Passenger rear door won't open
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rider311, Jan 12, 2016.
  1. Jan 12, 2016 at 6:28 AM
    rider311
    rider311 [OP] Well-Known Member
    Fort Collins, CO
    15 TRD Sport 4x4
    So, my rear passenger door jams at random times. I have taken it into the dealer a couple of times when it was jammed only to open without a problem when I get there, of course. The door is unlocked and the handle will pull, but the door doesn't budge. I am going to run to the dealer again today and hopefully it will still be jammed.
    Anyone have any ideas?
  2. Jan 12, 2016 at 7:13 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Assuming it hasn't been in any accidents, since it's a '15. I would guess the latch isn't always fully releasing.
  3. Jan 12, 2016 at 7:26 AM
    rider311
    Fort Collins, CO
    15 TRD Sport 4x4
    That is my guess. Any ideas on how I could get into the door and correct this since it is jammed? I know as soon as I go to the dealer, it will open. So, I might as well try and fix this myself.
  4. Jan 12, 2016 at 8:10 AM
    Fitz235
    Rob
    New Hampshire
    I would guess that there must be an adjustment on the latch, but don't know for sure. Maybe try moving the door while attempting to open it. Pull up, down, side to side. I'm guessing that it's slightly off, if it opened after you drove to the dealer. It sounds like maybe the light flexing of the body as it drives over uneven surfaces found on any given road is what let it loose the last time(s).
  5. Jan 12, 2016 at 8:27 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Try pushing IN on the door as you pull the latch/handle. If it releases, there is an adjustment to fix it.
    PzTank likes this.
  6. Jan 12, 2016 at 12:54 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Access Cab or what?
    If it is an access cab does the handle just feel like it is disconnected?
    See this post, the lever may be stuck in.
    https://www.tacomaworld.com/threads/help-suicide-door-wont-open.407218/#post-11437922
    shakerhood likes this.
  7. Jan 13, 2016 at 8:10 AM
    rider311
    Fort Collins, CO
    15 TRD Sport 4x4
    I was on one of my jobsites yesterday and had a coworker try to open the door and it wouldn't open. Just to make sure I am not crazy. I immediately drove to the dealership and low and behold, it opened with one finger. Needless to say, I lost it. The service manager came over and had them schedule an appointment to take the door apart and adjust everything. Then, after work, I go and pick up my son and it won't open. Pain in the ass.
    Anyway, thanks for the suggestion. I pushed in on the door as you suggested and it opened. Do you know what needs to be adjusted?
  8. Jan 13, 2016 at 8:11 AM
    rider311
    Fort Collins, CO
    15 TRD Sport 4x4
  9. Feb 4, 2016 at 6:25 AM
    rider311
    Fort Collins, CO
    15 TRD Sport 4x4
    Quick update. The door latch is bad and has to be replaced.
    PzTank likes this.
  10. Jan 27, 2019 at 6:58 PM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    how did you open it?
  11. Jan 27, 2019 at 7:53 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    He said he pushed in on the door and it opened.
  12. Jan 28, 2019 at 5:32 AM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    I am having a similar issue. It is like the cables pulled out of my rear pssenger door.
    The handle pulls out but doesnt has tension or resistence. It is locked and wont open from the inside or outside
  13. Jan 28, 2019 at 6:04 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
  14. Jan 28, 2019 at 6:09 AM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
  15. Jan 28, 2019 at 6:29 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I've watched that video dozens of times. I still have no idea how to get an inner door panel off. I may have to watch it again.
    TacoTRD78, jproffer and Rick's 2012 like this.
  16. Jan 28, 2019 at 6:43 AM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    There's a Tacoma in that video?? Really??
  17. Jan 28, 2019 at 7:39 AM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    this is a serious problem guys.... lol can i go through the window?
  18. Jan 28, 2019 at 10:32 AM
    TexasWhiteIce
    Texas
    There was a show once that they always jumped through the windows to get in and out. The guys names were Luke Duke and Bo Duke. They had a cousin named Daisy Duke... their vehicle was orange red with a 01 on the side of it and it used to jump tons of Hazards running away from the sheriff.
    I think the show was called, “The car that couldn’t open it’s doors”
  19. Jan 28, 2019 at 10:49 AM
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    SOLVED - I bought a $15 air shim and placed it on the inside of the truck where the locking mechanism. Pumped it up as much as possible then used plastic door trim tools to pry. While prying I yanked on the exterior handle and BOOM! It opened right up.
    Few thoughts for my specific situation..
    1. The primary issue was the connection with the exterior handle
    2. The child lock was on so that is why i could not open from the inside
    3. I tried to push the unlock lever with the window down but it was to no avail
    3. It is miller time and it is only 12:45
  20. Jan 28, 2019 at 10:54 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Just dont say the name of the car because its racist. :thumbsup:
