part# for interior 4-wheel drive selector switch
Discussion in '3rd Gen. Tacomas (2016-2023)' started by _matt_IRL, Mar 6, 2021.
  1. Mar 6, 2021 at 7:30 PM
    _matt_IRL
    _matt_IRL [OP] Member
    matt
    Mountain House, CA
    2021 Army Green TRD Off-Road
    Stock AF
    I tried to change the trim ring around my 4-wheel drive selector on my 2021 tacoma using the AJT trim ring.
    I was unsuccessful getting the OEM piece off so i reassembled it and now the selector is not functioning properly. it’s very lose and will easily switch to 4-hi.
    i researched but i couldn’t find the part number.
    does anyone have the part# for the 4-wheel selector for a 2021 tacoma? i need to order one so i can replace the one that’s not functioning properly.
  2. Mar 6, 2021 at 8:12 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Sounds like you lost the small plastic nub that was located behind the small spring. @MESO might have some recommendations on how to repair and what to replace it with.
  3. Mar 6, 2021 at 8:13 PM
    Cloaked
    Cloaked Well-Known Member
    There is a thread in this forum in the sticky section where a member is quite knowledgeable about a lot of parts. If he can't find it, you don't need it. :) :)
  4. Mar 6, 2021 at 8:19 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    See note #2 in the first quote...
    _matt_IRL[OP] likes this.
  5. Mar 6, 2021 at 8:28 PM
    _matt_IRL
    matt
    Mountain House, CA
    Stock AF
    I have lost that nub and it is nowhere to be found. At this point I just need the correct part#.
    On part.toyota.com they show the part# to be 842230C010
    So when I do a search for the cheapest price it will take me to TRDshop.com (https://trdshop.carlocktoyotaoftupelo.com/oem-parts/toyota-select-switch-842230c010) but that site says the part# does not fit 2021 tacoma.
    I'm wondering if that's just because of the new model year.
  6. Mar 6, 2021 at 9:54 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    That is the correct part number, nothing has changed between the 2021 and older 3rd gen models when it comes to the transfer switch. The same thing is shown for the TRD Air Intake.
    But, hopefully you can find the missing piece and rebuild rather than purchase a whole new switch.
  7. Mar 7, 2021 at 12:55 AM
    _matt_IRL
    matt
    Mountain House, CA
    Stock AF
    unfortunately no luck on finding the little nub.
    Ordered the selector online from my local toyota dealer. $140
  8. Mar 7, 2021 at 2:44 PM
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    If it were me, I would try to improvise something. It looks like you need a detent, like a small ball bearing. How about trying a single bead snipped from a beaded chain (the kind that's attached to ceiling fans or bathtub drains)? You have nothing to lose.
    Skydvrr likes this.
  9. Apr 4, 2021 at 6:48 PM
    Mowmax
    Mowmax New Member
    Tyler
    2021 silver Tacoma trd sport
    Wheels grill
    Just wondering if this new switch fixed the problem I did the same thing
  10. Apr 4, 2021 at 8:48 PM
    _matt_IRL
    matt
    Mountain House, CA
    Stock AF
    it sure did. it’s plug and play. since i knew what the problem was i was able to install the new trim piece and transfer over the detent pins. l
  11. Apr 4, 2021 at 8:53 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Someone in the @MESO thread improvised a piece. Idk how well it worked though
  12. Apr 5, 2021 at 1:10 AM
    Mowmax
    Mowmax New Member
    Tyler
    Wheels grill
    Heck yeah man awesome I’ll probably just put the new switch in and be done with it I’m scared to take it apart now
  13. Apr 5, 2021 at 7:01 AM
    NoVa TRD Sport
    Alexander
    Northern Virginia
    Leer cap
    I took my 4x4 switch apart to replace the chrome ring. In doing so, I noticed that the little detents were held in place by a very thick (viscous) grease. I even turned the switch upside down and shook it to see if they would fall out. They didn't. So, the conclusion is that it's very difficult to lose the detents. But if you do so, it's easy to improvise a detent. I certainly wouldn't pay $140 for a replacement switch just for this.
    Skydvrr likes this.
  14. Apr 5, 2022 at 11:37 AM
    CuriousMonkey
    CuriousMonkey Member
    2008 Tacoma 4x4
    Where does the ball bearing go? Mine fell out and I don’t know where it goes. Any pics? 2008 Tacoma 4wd selector housing.
