Painting Stock Running Boards
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hoopscoach, Feb 11, 2010.
  1. Feb 11, 2010 at 7:30 AM
    hoopscoach
    hoopscoach [OP] Active Member
    Danny
    Fredericksburg, VA
    08 DblCab TRD
    I was wondering if anyone has ever painted their stock running boards. I am going to be painting my rims black and would like to do the same with the running boards. Anyone with any pics or advice on this? I was thinking about taking them off, but I figured I would try painting them to see how it looks. Can I use the same spray I used for the tires for them? Also, I was think about using a textured spray for the running boards. Any thoughts? Thanks.
  2. Feb 11, 2010 at 8:58 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do you have the OEM running boards or the tube steps?
    I would assume you're not talking about the OEM running boards because they're already black - and plastic. Not a good idea to paint the plastic.
  3. Feb 11, 2010 at 9:02 AM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2018 4Runner LE
    TRD Pro Wheels BFG AT Tires
    not all OEM are black or plastic
    to OP.... First of see if you really need running boards i took mine out last month since they wernt black and it just looks so much better without them that i sold my boards and dont want them. Now if you really need them, you can maybe get them bedlined. I dont recomed painting them black yourself with a spray paint since you will be stepping on it, other car's doors will hit it and paint will easily come off. Im not sure if you are a big fan of chipped paint or not but i personally cant stand it.
  4. Feb 11, 2010 at 9:03 AM
    tanktodd
    tanktodd Well-Known Member
    Todd
    back on the right side of the bay, Ala
    08 Prerunner w/TRD Sport Pkg
    Limo tint in back w/ 20% on doors. Removed all badges. Stereo headunit, all new door speakers, 2 amps, and 10' sub...so far Black bullbar MotoMetals and 285/70/17 Duratracs. 3" OME springs in front and aal in back with tsb springs Black UWS tool box 5100's all around Plasti-dipped evo front end Fog light anytime mod OEM steps (for sale) HID fogs 55w 3000k HID heads 35 w 6000k "Cool white" dome & map lights
    I painted mine black and they look good but I'm about to sell them to get some sliders.
  5. Feb 11, 2010 at 9:49 AM
    hoopscoach
    Danny
    Fredericksburg, VA
    08 DblCab TRD
    They are silver tube steps. Not the chrome ones.
  6. Feb 11, 2010 at 10:52 AM
    Janster
    Jandy
    Lancaster, PA
    The OEM Running Boards are black plastic.
    The tube steps are different.
  7. Feb 11, 2010 at 10:56 AM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    You can use any type of paint.Only thing you need to worry about is durability.Duplicolor makes some good wheel paint that pretty durable.I used PPG shopline paint but you need spray gun. You can spray plastic but need to prep good.Silver one was when I painted my 4runner plastic cover running boards.
  8. Feb 11, 2010 at 11:52 AM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    I like the look of my double cab with the running boards better than without. I also have a silver truck and the silver TRD running boards (they are called step bars in the TRD catelog) match well enough. To the OP, I think running boards painted to match the truck looks sharp.
  9. Feb 11, 2010 at 12:49 PM
    Death_Stalker
    Talha
    Cypress, TX
    2018 4Runner LE
    i must be thinking about the wrong stuff because i had OEMs or i thought i had OEMs which wernt plastic ... :confused:
  10. Feb 11, 2010 at 12:56 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Use Krylon Fusion SP...that stuff is solid for metals and plastic :)
  11. Feb 11, 2010 at 1:49 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
  12. Apr 2, 2010 at 9:24 PM
    inlinejohn
    inlinejohn Well-Known Member
    Washington
    08 Tacoma TRD Sport SR5 4WD LB
    3" spacer/AAL lift, Toyo Open Country MT 265/70R17, Kenwood USB, Truxedo LowPro QT, Grillcraft w TOYOTA emblem...coming soon, Avid Offroading Sliders...coming soon.
    I have the tube OEM boards on a silver truck and am thinking of Rhino Lining them a dark grayish color.
