Part number for floor mat retention clip
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hunter5150, May 24, 2022.
  1. May 24, 2022 at 8:30 AM
    hunter5150
    hunter5150 [OP] Well-Known Member
    Tony
    So Cal
    2021 SR5 Trail Edition - AG
    The car wash guy broke the floor mat retention clip on the passenger side. I found something on eBay that might be the correct part.
    https://www.ebay.com/itm/163974792905
    But, they are selling for $23. That's alot for a couple pieces of plastic. The part number is partially covered. It ends with 78010. I am trying to see if I can find it cheaper elsewhere. Anyone know if this is the correct part for my 2021 and the complete part number?
  2. May 24, 2022 at 8:36 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Buy aftermarket from Amazon:
    https://www.amazon.com/AZERONE-Carp...locphy=1026451&hvtargid=pla-585826507116&th=1
  3. May 24, 2022 at 8:46 AM
    hunter5150
    Tony
    So Cal
    Thanks. Kinda want to get a direct replacement, even if it is aftermarket. Not sure how the ones from Amazon would fit.
  4. May 24, 2022 at 8:50 AM
    Borracho Loco
    DFW, Texas
    They're universal. You don't need OEM Plastic clips for the floor mats on your truck. But if you want to spend 4-5 times the amount just so it can say "Toyota" on it.... go for it.
  5. May 24, 2022 at 8:51 AM
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    For OEM, it is a two piece set.
    58694-76010 for the part above the carpet.
    58698-76010 for the part below the carpet.
    I used these to add them to the passenger side.
    hunter5150[OP] and Borracho Loco like this.
  6. May 24, 2022 at 9:03 AM
    hunter5150
    Tony
    So Cal
    Thank you both for your help.
  7. May 24, 2022 at 9:09 AM
    Rainoffire
    If you are looking for the same ones as your Ebay link, they would be 58694-78010 & 58698-78010. They might be a newer version, since it is 78010 vs 76010.
    For me, the 76010 looks identical to the one already in my truck.
    I got them from McGeorge Toyota, for 2 of each, it ended up being around $15 for the set.
  8. May 24, 2022 at 9:15 AM
    hunter5150
    Tony
    So Cal
    I think I only need the top piece. It is only $2. I will order it and see it goes. Thanks again.
  9. Mar 29, 2025 at 12:42 PM
    scottmen
    scottmen New Member
    Scott
    2022 Lunar Rock Tacoma TRD Off-Road
    Does anyone know the part number for the part on the actual floor mat?
