Passenger airbag "off" light always on.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hazard2600, Feb 14, 2017.
  1. Feb 14, 2017 at 2:24 PM
    hazard2600
    hazard2600 [OP] Well-Known Member
    Ted
    Watertown, TN
    2009 White 4x4 SR5 TRD Sport LBDC V6
    3" ProComp sus lift 2" Roger Brown body lift 33" BFGs ko2s 1.25" spidertrax wheel spacers Custom rock sliders Seat covers USB ports OBD2 computer monitor
    has anyone had a problem where their passenger side airbag light is stuck in the off position?
    I've tested it out by sitting on the seat and buckling in the seat belt. But it stays "off". I weight about 170 so it should work for me;)
    Btw, I have the '09 dbcb so there isn't an on/off switch for it.
    Any thoughts?
    wannabemtnbiker likes this.
  2. Feb 14, 2017 at 2:26 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Is there a reset procedure in the owner's manual? Just askin...
  3. Feb 14, 2017 at 2:39 PM
    hazard2600
    Ted
    Watertown, TN
    @Skrain thank you for the thought. Page 103 sit buckled in the seat and slide the seat all the way towards the rear of the cab.
    I did this a couple times and the "on" light came on! :D
  4. Feb 14, 2017 at 3:04 PM
    Skrain
    Monticello, Ky
    2009 F.J. Cruiser
    Sounds like the sensor that determines when someone is in the seat might have a loose electrical connection under the seat somewhere, and moving it around got it to make contact. Glad you got it sorted out! :)
  5. Feb 14, 2017 at 3:25 PM
    JadedTaco
    JadedTaco Well-Known Member
    IA
    15 OR SSM (MT)
    Lift, tires, mats, blah, blah, blah...
    I had the same problem. I checked the plugs under the seat and everything was fine. Finally took it in and they said a something was unplugged behind the glove box.
    Not sure if you have one, but a seatbelt clip extender on the passenger side will also make the light stay on.
  6. Feb 14, 2017 at 3:36 PM
    JadedTaco
    IA
    15 OR SSM (MT)
    TBH, I'm not sure if it really was a clip behind the dash or if they were just bullshitting me. I pulled my passenger side seatbelt extender off as I pulled into the dealership. When I put it back in the next day, I noticed the light came back on.
    So, they were either lying to me, or it was both the clip behind the glove box and my seatbelt extender. I've never heard about an airbag clip behind the glove box and they never showed it to me, so I'm not sure.
  7. Dec 14, 2018 at 6:13 AM
    mreen428
    mreen428 Well-Known Member
    Shmatty
    Queens, NY
    11 DCSB TRD Spt
    Older post I know, but I had a seat belt extender plugged in all the time bc my dog sits up front sometimes. Air bag off was always illuminated. I unplugged the extender and the air bag off light turned off.
