Parasitic battery drain
Discussion in 'Technical Chat' started by JDKred, Jan 1, 2021.
  1. Jan 1, 2021 at 5:29 PM
    JDKred
    JDKred [OP] Well-Known Member
    JD
    16 MT KDMax Tuned
    Hello, Hope this is the correct place for this question
    First question is: can doing this test wrong damage the vehicle electrical system? From what I gather, the multi meter will be damaged first (acting like a fuse in a way)
    Second, if there are small sparks when connecting the leads from the multimeter to the battery terminals, I assume the mulimeter got fried?
    Thanks for any help
  2. Jan 1, 2021 at 5:33 PM
    JDKred
    JD
    16 MT KDMax Tuned
    I connected in line with the negative battery cable but forgot to move the leads to the 10A comm port. Got a few small sparks. I assume that fried the multimeter :frusty:
  3. Jan 1, 2021 at 5:47 PM
    JDKred
    JD
    16 MT KDMax Tuned
    Thank you. I figured something might be wrong when I keep trying to do the test and was getting no values. Appreciate your help
    Also. I have been in the market for a better meter. I bought some cheap on on Amazon a few years back. I have been looking at a Klein MM400. Is this a good one or perhaps one recommended?
    Thanks again.
  4. Jan 1, 2021 at 5:48 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Damn Parasites :annoyed:
  5. Jan 1, 2021 at 7:08 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    A clamp on amp meter works well too just make sure it's rated for DC and not AC only. Also when chasing drains it's better to test across fuses with a voltmeter set to mv instead of pulling fuses as pulling fuses can "wake up" modules on newer vehicles.
    JDKred[OP] likes this.
  6. Jan 1, 2021 at 9:23 PM
    adamant365
    adamant365 Well-Known Member
    Adam
    Kentucky
    '09 SR5, DCSB, 4x4
    I just received the MM400 for Christmas. Haven't put it to much test yet, but it is fast, has several useful functions, has auto-ranging and is built solidly. The audible continuity beep will definitely come in handy. You can ignore most of the negative Amazon reviews because they are idiots that don't know you can remove the shields on the tips of the probes. The shields are for use in high voltage (Cat III and IV) situations and can be removed for most home and auto applications.
    JDKred[QUOTED][OP] likes this.
  7. Jan 2, 2021 at 6:45 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just what kind of drain do you have?
    Drains the battery flat over night??
    Your always going to have the radio memory and clock and ecm given enough time it will drain the battery
    Dm93 likes this.
  8. Jan 2, 2021 at 6:54 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Back a long time ago.....when analog clocks first landed in the dashboard......parasitic battery drain began.
    Modern vehicles have Computers to control everything, Digital Head Units connected to the world, remote starts, alarms, clocks.......
    You will find parasitic drain on any modern vehicle.
  9. Jan 3, 2021 at 3:17 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    How did this play out ?? It would be nice to know ?
