Parking / emergency brake seized / stuck
Discussion in 'Technical Chat' started by rcsb jon, Jan 19, 2017.
  1. Jan 19, 2017 at 5:48 AM
    rcsb jon
    rcsb jon [OP] Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    Had my truck parked for ~4 days, went to drive it... no movement was possible. Wheels would not allow any movement. Truck stalled. Slipped the clutch. Nothing. Truck finally moved in 4x4 low range, made me realize the right-rear tire was locked.
    Took wheel off, drum moved ever so slightly to confirm the rearend was fine.
    Parking / emergency brake was seized. Beat on the drum nothing released. Called my friend, he said to:
    -Put parking brake ON
    -Move truck in reverse
    Worked great... no noise, no effort. Released the parking / emergency brake within an inch. The parking / emergency brake adjusts while it is ON and vehicle is in reverse. Hope this helps anyone with a similar issue.
  2. Jan 19, 2017 at 5:49 AM
    Jmad1997
    Jmad1997 Well-Known Member
    2005 TRD sport long bed 6" fab tech lift
  3. Jan 19, 2017 at 6:22 AM
    Jmad92
    Jmad92 Well-Known Member
    Justin
    Albuquerque New Mexico
    06 SR5 4x4 DCLB
    Icon stage 4 w/billet UCAs and 33"BFG ATKO2's
    Spot on. Having this similar issues as well. My wheels are not completely locking up but they are very difficult to get rolling in the mornings especially when it's cold out. Getting my brakes replaced this weekend and gonna check for that problem in my E brake as well. After theee shops including dealer looked at it they had no idea what was causing that and told me " normal for a 2006 with the miles that's on it" clearly not normal. Just glad someone else had this problem and was able to resolve it. Good post.
    Nunya Bizness likes this.
  4. Jan 19, 2017 at 8:07 AM
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    That's a bummer. Hopefully the technique I used aids you as well.
  5. Jan 20, 2017 at 8:19 AM
    jv_74
    jv_74 Well-Known Member
    Jesse
    Filthadelphia
    2015 DCSB Silver Sky Metallic
    Great post!! I just had this problem and you saved me a lotta time
    Jmad92 likes this.
  6. Jan 20, 2017 at 1:05 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Any vehicle with the brakes locked will pretty much break loose in Reverse!!
    This works for frozen brakes as well
    Better lubricate the bell cranks and brackets or it will seize again
    DrFunker, CygnusX191 and Jmad92 like this.
  7. Jan 30, 2017 at 6:29 AM
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    Happened again. Didn't drive truck for 24hrs. Would not release in reverse this time. So I need to figure out what to do tonight.
    Interesting info from owners manual, pg 220.
    http://www.toyota.com/t3Portal/document/om-s/OM35A38U/pdf/OM35A38U.pdf
    2-5. Driving information Winter driving tips
    "When parking the vehicle Park the vehicle and move the shift lever to P (automatic transmission) or 1 or R (manual transmission) without setting the parking brake. The parking brake may freeze up, preventing it from being released. If necessary, block the wheels to prevent inadvertent sliding or creeping."
    ...Pretty sure this is absurd
    CygnusX191 likes this.
  8. Jan 30, 2017 at 12:35 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Why do you say that I have had that happen .
    Those warm days about 34 degrees F wet slushy snow freezes solid when temps drop to 20degrees
    I am thinking your bell cranks are hung up in the brackets .
  9. Jan 30, 2017 at 6:40 PM
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    No issues were noticable
    Brake cleaned both sides. Was nice to begin with... Only 30k mi on truck
    This time it was the driver's side. 2 weeks ago it was the passenger's side.
    CygnusX191 and Rambo54 like this.
  10. Mar 20, 2017 at 8:08 PM
    Myz250f
    Myz250f Well-Known Member
    daniel
    New York
    exhaust, headlight bulbs, k&n intake, programer, toytec boss front coil overs, toytec boss rear shocks, sway bar relocation, Dakar leaf pak, oc taco extended stainless steel break lines (red), kicker component front speakers, kicker 2 way rear speakers, pioneer head unit, mtx thunder amp, reverse light bulbs
    i am having the same issue. before i was able to get it unstuck by using reverse with light brake pressure. tonight it was 100% locked up. i have not used my parking brake and it is not frozen due to cold weather as i was able get it to release for several feet. i mad what seemed at the time to be a smart move and cut the e brake cable. no fix.
    i am thinking its the rear brake cylinder/ caliper not functioning correctly.
    also this truck is an 07 trd off road 4x4. i replaced the rear brake hardwear about 5k miles ago (installed and greased everything properly)
  11. Mar 21, 2017 at 1:57 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    The Arm where the Parking brake cable attaches is called the Bell Crank it has a steel pin going through a aluminum housing this is the bell crank bracket .
    The pin tends to corrode to the point it will not move at which time the shoes may be in contact with the drum
    They can get to the point I needed to cut the bell crank bracket apart to reuse the other parts
    When doing rear brakes one should make sure the bell crank moves free in the bell crank bracket .
    I never seize the pins
    CygnusX191 and Tacos4ever15 like this.
  12. Apr 5, 2018 at 7:19 PM
    07toytaco4x4
    07toytaco4x4 Member
    Curtis
    Baxter Springs, KS
    07 access cab tacoma
    Toytec Ultimate Lift kit: Toytec 5100 adjustable coilovers and 700lb springs on the front Aluma 2.0 IFP rear shocks with progressive 3 leaf AAL pack front diff drop 33 inch Mastercraft MT tires
    Had a panic moment out in the middle of nowhere doing some off-roading by myself (first mistake). I stopped along the trail to scope out a rough patch, put the truck in neutral (manual tranny) and pulled the e brake. When I got back in the truck it wouldn’t move. After some investigating I narrowed it down to the e brake freezing up the back end. After reading this thread I banged on the drums and rocked the truck back and forth and finally got the brake to let go. Thank god.
    There was no way I was gonna get a tow out on a trail that’s primarily for side-by-sides and 4 wheelers .
    I’ll probably change out the rear brakes this weekend and inspect everything for damage. I really hope this fixes the problem.
  13. Nov 15, 2018 at 7:56 PM
    Allinqhicksand
    Allinqhicksand Member
    Just had this happen to me for the second time. The first time it realeased after 15 mins of moveing the truck bank and forth however this time no luck, even after 45 mins of trying. It seemed like there were moments were it released but would engage again so I’m starting to think this might be something else. Any advice on what to check for? This is happening on my 2017 MT OR only got 47k miles.
    CygnusX191 and ANTHONYK0928 like this.
  14. Jan 11, 2019 at 4:30 AM
    Brucenemours
    Brucenemours Member
    Bruce
    Lorton, VA
    2016 Toyota Tacoma TRD Off Road 4x4
    It seems its a more common problem than I would hope. Last night I disengaged my parking brake and gave it some gas to drive off but the vehicle would not move. I quickly realized the brake did not disengage and was causing much resistance on the rear axle. I was able to disengage it with reversing the vehicle. I only had about 1/4 to drive before I was home and this time I did not engage the parking brake. The next morning about 4 hours later I got to my truck to head to work and the same issue occurred. I checked all the brake lines and everything looks fine. Reversing the vehicle was able to fix the issue again. Any clue as to why this happened again even without engaging the parking brake the second time? I plan on pulling the wheels this weekend and getting in there to see what's the matter. Any suggestions on what I need to pay particular attention too or possible fixes would be appreciated! Truck is a 2016 TRD OR 4X4 with 43k miles.
  15. Jan 11, 2019 at 4:45 AM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    Is it possible that this has something to do with the antilock brake system? The above post is strange, locked without e-brake even on. Is it still a manual brake or an electric one like Subaru?
  16. Jan 11, 2019 at 5:27 AM
    Allinqhicksand
    So since I’ve had my issue twice in the last two months I’ve decided to not use my parking brake when the temp gets below 35 that being said I did find mouisture in my parking brake cable which I believe is freezing when ever it’s engaged for sometime when it gets bellow freezing. Even last night when I parked outside an airport and wanted to help my in-laws load their bad just from the truck sitting with the brake not engaged it popped when I engaged it temp was around 18 when I left my home to the air port (brake was not engaged)
    What do you think about this moisture I found on the cable? How can I dry it out? 9A25D1D0-FB75-4E9A-B608-924EAB0AC0D7.jpg
  17. Jan 11, 2019 at 6:21 AM
    Troyken
    NY
    If you can get to the other end of the cable.... Disconnect it, elevate it, attach a small funnel and pour some antifreeze in it and let it penetrate. Of course, watch where it drips on the ground, we don't want a toxic hazard. It works for seized outboard motor control cables, it may work here. You will need to find out where water is getting into the cable. Even if you can get WD-40 into the cable it will help.
    Edit; make sure it doesn't run onto the brake shoes!!!!
  18. Feb 19, 2019 at 9:25 AM
    Newfiebruh
    Newfiebruh Well-Known Member
    Tom
    2010 Black sand pearl access cab Base
    LED's, Tonneau cover, Fog lights, Front mud flaps, Cooper discoverer a/t3 tires, Tailgate reinforce, Cruise control, LED ditch lights, Bluedriver, 8-ball shift knob, Hitch, SR5 grille.
    I’ve been having the same thing for a while now. Worst case I had was I was parked in my driveway and it froze (summer) it releases when the breaks are pushed in hard and in reverse. Anyways I hooked up the camper and went to the supermarket for supplies (didn’t apply the brake this time) when I went to leave and started driving the wheel locked up at around 15km/hr causing me to skid to a stop and have an audience staring at me like wtf ? No idea what causes it but I don’t use the parking brake anymore
  19. Mar 8, 2019 at 12:22 PM
    Waveydavey
    Waveydavey New Member
    David
    2007 trd sport 4x4 crew lb automatic
    Most likely what happened to my cables - corrosion. Expensive to replace.
  20. Mar 8, 2019 at 2:25 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Other then snow being packed around the intermediate lever or the rear axle at the pivot or the bell cranks packed in snow.
    I have never had it freeze then everything is only about 80,000 miles old it gets used every time I park the truck
