Part shopping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by freiejer, Apr 7, 2025.
  1. Apr 7, 2025 at 9:13 AM
    freiejer
    freiejer [OP] Member
    Jeremy
    Trd off road
    3d printed cup holder
    Hi i just bought my first toyota and its a 2015 tacoma trd off road. So far i love it but as with all used vehicles it needs work. When looking for parts nhtsa says it is a delux model and when looking for parts usually see base, trd pro and pre runner. What one do i select. TIA!
    Jmack69 likes this.
  2. Apr 7, 2025 at 9:47 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I've had my 2010 since 2016 and I'm still not sure and all I know it is not a TRD. All I now for sure it is 4.0, auto, SR5, 4x4, and an extended cab. I try and use the S/N when ordering parts.
  3. Apr 7, 2025 at 9:52 AM
    freiejer
    Jeremy
    Trd off road
    I have read in forums and by dealers is trd off road will have a diff button and cloth interior which i have. They sure make it difficult! Thank you i will try that too!
    just made an account with toyota and entered my vin it is a base gives me a lot of other information too
  4. Apr 7, 2025 at 10:05 AM
    freiejer
    Jeremy
    Trd off road
  5. Apr 8, 2025 at 10:40 AM
    Clearwater Bill
    Billy
    Largo Florida
    Most parts are the same across all models
    4wd vs 2wd, v6 vs l4, auto vs manual are big distinguishers
    What are you looking for?
  6. Apr 8, 2025 at 10:45 AM
    freiejer
    Jeremy
    Trd off road
    I am starting to see that. I Want to refresh the suspension the front is bouncy on the left side and the rear springs are flat.
    want to put in the heavier springs in the rear. I also do not want to stray to far from factory lift.
  7. Apr 8, 2025 at 1:17 PM
    Clearwater Bill
    Billy
    Largo Florida
    Flat or flat-ish springs are common. May or may not need replacing, depending on how you will use the truck.
    Miles?
    Use?
    I'd start with a 4 shock replacement. Even if you need springs, with a no lift goal, there is no risk in doing the shocks first
    All 6 lug 2nd and 3rd gens can fit the same shocks even though different models come with different shocks. Leaf springs are the same fitment.
  8. Apr 8, 2025 at 1:19 PM
    TacoTuesday1
    FL
    To my knowledge
    pre runner is 2wd
    Base is 6 lug
    Pro is pro
    never heard of “delux model”
  9. Apr 8, 2025 at 6:07 PM
    freiejer
    Jeremy
    Trd off road
    I looked that up on the nhtsa vin decoder it is a free decoder for any vehicle sold in the USA also works on atv’s, motorcycles and boats.
    it has 160,000 going to use mostly to haul my atv’s and tent camping
  10. Apr 9, 2025 at 12:49 AM
    Clearwater Bill
    Billy
    Largo Florida
    Post 4 is the right answer. Other sources are agrigators at best and may or may not be accurate.
    @memario1214 is good for advice and parts via hotshot offroad
  11. Apr 9, 2025 at 11:51 AM
    lowmower
    lowmower Well-Known Member
    Benji
    2011 Pyrite Mica V6
    What's the VIN? I can look it up here at my dealership.
  12. Apr 10, 2025 at 12:30 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    The dead giveaway for a TRD Offroad: it will have a 4 channel hydraulic brake booster under the hood, on the driver's side firewall, instead of a standard booster.
    Other trucks will not have it (maybe the Pro in years it was offered. I don't know that for certain). The Sports had a slightly larger rear diff and a hood scoop. My TRD OR shows as a "base" in various places, as does a friend's 2011 TRD Sport. The nomenclature is not always consistent.
    If it's 4x4, you'll want 4x4 parts - some parts are the same for all trucks, but 4x4 and RWD are major differences for a lot of parts (drivetrain parts, front suspension). Ditto the hydraulic brake system for the TRDOR.
