Parking lights turn on with DRL
Discussion in '3rd Gen. Tacomas (2016-2023)' started by oneup714, Jan 18, 2019.
  1. Jan 18, 2019 at 9:32 AM
    oneup714
    oneup714 [OP] Well-Known Member
    All show no go Super White Tacoma TRD Mall Crawler
    Hi guys, I recently installed some "raptor lights" on my TRD Off Road by tapping into the DRL wire. The toggle switch is off, DRL, parking lights, headlights. I have noticed when I toggle the switch to DRL my parking lights also come on (side ambers, rear lights, license plate) however my instruments inside do not turn on. If I toggle the switch to parking lights then everything works like normal along with toggling it in headlight. I have tried disconnecting the "raptor lights" to see if it would bring everything back to normal but it still does it. Any help would be appreciated thanks!
  2. Jan 18, 2019 at 11:39 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Not quite sure what you did there or what you mean by toggle switch but the raptor lights should come on with the parking lights “side marker lights” makes more sense to tap the purple and white wires coming from the side marker lights. Purple is hot and white is ground if I remember correctly
    oneup714[OP] likes this.
  3. Jan 18, 2019 at 12:10 PM
    Taquitoma
    Taquitoma Well-Known Member
    2017 OR DCSB M/T
    The DRL position on the stalk should only turn on the DRLs and nothing else. It's your 'daytime' setting for lights. When you select parking lights or headlights, that's when all of your parking lights and instrument lights should come on, those would be your nighttime light settings.
    If you're getting any other auxiliary lights coming on with DRLs, it's possible you messed up something with your wiring.
  4. Jan 18, 2019 at 1:28 PM
    oneup714
    Sorry if I wasn't clear, when I said toggle switch I meant the one that is on the steering wheel column that you click off, drl, parking light, headlight. When I clicked it to turn on the drl, the parking lights all come on as well but not the interior lights like gauge cluster. If I clicked it one more to parking lights then everything works from normal from then on. The "raptor lights" were tapped to the pink wire.
  5. Jan 18, 2019 at 1:34 PM
    oneup714
    I tapped the "raptor lights" into the pink wire of the headlight, the drl position before just turned on the drl and nothing else until I click it to the parking lights. After installing the "raptor lights" when I clicked it to the drl everything as mentioned above turns on except the actual headlights but non of the instruments turn on.
  6. Jan 18, 2019 at 1:38 PM
    Alden
    Alden Well-Known Member
    Alden
    Atascadero, CA
    2018 Cement Tacoma DCSB TRD OR AT 4x4
    Reverse the wiring modification you did and use an add-a-fuse to tap into your headlamp fuse. Then they'll come on with your headlights and it should reverse whatever you did to your current wiring.
  7. Jan 18, 2019 at 1:49 PM
    Ronzio
    Pennsylvania
    17 DCSB TRDOR
    In the auto position the DRL will be on regardless if it’s night or day but the instrument cluster will be not lit during the day because of the sensor on the passenger side of the dash. If you cover the sensor with your hand and turn the lights to off then back on while covering the sensor the instrument cluster will lite up in the auto position. In other words the gauge cluster is tied to that sensor on the dash.
  8. Jan 18, 2019 at 2:06 PM
    oneup714
    Yeah I will try to make time to pull everything out this weekend. Thanks
  9. Jan 19, 2019 at 9:14 AM
    Taquitoma
    2017 OR DCSB M/T
    I'm not familiar with the wiring for the lights, but from what I understand the stalks are more complicated than simple switches. So even if all you did is tap into a wire coming out, you could be confusing the whatever mini-computer is in the stalk. That said, I'm sure someone here has made a write-up of how they hooked up their raptor lights, maybe try a search?
    That's only for models equipped with auto headlights. From what OP said it sounds like he has the manual stalk.
    oneup714[QUOTED][OP] likes this.
  10. Jan 19, 2019 at 10:31 AM
    oneup714
    You are correct no auto, I have searched but everyone who install the lights will either work when drl is on it will turn off when the headlights are on and vice versa
  11. Oct 22, 2019 at 1:48 PM
    RockHed
    RockHed TTC #051
    Danny
    San Antonio TX
    2016 Black TRD Sport OnRoad 4x2
    Hey OP, just wanted to see if you ever got this figured out. Just installed mine and same thing is happening. But I do have the auto feature. Parking lights stay on at all times while truck is running.
  12. Oct 22, 2019 at 2:05 PM
    oneup714
    I just tapped into the pinkish wire of the headlight's harness and my problem was fixed
    RockHed[QUOTED] likes this.
  13. Oct 22, 2019 at 2:08 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    Just curious - where did you make the tap that screwed everything up?
  14. Oct 22, 2019 at 2:09 PM
    oneup714
    I tapped into the green and pinkish one at the same time, I wanted the raptors lights on at all times but I like it where I have the option to leave it off by not turning on the parking lights
  15. Oct 22, 2019 at 2:14 PM
    RockHed
    RockHed TTC #051
    Danny
    San Antonio TX
    Will this only turn the raptor lights on when headlights are on?
  16. Oct 22, 2019 at 2:15 PM
    oneup714
    it will turn on in "parking" and when headlight is on
    RockHed[QUOTED] and Gunshot-6A like this.
  17. Oct 22, 2019 at 2:22 PM
    RockHed
    RockHed TTC #051
    Danny
    San Antonio TX
    Thanks :thumbsup:
  18. Oct 22, 2019 at 2:31 PM
    PhenixFord
    Randy
    Arkansas
    Thanks.
    You can add features like this using switches and relays. But it would require some rewiring.
  19. Sep 23, 2021 at 2:01 PM
    plim11
    plim11 Active Member
    California
    2019 tacoma trd offroad 4x4
    were your tail lights and license plate lights on too? running into the same situation drls on, dash is off, rear lights are on. i have raptor lights as well and tapped a wire to the pink and one to the green wire of the headlight harness
  20. Sep 23, 2021 at 3:08 PM
    HIallday
    HIallday Well-Known Member
    Hilo
    2019 TRD OR
    The pink wire is parking the green is Drl. You are essentially connecting your parking lights to the Drl switch
