buy an aftermarket knock-off, but I'm glad I did. Holding the two mirrors side-by-side it's almost impossible to tell the difference between these and OEM. If you run your hand along the black plastic it is slightly more coarse to the feel but visually it looks the exact same in every single way. I planned to replace the mirror w/ my OEM one, but given the glass looks to be of good quality, I'm going with the mirror on the after-market one.
    Like the OP, my silver color-matched cover snapped right on without any trouble. Motor works as well (if not a bit quieter) than OEM as does the turn signal. Glad I didn't fork out more than double the cost of this mirror for OEM. Easy install ~20 mins and my wife's garage mishap is fixed for less than $100
    NOTE: On a short drive, I've seen ZERO issues w/ shaking or anything. If I do over time I'll report back, but I don't think OP has had any issues either.
    Thanks @Cam308
    Cam308[OP] likes this.
  6. Sep 9, 2019 at 9:55 PM
    bongbong
    bongbong Active Member
    Georgia
    2019 White Tacoma SR5
    Mine shakes and get disoriented when driving on the highway, does it happen to you?
  7. Sep 10, 2019 at 6:19 AM
    bshammer0
    Brandon
    Nashville, TN
    Nope. No issues whatsoever
  8. Sep 10, 2019 at 6:20 AM
    bshammer0
    Brandon
    Nashville, TN
    I'd remove and reassemble the mirror (you can use the Rav4 convex mirror mod directions to find out how) to make sure it's secure. Likely the mount of the mirror is just loose to the base where the heater coils are.
  9. Feb 6, 2020 at 7:06 PM
    SeminoleNate
    SeminoleNate New Member
    Hi folks, new member and first post. Hoping to get some help.
    Last night someone hit the driver side mirror on our new 2020 Offroad (less than 700 miles :(). It looks like they barely grazed it because the mirror itself works fine (motor, BSM, heater, blinker) but it was enough to tear off the plastic body housing and break some of the internal plastic pieces that seem to hold the wires. I've attached some photos for reference.
    A couple of questions - any idea if it's possible to simply replace the housing / internal plastic pieces? Not even sure how to identify the correct parts or ensure I'm getting everything I need. More reasonable is probably to replace the whole mirror with something like the part referenced above. I'm assuming that since 2020 is still a 3rd gen Taco the part should be compatible but would really appreciate if someone could help me confirm.
    Thanks a ton in advance!
  10. Feb 7, 2020 at 4:59 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Brand new truck! MuthaF! That sucks, I'm guessing they drove off too?
    Welcome, sorry about your bad luck, hopefully it ends the though.
    Bleep100 likes this.
  11. Mar 22, 2020 at 6:40 PM
    Risenski11
    Risenski11 Well-Known Member
    CO
    2017 Tacoma TRD OR DCSB
    Does anyone if the hinge/part that mounts directly to the truck, separates from the rest of the assembly? I totally ripped the mirror off my truck, getting out of the below, and although the mirror looks good, the mount/hinge is destroyed. For the record my wife was driving DE6D3B83-7E82-4B99-A1CC-B7CBCAC0846F.jpg
    gavone1976 likes this.
  12. Mar 22, 2020 at 7:08 PM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    At least she kinda kept one tire on the road . Glad she wasn't hurt , good luck to you two .
  13. Mar 22, 2020 at 7:08 PM
    gavone1976
    gavone1976 Member
    George
  14. May 3, 2021 at 5:50 AM
    Want2Believe
    Want2Believe Well-Known Member
    Colorado
    2020 Quicksand MT OR
    Wondering what you ended up ordering for this, did you go with the parts listed above?
  15. May 3, 2021 at 7:29 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    He was a one poster and never returned.
  16. Dec 20, 2021 at 8:26 AM
    easfahl
    easfahl Erica
    Erica
    Fayetteville, AR
    2017 Black Toyota Tacoma 4-Dr TRD Sport 5' bed
    ToyTech 3" lift, 285/70/17 BFG on 17" FUEL rims
    For those of you who have the aftermarket mirror that rattles/vibrates, which aftermarket brand did you buy from the OP's link: Brock, TRQ, DIY Solutions, Action Crash Parts, or TYC?
  17. Jan 29, 2025 at 12:16 PM
    Yamz
    Yamz New Member
    Taco Blanco 2021
    @Chew yeah, bc his wife found out he the HER under the bus!!!
    I had something similar backing into a wooded driveway. The mirror, motor, heater, blinker, warning light... everything is fine except the cowl.
