Passenger Lock making Weird Sound
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kjd99, Sep 19, 2022.
  1. Sep 19, 2022 at 8:30 AM
    kjd99
    kjd99 [OP] Member
    Connecticut
    21 SX
    KDMax Tune 33” KO2’s
    Hello!
    Yesterday when I went to lock my 21 Taco from the inside with the passenger door open and I heard this odd noise. I’ve attached a video below of the odd sound it makes when I lock it, it went away yesterday, was fine earlier today, and when I went to lock it 30 mins ago, it made the same sound. https://youtube.com/shorts/-NksjK_wNo8?feature=share
    Anyone know what causes this issue?
    The truck is still within warranty so if a part needs to be replaced, I’m good. More so curious as to why the funky noise is occurring in a year old truck.
  2. Sep 19, 2022 at 10:51 AM
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    Sounds like the solenoid is messing up...or something is obstructing movement. Is it locking and unlocking the door? I once had a vehicle where the rubber boot of the solenoid got tangled with the extended push-rod. As the push rod moved in and out, the boot was causing an issue of movement. Could be a similar issue. Take it in and let them fix it.
  3. Sep 19, 2022 at 1:53 PM
    kjd99
    kjd99 [OP] Member
    Connecticut
    21 SX
    The truck still locks and unlocks, I’ll take it to the dealer
  4. Sep 19, 2022 at 8:09 PM
    Spacecoast
    2022 White SR5 2.7L
    Be prepared for the dealer to say "it locks and unlocks, so there's no problem". Just saying. Hope they are willing to investigate since that sound is not normal. Let us know how it goes and what they find if they do any repair.
  5. Sep 19, 2022 at 9:40 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    My driver rear does the same, was pretty loud a couple months ago but now its pretty quiet.
  6. Sep 20, 2022 at 3:54 AM
    kjd99
    kjd99 [OP] Member
    Connecticut
    21 SX
    I’ll update when I take it to the dealer.
  7. Sep 20, 2022 at 11:30 AM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Just listened to mine before starting or driving and it makes a similar sound. I then started the vehicle and no more sound. Possible low battery.
  8. Sep 20, 2022 at 11:32 AM
    kjd99
    kjd99 [OP] Member
    Connecticut
    21 SX
    The noise comes and goes w/ my tacoma, regardless of if the truck is running or not. I don’t get it, I have an appointment in few weeks for the dealership to take a look.
  9. Mar 6, 2024 at 7:01 AM
    Leek300
    Leek300 Member
    Mines making the same noise, did you ever get this fixed/resolved?
  10. Mar 6, 2024 at 7:14 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    2011, same sort of noise since new.
  11. Mar 6, 2024 at 7:48 AM
    kjd99
    kjd99 [OP] Member
    Connecticut
    21 SX
    I ended up taking the truck to the dealership and was told - “since it’s locking and unlocking what’s the big deal?”
    Since I despise random noises that my truck makes, I took apart the door card. And I watched the locking unlocking mechanism to see what was making the noise, and there was an obstruction between the solenoid and the extending rod, twas a piece of loose rubber.
  12. Mar 6, 2024 at 7:50 AM
    kjd99
    kjd99 [OP] Member
    Connecticut
    21 SX
    Unsure about what may be causing it in a second gen, but I took off the door card and watched unlocked/locked to see what was causing the issue. There was a piece of loose rubber wedged between the solenoid and the rod.
  13. Mar 6, 2024 at 8:02 AM
    Leek300
    Leek300 Member
    Wow dealership didn’t even bother to look.
    Did you have to remove the rubber or adjusted it? And did it resolve the noise when locking?
  14. Mar 6, 2024 at 8:11 AM
    kjd99
    kjd99 [OP] Member
    Connecticut
    21 SX
    Only thing the dealership “helped” me with was telling me how to remove the door card if I wanted to do something about it :mad:. And all I had to do was gently pull the rubber lining from where it was situated and put it back in place, the whole thing took maybe 45 minutes. The biggest P.I.T.A was ensuring I didn’t snap any of those cheap plastic clips that hold the door card in place.
    Leek300[QUOTED] likes this.
  15. Mar 6, 2024 at 10:28 AM
    Leek300
    Leek300 Member
    Those damn dealerships.
    Hmmm thats good to know. Longshot but did you happen to take any pics of the rubber when you did it?
  16. Mar 6, 2024 at 10:39 AM
    kjd99
    kjd99 [OP] Member
    Connecticut
    21 SX
    I’ve unfortunately upgraded my phone since that predicament and if I did, they’d be on there. Whenever I’m off work I’ll open it up and see, I’d like to think I took a photo of it but I’m not sure.
  17. Mar 6, 2024 at 10:49 AM
    Leek300
    Leek300 Member
    No worries bro. Ironically, the noise went away after unlocking/locking multiple times But I’m gonna keep my ears open for that noise
  18. Mar 15, 2024 at 6:42 PM
    vinegarboy89
    vinegarboy89 Member
    Was the loose rubber by the door handle or behind the plastic sheet? Would it be a long term issue if nothing is done? I’m hoping it will go away on its own too, but hearing it just concerns me and makes me upset that I’m experiencing “issues”.
