Passenger side diff. seal still leaking - 3rd change????
Discussion in '1st Gen. Tacomas (1995-2004)' started by TTBlues, Oct 31, 2013.
  1. Oct 31, 2013 at 5:42 PM
    TTBlues
    TTBlues [OP] Well-Known Member
    1999 Tacoma SR5 V6 4x4
    Stock
    1. Changed my CV axles and afterwards, the passenger's side started leaking.
    2. Took it apart and changed the seal and it still leaked.
    3. Opened it up and re-seated the seal so that it was flush with diff. housing and it still leaked.
    4. Changed the seal again. This time put it on the axle and then inserted the axle into the housing.
    STILL LEAKING.
    Should I glue it in with something? RTV silicone?
    I am using factory OE seals.
    I've also found it fairly easy to move in and out of the diff. I can pull it out with my hand and can put it in without the use of a rubber mallet. I had the understanding that it should be a bit more snug than it is. Is that true?
    It's also very easy to push the seal in too far. There is no lip or anything in the diff that catches this thing and prevents it from seating in too far. Very silly design.
    Thanks.
  2. Oct 31, 2013 at 7:59 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    should be snug and not easy to pull out with your finger. you got the right part? part guys make mistakes all the time
  3. Oct 31, 2013 at 8:58 PM
    TTBlues
    Stock
    99 Taco, V6 4x4.. Passenger side. I've received part 90311-47013 from 2 different dealerships.
    Also saw it listed on the forums as that number.
    It's a little snug, but I can push it in beyond flush with just the palm of my hand and can get two fingers on it and yank it out. Harder to calibrate its depth with just hands, but when i put it in i thought: "that ain't gonna keep the oil in".
  4. Oct 31, 2013 at 9:18 PM
    gearcruncher
    Canadain bumper technician
    Not a common problem that I am aware of .
    If you remove the seal and look at the housing where the seal fits , does it look like the seal has been spinning ?
    The diff needs to be filled up after install to lubricate the seal .
    Did someone swap out the diff before you owned the truck with a different part number ?
    Installing a seal by hand will not work . The seal needs to be press fit or a good amount of force to install it .Something is incorrect or wore out . Without looking at the diff , thats my guess
    A quick fix ... add a bunch of locktite to the outer portion of the seal , then install it letting it sit for 24 hours before you install the axle . May get you back up and running but something is incorrect with your set up
  5. Oct 31, 2013 at 10:03 PM
    TTBlues
    Stock
    It doesn't look like it's been spinning.
    I fill the diff up after install.
    I'm pretty sure the diff is stock. The gearing on the truck matches the door sticker and there are no signs of a replace at the diff.
    I'm not sure why these seals don't require press fitting. They're close. They move a little like a stuck drawer. But not stuck enough to seal.
    I'm pretty sure the axles I replaced were the original stock axles. They were toyota with the green casing. The only reason I had to replace them was that the rubber boots were so old they broke away at the clamps.
    Loctite might work. Someone else said RTV. But something like that should do the trick.
  6. Oct 31, 2013 at 10:07 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea..you shouldn't be able to push it in and out at all with your hands. Should take tapping with a large socket and hammer to get in at all.
    I got mine from Napa and worked great. But my OEM one i bought first to replace with was very snug too.
  7. Oct 31, 2013 at 10:22 PM
    TTBlues
    Stock
    hmm. that's weird. i'm pretty sure the diff is the stock one so all it could be is the wrong part number. there's no sign of damage at the diff. and yet the opening is slightly too large for the seal. Again, the part number I got was 90311-47013. I'll check on it.
  8. Oct 31, 2013 at 10:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Make sure your not getting a driver's side seal maybe..
  9. Oct 31, 2013 at 10:49 PM
    TTBlues
    Stock
  10. Nov 1, 2013 at 9:43 AM
    gearcruncher
    Do you have a micrometer to measure the seal before you install it ?
    I doubt RTV will hold in a loose seal , possibly JB weld or a red lock tite
  11. Nov 1, 2013 at 9:53 AM
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    dude the same dam thing happened to me. i literally changed it 4 times new seals every time, and second i would put it all together and test it, oil would POUR out. its like... WTF!
    my problem was i was putting in the seal too far, like you said can happen.
    also, the seal should not be able to be pulled out by hand, id go to the dealer and get a oem seal.
    and about your seal being easy to put in and out... you can try locktight... idk... maybe the oem wont do that..
    what id do if i was you, insert the seal into the diff, slightly. do not put in flush with the outside of the diff yet, but in enough to hold the seal there.
    once you do that, then put the axle in, and it should put the seal in at the exact correct depth.
  12. Feb 2, 2014 at 10:26 PM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    Have you fixed this problem? I ran into the same problem going to check if I installed my seal to far in the diff housing.
  13. Feb 3, 2014 at 11:23 AM
    4runnercaged
    cody
    arizona
    LOL
    im not sure if its different with 2nd gens. but i know for on 1st gens if you just installed a new seal on the passenger side and it started leaking right away, 2 things could have happened. you wither fucked up the seal putting it in, or you put the seal in too far making it so the cv axle doesnt sit flush against the seal.
  14. Feb 7, 2014 at 1:41 AM
    TTBlues
    Stock
    you know, i thought i had it fixed. i had re-installed it by putting it on the axle first, and then installing the axle. it seemed to have worked for a month or so. but i checked just last week and there is a bead or oil collecting. i'm gonna use rtv next. i don't get it.
  15. Feb 7, 2014 at 8:16 AM
    4runnercaged
    cody
    arizona
    LOL
    if its just a bead of oil collecting im sure your fine.
    so its only a couple drops a day? if it is i would not worry about it.
    it could be your cv axle if your going through them that fast
