Passenger Airbag light off and seat belt light flashing.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by keiro369, Jan 7, 2021.
  1. Jan 7, 2021 at 2:43 PM
    keiro369
    keiro369 [OP] Member
    Cameron
    Hi all,
    My passenger airbag light says it is off in the center console, as well as has the flashing seat belt light. The light stays on the driver's side cluster panel as well. Reading the manual it said there is a malfunction in the system. I unplugged the yellow connector under the seat, nothing. I took the seat off, unplugged all the connectors, checked them and looked good. Put it back on. Tried sliding the seat back and fully forward multiple times and still nothing to get the light to go away. Not sure where to go next, and like in my previous leak issue I am 3 hours away from the nearest Toyota dealership so anything helps. No codes at all when I hooked up my OBD reader.
    Update: did some shot gun troubleshooting. Turned RSCA off to see if that would reset it for me since I do not have the key to reset the airbags next to the passenger air vent and still nothing.
  2. Jan 7, 2021 at 3:33 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    What year is your truck?
    Does it have the On/Off switch that you operate by using the Key?
    I can’t remember, but I think the light only flashes if someone is in the seat and seat belt is not buckled?
    It sounds like the occupant classification sensor may be bad?
    Jimmyh likes this.
  3. Jan 7, 2021 at 3:35 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    OP's profile shows 2011 Tacoma DCSB.
    TnShooter likes this.
  4. Jan 7, 2021 at 3:39 PM
    keiro369
    Cameron
    It does not have the ON/OFF switch, the manual said that it was located under the passenger inboard air vent, took the panel off and there wasn't anything there. It is a 2011 off-road.
  5. Jan 7, 2021 at 3:42 PM
    JasonLee
    15 TRD OffRoad
    That switch is only for the regular and Extended cab. With a double cab, you're supposed to put smaller passengers and kid seats in the back seats.
  6. Jan 7, 2021 at 3:45 PM
    TnShooter
    Deogee
    STOCK
    If that is the case, then maybe the water that is leaking in could be causing your problem?
    Maybe it’s leaking onto the switch?
  7. Jan 7, 2021 at 5:38 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If you have nothing sitting in the seat then it could be a problem with the passenger occupant detection weight sensors in the seat, occupant detection module itself, wiring, or the airbag module. Since you had a water leak I'd look really closely at connectors and modules for water intrusion and corrosion (disconnect battery when unplugging or unbolting connectors and modules), if you can't find anything your gonna need someone with a scanner capable of airbag system diagnostics to proceed.
    Jimmyh, TnShooter and DoVeR TaCo like this.
  8. Nov 15, 2023 at 3:54 PM
    JDE
    JDE Well-Known Member
    Jacob
    2014 Silver Tacoma TRD Sport
    Camburg Kinetic UCAs King Extended Travel OEM Coilovers w/ RR Deaver J66 Leaf Springs King OEM Rear Shocks 16" Double Standard Method Wheels 33" BFG KO2 Tires
    Any update/solution? I have the same symptoms after going a little hard on my last off-road trip
