Parasitic draw
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gjr003, May 14, 2020.
  1. May 14, 2020 at 2:39 PM
    Gjr003
    Gjr003 [OP] Well-Known Member
    I know this has been asked before but most of the websites and videos I’m watching are over my head.
    I just replaced my battery and it died after two weeks. Battery checked out good at O’Reillys when I went back this afternoon. I got out my multimeter and the battery is currently a 12.5, when the car is on w/o a load it’s in the high 13s and with radio, lights and light bar it’s 13. So, I think my alternator is good enough.
    I tried to do a parasitic draw test, but I don’t think I’m doing it right. I disconnected my negative terminal and set up the multimeter as pictured I then touched the negative lead to one end and the terminal to the other of my multimeter. On the attached settings the drain was .5 which I think is acceptable if I set up the meter right.
    If so why is my battery dying so fast?
  2. May 14, 2020 at 2:43 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Assuming you have cleaned everything up and replaced the cables (making sure they are routed correctly) try disconnecting the negative for a few days and see what happens to the battery. If it remains good, then you have something drawing, not unusual on newer vehicles, or a short somewhere. The short could even be intermittent happening only when you are driving.
  3. May 14, 2020 at 2:46 PM
    Clearwater Bill
    Billy
    Largo Florida
    Any aftermarket wiring done? Auxiliary lights? Stereo changes?
  4. May 14, 2020 at 2:48 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    My wife's Highlander has a parasitic draw that I'm 99% sure is the Autostart but I haven't disconnected it yet. If she drives it every day, it's fine but if it sits all weekend, it'll be dead Monday morning.
  5. May 14, 2020 at 2:53 PM
    n6vmo
    n6vmo Well-Known Member
    Sahuarita, AZ
    2018 DCLB OR AT Super "Priviledged"
    Bilstein 6112, ICON UCAs, 5160, AAL, 265/75/16 Falken Wildpeaks
    1/2 amp of parasitic draw sounds high to me. Although I've never tested mine. Maybe someone can chime in about the normal parasitic draw on the 3rd Gen.
    With your meter connected as you did, pull fuses one at a time and see what is drawing that much current. Curious as to what is doing that.
    Early Man and SR-71A like this.
  6. May 14, 2020 at 2:55 PM
    Gjr003
    I have three aftermarket items, a Caliraised Lightbar, N2 Designs Remote Start w/ module, and the Camper Shell. I know my lights aren't on in the camper shell and I pulled the fuse on my light bar and nothing. I am not sure how to check the Remote Start, but I have had that for over a year. I haven't driven my car much since COVID19, so I could have been masking the problem.
    Did I actually do the draw test correctly? Is .5 acceptable on those settings?
  7. May 14, 2020 at 2:57 PM
    n6vmo
    Sahuarita, AZ
    I believe you did....
    Disconnect the neg from the battery, put the black meter lead on the neg cable and the red meter lead on the neg battery terminal.
    I did a simple calculation with some generic battery assumptions and with that draw of 0.5 amps, the battery would be dead in 25 days, if you didn't drive it.
    ericvega likes this.
  8. May 14, 2020 at 3:01 PM
    Timmcc02
    Timmcc02 Well-Known Member
    Tim
    2017 TRD OR
    Definitely way high. I think bmw spec for current draw is >40milliamps but I haven’t looked up the spec in awhile. I know it’s definitely less than 100milliamps
    MOC221_ and davidstacoma like this.
  9. May 14, 2020 at 3:03 PM
    Timmcc02
    Tim
    2017 TRD OR
    It’s likely that remote start disconnect it with your meter reading the current draw and will probably go down
    Joe23 and davidstacoma like this.
  10. May 14, 2020 at 3:04 PM
    Loco_Barbon
    Loco_Barbon Just deez nutz hangin’ out
    Hugh Mungus
    Where ever my 10mm isn’t
    i LiKe tRuCkS!!
    Penis valve stem caps.
    .5 seems high to me as well. Like n6vmo said, with the multimeter connected the same way start pulling fuses and relays one at a time, wait 5 or 10 seconds and see if the draw tapers off. That's the best way to narrow it down to one or two circuits. Also I would double check your alternator, with my truck running and all my lights on i get 14.2 volts.
    MOC221_ likes this.
  11. May 14, 2020 at 3:06 PM
    Timmcc02
    Tim
    2017 TRD OR
    Important note on your testing strategy make sure all door latches are closed even with the doors open which you can do with a screw driver and lock the vehicle so that the control modules can go to sleep or your readings won’t be valid
  12. May 14, 2020 at 3:10 PM
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    I've done this on other cars, the draw can stay high for a good 10 minutes before it settles down.
    At .5 amps, you're drawing 12 amps a day. Battery could be dead in short as 4 days. Would want to run your engine at least once a day.
    davidstacoma likes this.
  13. May 14, 2020 at 3:18 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Typical amp-hours for a standard battery is around 45 amp-hrs, with a 1/2 amp draw ya got less than 90 hours till she’s totally dead. (Don’t use cold cranking amps to calculate that’s just an instantaneous crank rating, nothing to do with capacity).
    Read every post in this thread linked below and you’ll have your answers, also another post said close your doors and hood when testing I have no comment regarding that but if you have a key fob take it far away and wait a couple hours to see if the drain current drops like it has for others.....
    https://www.tacomaworld.com/threads/ma-draw-w-truck-turned-off.644085/#post-22305363
  14. May 14, 2020 at 4:14 PM
    Gjr003
    I got it, so i was doing a couple of things wrong. I appreciate all the suggestions.
    I disconnected my battery and put my multimeter in between the terminal and negative cable. I don't have small enough clamps so I was reconnecting every time. Biggest thing was I was not waiting for the volts to drop. Its almost 30 seconds to get back to baseline. Once I figured that out, I pulled my GPS Remote Start and waited 30 seconds it dropped down to .04 Amps or 40 ma. The Remote start was using 250 ma of power at rest. When I tested this the first time I was waiting for about 15 seconds and it would sit at 50. I am guessing there are some initial start up modules that draw power that need to calm down before an accurate reading is produced.
    MOC221_, hr206, Timmcc02 and 2 others like this.
  15. May 14, 2020 at 4:18 PM
    davidstacoma
    David
    NC
    You got it. If you didn’t have something on or a door not fully closed, you may have a faulty new battery. You didn’t mean two weeks without driving it did you? That can do it too lol
  16. May 14, 2020 at 4:53 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Looks like your meter is set to AC amps, not DC.
    Knute and Lawfarin like this.
  17. May 14, 2020 at 4:55 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Anything over .06 amp is a current draw
  18. May 14, 2020 at 4:56 PM
    Timmcc02
    Tim
    2017 TRD OR
    Amps is amps. There is no ac/dc amps
  19. May 14, 2020 at 5:03 PM
    mutely
    Joe23 likes this.
  20. May 14, 2020 at 5:31 PM
    Gjr003
    I think I only drove it once or twice since I got the new battery, I have been working from home. Now I probably need a battery maintainer or a portable jumper... its a pain in the neck to use my wifes car.
    davidstacoma[QUOTED] likes this.
