Painting your own sliders?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SkinnyP2, Jan 17, 2019.
  1. Jan 17, 2019 at 10:54 AM
    SkinnyP2
    SkinnyP2 [OP] Millennial Wise Guy
    18 Offroad Chuck Norris Edition
    I decided to get a set of sliders, and am still on the fence whether I should pay an extra $120 for powder coat or just use self etching primer and some black rust oleum or rattle can black.
    The sliders will see mild off-roading and are just bolts ons so they’re more for protection from door dings.
    Anyone rattle can their own to save a buck?
  2. Jan 17, 2019 at 10:56 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Judging by the icy taco as your avatar, you’re somewhere that gets snow and probably salted roads. I’d get PC as it’ll withstand the elements that much better.
    With that said, all my stuff is rattle canned
    SkinnyP2[OP] likes this.
  3. Jan 17, 2019 at 10:58 AM
    Leman
    Leman BROverlander
    North Alabama
    '16 TRDOR4x4
    I prefer rattle can, specifically bedliner for armor. Makes it easy to touch up when they do get scratched.
  4. Jan 17, 2019 at 10:59 AM
    SkinnyP2
    Yeah I we ended up with some snow down here in Virginia, but from what I’ve seen they use mostly sand.
    Powder coat might be worth it just for the longevity and everything.
  5. Jan 17, 2019 at 11:02 AM
    vanrynd
    vanrynd Well-Known Member
    dan
    West Chester, Pa
    2017 Off Road DCLB
    WIP
    I had same concerns when I got my bare sliders, decided too powder coat them so they have a solid "foundation" (if you will)...all touch ups will be rattle can.
    after picking them up from the coater......glad I spend the money.
    obviously it's about money and convenience for the owner....your call, they both will look good, done right.
    EatSleepTacos likes this.
  6. Jan 17, 2019 at 11:03 AM
    11Bguy
    11Bguy Well-Known Member
    Va
    2017 DCSB TRD
    Icons/ JBA UCA's
    Rattle can works great too. I cleaned mine real well with a degreaser then put on a couple coats or self etching primer and a couple coats of spray on bed liner. However, on the inside where the slider touches the frame I just used regular black paint so there was no gaps or "obstructions' from the bed liner texture.
    I like this for two reasons. It gives me a little texture when I step on them so there is no slippage and anytime I get a little rash or scrape on the slider I can just touch it up and not have to worry with getting them recoated.
  7. Jan 17, 2019 at 11:09 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    don't waste money on powder coating sliders and skids (or even bumpers really) if you intend on using them for their designed purpose. It's a waste of money because the powder coating won't hold up, just mask off areas you don't want to hit with paint using tape and cardboard/grocery bags and go to town with a rattle can...touch up as needed
    Mr-Paul likes this.
  8. Jan 17, 2019 at 11:10 AM
    eon_blue
    Azusa, CA
    Not to mention, proper prep and handiwork with a rattle can will look just as good to most people's eye as powder coating will.
  9. Jan 17, 2019 at 11:19 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I rattled mine. Kinda wish I powder coated them as right now where the rocks hit are rusted to all hell (will need to do a thicker coat on these locations). I did drag them on a rock at some point (don't recall every doing this, but I have 12" scratch down one of them) and have rust there now too. But touch up will be pretty simple to do once it warms up and will match the rest.
    If you plan on using them, don't powdercoat them. If you don't plan on beating them up, powder coating may be a good easy clean option.
  10. Jan 17, 2019 at 12:04 PM
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    You can fix a lot of door dings with how much you're spending on sliders. Ridiculous. If they are mainly for "door ding protection" is there even a reason for making this thread? Rattle can and save yourself the money for these outrageously priced "door doing protectors".
  11. Jan 17, 2019 at 12:07 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Powder coat.
    $120 is a good deal
  12. Jan 17, 2019 at 12:07 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    One long gravel road and it won’t matter anyways. I’d just paint it realizing it will be a annual maintenance thing. PC will need stripping and paint if it fails too, especially if you use them as sliders.
    V V V there, you see? V V V
  13. Jan 17, 2019 at 12:09 PM
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    from experience, it's annoying to spray paint sliders. I did 2 coats of self etching primer and 2 coats of gloss black.
    By the end I was really wishing I forked up the monies for PC. Besides, you can always spray paint over the PC after you use your sliders. My sliders get an annual refresh
    vanrynd and jowybyo like this.
  14. Jan 17, 2019 at 12:09 PM
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    Or, to throw a wrench in everyone's sensibilities... powdercoat them, because it's only $100ish bucks and you're not doing heavy offroading, and the powdercoat looks pretty good.
    And if they get scratched up from using them, then they're going to have nicks and grooves, and your surrounding armor is going show wear, and it won't matter if you decide to touch them up with a can or have the whole mess re-coated.
    -Craig
  15. Jan 17, 2019 at 12:45 PM
    chaotic_taco
    chaotic_taco Well-Known Member
    ATX
    2017 DCSB TRD OR MT
    I rattled can'd my All Pro Apex sliders. Did some light clean up with a grinder, sand, clean with mineral spirits, gloss black for the mounts / frame contact points, and bed liner for the rest. I had put gloss under the bedliner but it's not worth the trouble. It's really easy to touch up, which if you go off road at all, you'll need to do.
    My roof rack from baja rack is powder coated, and has chipped in places where my plastic canoe has rubbed or damaged the powder coat, or from limbs getting snagged. Powder coat is fairly fragile if you expect to use your armor.
  16. Jan 17, 2019 at 12:53 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Line-X, did that on my last truck after powder coat was all chipped up after a year on gravel roads. Looked great after 3yrs with the Line-X.
  17. Jan 17, 2019 at 1:25 PM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    sent you a pm
  18. Jan 17, 2019 at 4:09 PM
    Tocobob
    Tocobob Well-Known Member
    I bought mine from California shipped it to PA. Small surface rust was a huge pain in the ass to clean before rattle can with primer than bedliner. if I did it again I would get it powder-coated and just hit it with bedliner.
  19. Jan 17, 2019 at 4:29 PM
    Mad Mark
    Mad Mark Well-Known Member
    18 TRD 4x4 off-road
    Steel it. $30 a can but it’s pretty much powder coat in a can.
  20. Jan 17, 2019 at 4:40 PM
    Clearwater Bill
    Billy
    Largo Florida
