Painting rear drums
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Korby, Aug 15, 2020.
  1. Aug 15, 2020 at 6:26 AM
    Korby
    Korby [OP] Well-Known Member
    Freeport PA
    2017 Magnetic Grey Tacoma TRD Sport
    I know this has probably been asked. So if someone could direct me to the thread it would be great.
    I noticed yesterday that there is some normal rust on the outside of the brake drum. Can it be painted? Any special prep I would need to do?
  2. Aug 15, 2020 at 6:29 AM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Wire brush the rust off then rattle can
    9th and Skydvrr like this.
  3. Aug 15, 2020 at 6:30 AM
    Korby
    Freeport PA
    That's what I was thinking but I wanted to make sure before I did it. Thanks
  4. Aug 15, 2020 at 6:31 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Be sure to put a thin film of grease on the back of the wheel hat. This will help keep your wheels from sticking next time you pull them
    Skydvrr likes this.
  5. Aug 15, 2020 at 7:30 AM
    Korby
    Freeport PA
    Well I was thinking of leaving them on the truck and painting them. To be honest I haven't really dealt with drum brakes that much. My s10 had them but I never needed to change them in the time I had the truck. Especially since it was a manual and my ram had disc all the way around.
    So the better question is should I remove it and paint it that way
  6. Aug 15, 2020 at 7:34 AM
    Clearwater Bill
    Billy
    Largo Florida
    I'll assume you aren't looking for a hot color to show off your old tech, just something to protect the surface and make them appear a bit cleaner.
    The drum is nothing but a chuck of cast iron, and you can treat it as such.
    Meaning you can simply wire brush and/or sand the rust spots and shoot it with black Rustoleum, Krylon, or BBQ grill paint. Whatever.
    Another color that is sedate but looks nice in many applications is Rebuilders Cast by Plasticote. I've used it on calipers many times. No reason not to use it on the drums too, if you like the look.
    Jimmo likes this.
  7. Aug 15, 2020 at 7:38 AM
    jersey jim
    jersey jim Well-Known Member
    Jim
    2018 Cement DCSB TRD Sport 4x4 6MT
    As mentioned, it's just a hunk of cast iron. Personally I'd wire wheel any rust off, then a high heat primer and paint. And, for the sake of all that is right and proper, just paint them black.
    Big tall dave likes this.
  8. Aug 15, 2020 at 8:25 AM
    Korby
    Freeport PA
    That was my plan was to paint them black. I just don't like seeing the rust. Lol
    So keep them on the truck. Wire brush and paint was my plan.
    whatstcp likes this.
  9. Aug 15, 2020 at 8:32 AM
    jersey jim
    Jim
    :thumbsup:
    I'd cover the bed sides with a cheap lightweight plastic sheet, and mask off the wheel studs too. But you probably already thought of that. ;)
    Korby[QUOTED][OP] likes this.
  10. Aug 15, 2020 at 8:34 AM
    Korby
    Freeport PA
    Yes sir!!! I do some detailing on the side and have seen many people paint their drums and all I see is over spray. From doing little projects like this. They get mad that I wasn't able to get the paint off. But oh well. You win some and you lose some. Lol
    Thanks again everyone!
    jersey jim[QUOTED] likes this.
  11. Aug 15, 2020 at 8:47 AM
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    I’d pull them off and paint them on some cardboard away from your rig. That way no risk of overspray. They pull right off so long you don’t have the park brake on..
    kahanabob likes this.
  12. Aug 15, 2020 at 10:07 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Use high heat engine paint !
  13. Aug 15, 2020 at 10:37 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Rustoleum high heat black like 2,000 degrees works great. Found anything like engine paint will get sticky, and melt to your wheels making it a bitch to remove your tires the next time to rotate them..
