Parking lights and DRL
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Vinci, Jun 7, 2021.
  1. Jun 7, 2021 at 11:18 AM
    Vinci
    Vinci [OP] Well-Known Member
    Sarasota, FL
    '17 MGM Limited 4x4
    I drive with my parking lights on 95% of the time, with the other 5% of the time being when it's actually dark enough to use the low-beams. It seems I may not have noticed that the LED DRLs are run with a lower output in both the parking and low-beam light settings. I thought it was ONLY the low-beam setting that caused the DRL to dim.
    Is that the normal operation? Dimming in both parking and low-beam settings?
    If so, what would be a solution for having the DRL run at full power in the parking setting, but NOT with the low-beams on? A relay between the 12v lines to the DRL that triggers with the low-beam?
  2. Jun 7, 2021 at 1:08 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    When I had a 2018 with non-automatic headlights, the DRL's were still full power on the parking light setting. Maybe it's different with auto headlights...
    usmc2msu likes this.
  3. Jun 7, 2021 at 1:18 PM
    Crossgolf
    Crossgolf Active Member
    Your setup is normal. To get the DRL to turn on with all parking lights Get a DRL harness from Ali express or eBay. It senses the voltage of the battery to turn on the DRL. To dimm or turn off the DRL hook the sensor cable up to you low beams instead of the running lights.
  4. Jun 7, 2021 at 3:08 PM
    caribe makaira
    Caribbean, Puerto Rico
    Seems? Remove the plug to both headlights. Select Parking, look at DRL. Select Low beam, Look at DRL.
  5. Jun 7, 2021 at 3:38 PM
    Kairide
    Kairide Well-Known Member
    2020 White SR5
    Is there a reason you drive with your parking lights on 95% of the time? If you want 100% DRL, it seems common sense to just drive without your parking lights on. Unless you changed your head unit setting for the brightness level, isn't it really dark during the day and if you changed the setting, really bright at night?
  6. Jun 7, 2021 at 3:45 PM
    Vinci
    Sarasota, FL
    '17 MGM Limited 4x4
    This question came about because I swapped my lights out for Morimoto XBs. I never drove with DRL only with the stock lights, hence my question. I thought the difference might have been the lights at first, but I'm hoping to confirm or deny my theory before I tear into the harness.
    I like to have the lights on the back because my area is packed to the rafters with retirees and I want to be as visible as I can be.
  7. Jun 7, 2021 at 4:15 PM
    caribe makaira
    It's your XB lights.
    OEM have a high (bright) & Low (dim) input.
